土木在线论坛 \ 园林景观 \ 景观规划设计 \ 释放天性的乡村俱乐部 | 江小白的一亩三分地
发布于:2024-05-21 16:04:21 来自:园林景观/景观规划设计 [复制转发]
乡村究竟是什么样子,乡村自己又想成为什么样子?
当现代建筑走进传统乡村,不同寻常的形式带来关联与冲突,质朴的体量和空间传承不变的气质。
项目背景
PROJECT CONTEXT
项目位于重庆市江津区慈云镇,这里是典型的西南地区丘陵地带农村,距离江小白酒厂约 15 分钟车程,是江小白酒业生产的原材料种植基地,也是酒业集团形成一二三产联动的重要节点。
The project is located in Jiangjin District of Chongqing City, a typical south-west village in the hilly terrain. The site is 15 minutes’ drive from Joybo Distillery and is the raw material planting base of the liquor production, also a key linkage of primary, secondary and tertiary industries of the Joybo Group.
项目理念
PROJECT CONCEPT
“释放天性的乡村俱乐部”
A Country Club to Release Nature
由于品牌自身的独特属性,江小白的受众多为都市中的时尚人群,如同整个社会一样,他们的兴趣也正在逐步转向乡村。用现代的设计手法在老环境中创造新氛围,打造即不同于都市又区别与传统农家乐的当代乡村体验,探索当代乡村建设发展的全新可能性。鼓励人们来到乡村不仅仅是换个外部环境,也要换个内在心境,将身心同步回归自然,释放天性,感受快乐。
Joybo is a special brand which is popular especially in the younger fashion group of people inside the city. Their interests are turning slightly to the countryside as the whole society does. We create new atmosphere in the old environment using modern design method, to build a contemporary country experience different from urban life or usual rural life, and to explore a new possibility of country development. We encourage people come not just change physical environment but also change the inner world, go back to nature from body to mind, release nature and enjoy.
总体布局
OVERALL MASTERPLAN
“跳岛村落”
Island Hopping Village
项目现场有一条小溪汇入一条主河流,周边地势相对平缓,若干个半岛随水系蜿蜒错落有致,规划选择将建筑及功能体验区分布在这些半岛上,采用“跳岛”的方式营造体验动线,既能丰富不同场景之间切换的独特体验感,又能满足各个不同功能板块之间相对的独立性和纯粹性。
There is a small stream flows into a main river with flat lands around,several peninsulas sits along the riverside. We choose to locate architecture and functional areas on these peninsulas, to create a special experience route like 'Island Hopping', which brings an exchanging experience from different unique scenes and at the same time keep the independence and purity of different functional areas.
⊙ 总平面图
”依托场地关系的空间原型“
Spatial prototype based on site relation
没有过多的去考虑“乡村”应该长什么样子,而是关注于什么样的空间形态是最适合这几个半岛的场地关系,采用最纯粹的几何空间语言去呼应自然的环境,创造令人感到舒适的对比冲突和丰富变化。
There is no preconception about what a country supposed to look like, however we focus on which type of space form fits these peninsulas best, to talk with the natural environment with the most original geometric form of space, and create a comfortable contrast together with diversity.
⊙ 空间形态思考草图
分项设计
PROJECTS
入口停车场  ENTRANCE PARK
不规则的彩色混凝土停车位营造出自然放松的状态,散落的小乔木和种满风车茉莉的白   色花架丰富了垂直空间的内容,营造到达后的花香气息,又在一定程度上提供夏日里的遮阳。
Colourful parking spaces sits in a irregular layout to create the feeling of natural and relax. Small trees and white steel flower shelf with windmill jasmine enrich the vertical space content, provide flower smell when arrive and provide sunshade in the summer.
⊙ 入口停车场 | 平面图
入口卫生间 ENTRANCE TOILET
入口卫生间整体呈一个朴素的长方体,位于停车场靠近入口的角落,与混凝土片墙形成一个具有引导性的入口通道空间。正面是一台由重庆青年建筑师群体集体涂鸦完成的废弃拖拉机,用艺术与乡村的亲密结合欢迎人们的到来。
The entrance toilet is a simple cuboid as a mass, locates at the carpark corner close to the entrance. The mass creates a guided entry path together with a piece of concrete wall. In front of the toilet is an abandoned tractor doodled by a group of Chongqing youth architects, to welcome people with a close relationship between art and country.
