土木在线论坛 \ 装配式建筑 \ 装配式施工 \ 项目分享,一种降低综合造价的超薄屋面技术
发布于:2024-05-23 16:09:23 来自:装配式建筑/装配式施工 [复制转发]
南昌旭辉中心示范区63万㎡城市综合体及19万㎡中央公园,位于南昌经济技术开发区。横跨商业、办公、文化、住宅、生态五大空间,是旭辉在江西首个城市综合体。前期,南昌旭辉中心作为示范区售楼部,后期将变成城市公园公共建筑,聚拢城市中自然、人文、艺术、运动等多维度资源,形成一个多元的生活圈。
CIFI Nanchang Center Demonstration Area of 630,000 ㎡  city complex and 190,000 ㎡  central park is located in Nanchang Economic and Technological Development Zone. Spanning five major spaces: commercial, office, cultural, residential and ecological, it becomes the first urban complex of CIFI in Jiangxi. In the first stage, CIFI Nanchang Center is used as the sales department of the demonstration area, and later it will be turned into a public building of the city park, gathering multi-dimensional resources such as nature, humanities, art and sports in the city, forming a multi-dimensional living circle.
▼图一:示范区鸟瞰,overview of the CIFI Nanchang Center
圆形建筑形体如天外来客直插广场中央,透明的玻璃体块在如茵绿草间熠熠生辉。建筑位置恰如其分的衔接上下视觉,浮于斜坡上方,明丽透亮,像曲面的巨符画卷,周围的人、物、景统统收纳其中。
The round shape of the building is like a visitor from the sky plunging into the center of the square, and the transparent glass blocks shine among the green grass. The building's position is aptly connected to the upper and lower vision, floating above the slope, bright and translucent, like a curved scroll of giant symbols, in which the surrounding people, objects and scenery are all included.
▼图二:城市公园夜景,the charming night view
建筑空间、形体和材料语言重塑着人与建筑的角色关系,而白色玻璃所带来的通透与豁达赋予建筑沉浸感与生命力。为了达到这一效果,在结构上必须选择更“细”的支柱,更轻的屋顶能消溺建筑的坠落感,构建点、线、面的合理关系。
The language of architectural space, form and material reshapes the relationship between human and architectural roles, while the transparency and openness brought by white glass gives the building a sense of immersion and vitality. In order to achieve this effect, the structure must choose thinner pillars, lighter roofs can drown the building's sense of falling, and build a reasonable relationship between point, line and surface.
▼图三:建筑结构原始方案,Original scheme of building structure
屋面是直径为48米的圆形,虽然可以采用常规的“径向梁+环向梁”的网格结构方案,但屋面不论是采用铝板、矮立边铝镁锰板或者是钛锌板,都会存在屋面构造厚度过大的问题,而且会造成很多的“缝”或者“肋”。仅“吊顶+屋面保温防水”的建筑构造厚度将达到300mm左右。为了达到“轻薄屋面”效果,我们采用了自有专利的“板桁架”方案,最终实现立柱直径优化为203mm,屋面最大悬挑处16m,建成后屋面厚度几乎看不到的效果。
The roof is a round shape with a diameter of 48 meters, although the conventional grid structure scheme of "radial beam + circumferential beam" can be used, but whether the roof is made of aluminum, short standing edge aluminum-magnesium-manganese plate or titanium-zinc plate, there will be a problem of excessive thickness of the roof structure, and it will cause a lot of "seams" or "ribs". " or "ribs". Only the "ceiling + roof insulation and waterproofing" building structure thickness will reach about 300mm. In order to achieve the effect of "light and thin roof", we adopted our own patented "plate truss" solution, which finally realized the optimized column diameter of 203mm, the maximum roof overhang of 16m, and the almost invisible roof thickness after completion.
▼图四:多次立柱布置优化,Column layout optimization
▼图五:通透的建筑立面,the transparent book bar
板桁架是一种基于产品化思维,通过极致设计和标准化的方式打造的一种用于轻薄屋面的技术方案,相对于传统钢结构 + 上下铝板包覆的屋面设计方案具有明显优势。
Plate truss is a technical solution for light roofing based on product-oriented thinking, through extreme design and standardization, which has obvious advantages over traditional steel structure + upper and lower aluminum cladding roofing design.