⊙ 入口卫生间 | 空间形态分析
打破传统卫生间的空间模式,打造一个由若干单体组合成的半室外空间集群,每一个位置都是一个独立小单间,公共区域的天窗引入阳光和雨水,滋养内部的植物生长,单间内的天窗不设置玻璃,出门即是野外,营造返璞归真的独特体验。
To break the traditional mode of public toilet and build a new prototype of having several toilet units combined together. Each units have sky light and allows rain to come in. Plants grow in the half-exterior public space naturally. All the toilet units sit just in the wild nature, a unique experience of return to nature.
⊙ 入口卫生间 | 轴侧图
⊙ 入口卫生间 | 平面图
大地美术馆 LAND MUSEUM
⊙ 大地美术馆 | 平面图
⊙ 大地美术馆 | 1-1 北立面图及短向剖面图,1-2 西立面图,1-3长向剖面图
“高粱地里的水泥粮仓”
A Concrete Barn in the Sorghum Field
这是一座高粱地里水平稳重的清水混凝土坡屋顶建筑,用现代的手法诠释质朴的精神,尺度上的些许放大和形式上的些许传承,共同作用于乡村内在气质而非外在形式的延续。
This is a pitch roof cast-in-place concrete building sitting horizontally and steady in the sorghum fields. Use the modern way of design to inherit the spirit of countryside rather than the similarity in the shape of surface.
⊙ 方案草图
⊙ 建筑体量演变
⊙ 建筑形态思考 | 概念设计草图
“ 高粱同心圆 ”
broomcorn concentric circles
⊙ 平面草图
⊙ 关系衍变过程
线性的空间形态顺应长条状半岛的环境关系,兼顾农庄研究人员的日常使用与参观人群通行的作用,在半岛轴线的基础之上顺时针旋转 15 度,既使建筑山墙面正对车行入口,创造更好的展示效果,又让建筑出口避开现有步行桥面对回水塆,创造一个亲水平台作为节奏变化的空间节点。
The space form stays in a line to follow the site relationship of the peninsula, give a consideration to the researchers' daily work and tourists' visit journey. The building direction rotates 15 degrees clockwise from the peninsula’s axis, make the front elevation of the building facing the entrance of the cars and avoid the exit facing the bridge, at the same time creates a resting platform touches the river.
⊙ 亲水平台剖面图
“ 敬畏农业 ”
Respect for agriculture
穿过弧形的混凝土墙,一个仅有 2 米高的空间界定空间的转变,用独具精神性的轴线动线和和三角形的立面去营造庄严神圣的感受。
Across the curved concrete wall and a 2 meters clear height space, the spiritual route axis facing the triangle front face of the building creates a solemn feeling.
⊙ 立面比例
进入美术馆随之而来一个通高的空间,空间向上,肃穆的斜向线条向天空汇聚,引入阳光;空间向下,圆形的下沉徐徐走入大地,用上下空与唤醒人们对农业的敬畏之心。
A 3 levels height space comes first when enter the museum, on the upper space diagonal lines converge to the sky, to welcome the sunlight coming in; on the lower space, circular sunken space goes into the land step by step, both to awaken the revere of agriculture.
⊙ 水景的剖透视图
“ 空间组织与场所营造 ”
spatial organization & scene construction
在一个完整的条状空间内通过条石幕墙,阳台,天窗,露台,混凝土幕墙等空间形式语言去营造丰富的室内外变化,让人们来到乡村,即便是走入了建筑内部也会不停的以不同方式与外部环境发生关系。
Stone curtain wall, balcony, sky window, terrace, concrete curtain wall and other design languages create a wealth of variation of the space from inside out. To let people have the experience of keep touching external natural world even when they walk inside the building.
建筑东西向为长边主采光面,东侧日照时间相对较短,在一层布置展览空间,二层布置阳台,三层布置会议空间;西侧日照时间相对较长,在一层布置走廊,并用条石幕墙丰富光影效果,在二层开小窗,三层布置走廊。建筑南侧二层为混凝土幕墙,外部西南侧种植蓝花楹,在夏日遮挡一定的西晒,帮助控制室内温度,在冬日引入阳光,营造丰富的光影效果。
The east facade has less direct sunlight, which decides to have exhibition space on the ground floor and balcony on the second floor and meeting rooms on the third floor. The west facade has more direct sunlight, which allows to have a corridor with stone curtain wall as shadow casters on the ground floor, small windows on the second floor for the office and corridor on the third floor for the meeting rooms. Concrete curtain wall on the south facade to control the heat in the summer and filter the sunshine in the winter together with jacarandas outside.