▼图六:板桁架横断面传力示意图,Schematic diagram of force transmission in cross section of plate truss
板桁架的主要特点就是超薄。之所以超薄,是运用了以下几项创新技术:
1)结构即建筑,通过机加工等多种技术,保证面层平整美观,无需另做铝板装饰,从而节省了双面200mm左右的装饰层厚度。
2)面层即结构,相比于分散布置的梁式结构而言,板式结构的面层钢板具备强大的刚度。
3)巧妙地W型腹板,使得板桁架双向传力效应明显,大大提高了结构的整体效应。
因此,板桁架的建筑完成厚度可以做到50mm~100mm,边缘厚度甚至可以做到5mm,比常规结构动辄300mm以上的建筑完成厚度要轻薄许多。10cm的板桁架甚至具备10m的悬挑能力。
The main feature of the plate truss is its ultra-thinness. The reason why it is ultra-thin is the use of the following innovative technologies:
4)The structure is the architecture. Through machining and other technologies, the surface layer is flat and beautiful, and there is no need to do aluminum plate decoration, thus saving the thickness of the decorative layer of about 200mm on both sides.
5)The surface layer is the structure. Compared with the scattered beam structure, the surface layer steel plate of the panel structure has strong rigidity.
6)The clever W-shaped web realizes the bidirectional force transmission effect of the plate truss, which greatly improves the overall effect of the structure.
Therefore, the finished thickness of the plate truss can be 50mm~100mm, and the edge thickness can even be 5mm, which is much thinner than the conventional structure with a thickness of more than 300mm. A 10cm -thick plate truss even has an 10m cantilever capability.
▼图七:建成效果:屋面悬挑16m,Completed effect: Roof overhang 16m
板桁架的第二个显著特点是连续的无缝外观,它的无缝外观甚至优于传统的铝板装饰方案,铝板拼缝处的硅胶由于年久老化易变形变色,影响外观,板桁架结构则无此顾虑,结构完成面可代替建筑面层直接使用,可在屋面、雨棚、廊桥等结构类型中广泛应用。
The second notable feature of the plate truss is the continuous seamless appearance , which is even better than the traditional aluminum plate decoration scheme. Without this concern, the structural finish surface can be used directly without the building surface layer, and can be widely used in roofs, canopies, bridges and other structural types.
板桁架的第三个优点是支点布置灵活,由于板桁架具有良好的双向传力性能,建筑师可以根据空间要求灵活的布置立柱,而不必像常规梁式结构一样必须考虑与上部结构的关系。
The third advantage of the plate truss is its flexibility in support arrangement. Since the plate truss has good bidirectional force transmission performance, the architect can flexibly arrange the columns according to the space requirements, without having to consider the relationship with the superstructure like the conventional beam structure.
▼图八:结构三维深化模型,Structural 3D deepening model
对于造价与工期而言,相对于传统结构体系,板桁架在结构上面的支出虽然有所增加,但由于节省了装饰铝板的费用,综合造价基本不会增加。而且简单的现场工序可以大大降低甲方的工程管理复杂度,减少管理成本。板桁架采用标准化预生产,现场施工结构完成即宣告建筑完成,省却铝板装饰工序,现场施工工期亦可缩短50%。
In terms of construction cost and construction period, compared with the traditional structural system, although the expenditure of structure has increased, the overall construction cost will basically not increase due to the savings of decorative aluminum plates. The simple on-site procedures can also greatly reduce the complexity of developer’s project management, loweing management costs. The plate truss adopts standardized prefabrication, the completion of structure also means the completion of architecture. The aluminum plate decoration process is no longer needed, the on-site construction period can be shortened by 50% as well.
装配式施工
9484 条内容 · 133 人订阅
318米高的长沙金茂大厦之创新应用篇——工艺、材料、工具、技术、管理等创新
前言 历经十数年蜕变,梅溪湖国际新城已成城市标杆。而在梅溪湖畔,承载着长沙人、河西人殷殷期盼的城市CBD建设正如火如荼。 ▲梅溪湖CBD规划图 这其中最引人瞩目的——长沙金茂大厦,项目总建筑面积21万平方米,由1栋318米高的办公塔楼,一座4层集文化、商业于一体的裙房以及由建筑围合出的城市广场有机组成。