⊙ 大地美术馆通风分析图
大地美术馆材料与建造
Materials and construction of the musem
木纹清水混凝土兼具自然的纹理和肃穆的现代性,其一次浇筑不可修改的特性具有极大的施工挑战,但对于希望用现代手法来传承质朴气息的大地美术馆来说无疑是最契合的选择,经过大量的打样最终呈现出了理想中出现代质朴的效果。
Cast in place concrete with wood texture has both a natural feeling and the solemn modernity, which is the best choice to inherit the plain temperament of the land through modern way of architecture. However, its un-modifiability brings huge challenge to the construction work and there has been lots of test to reach the ideal effect.
⊙ 木纹清水混凝土打样过程
“ 混凝土龙出水 ”
Concrete Water Outlet
现场预制的成品混凝土龙出水让排水问题的解决方式回归自然,雨水经过坡屋顶自然流淌到排水天沟,再由龙出水流下到建筑周围的水渠,不刻意掩饰雨水与建筑原有的关系,让其自然呈现。
Prefabricated cast in place concrete water outlet brings the drainage back to traditional and natural. Rain flows from the pitch roof to the roof gutter then drop to the gutter around through the water outlet, to make the relationship between rain and architecture obvious.
BIM正向设计
从概念到现场管理全程使用BIM技术完成设计,在前期为频繁的方案修改出图提供了高效便利的工作流程方法,在后期极大程度的避免了各专业之间的碰撞问题与现场的施工误差。
The use of BIM starts from the very beginning concept stage to site management, which provides high efficiency during design process and helps a lot to avoid construction error on site.
⊙ BIM应用
田野商店 THE FIELD STORE
农副产品小超市与文创小商店作为配套的商业功能与美术馆主体建筑直接分离,在高粱地里以两个独立圆形平面的点状空间呈现,既从建筑体量上明确功能属性的不同,又有意识的将人们的行为活动从建筑内部拉到高粱地中,室内外频繁切换,回归自然。两个商店一个内部抬高 60 公分,营造轻松自由的平面,另一个抬高后又降低,营造沉入大地的氛围。
Agricultural products store and cultural creative products store are separated from the museum as two spot space in the sorghum fields, to have a clear distinguish between culture and retail, also brings people from interior to fields. One of the stores elevated 60cm height from the ground to create a free walking plan and anther one goes up and down to create the atmosphere of sunken in the land.
⊙ 田野商店草图
建筑周边环绕的木平台步道提供人们行走和坐在田间的可能性,平台离地 60 公分让人们坐下的时候腿脚刚好悬空摆动,营造轻松舒适的乡村体验。
Timber platform around the store provides the possibility to walk and sit in the fields, the height of 60cm let the legs swinging freely when sitting there, to create the experience of relax in the countryside.
⊙ 农副产品小超市平面图及剖面图
⊙ 文创产品商店平面图及剖面图
蜗牛菜园 SNAIL VEGETABLE GARDEN
位于紧邻美术馆的半岛端头,蜗牛菜园是一个为蔬菜花果设计的专属空间,砖砌固定花台用于种菜,周边一圈种满不同品种的花果树,在不同季节呈现不同的自然风貌。菜园整体平面布置为一个由中心向外蜿蜒延伸的螺旋线,既形似蜗牛壳的螺旋图案,又营造如蜗牛般缓慢行走的游览体验,靠近河边的位置穿过草丛延伸出五个神似蜗牛触须的亲水平台提供驻足停留的空间,用空间形式语言引导人们放慢节奏,耐心品味大自然的美好。
Sitting at the front of the peninsula next to the museum, snail vegetable garden is a space designed for the vegetables, flowers and fruits specifically. Fixed planting bed for vegetables, flower and fruit trees around to let different landscape in different seasons. The garden layout is a spiral line as a route from the center, a similar shape to the snail to make people walk slowly like a snail. Five snail tentacles extend out to the river as a resting platform to let a moment close to the water, to guide people slow down and enjoy the nature through space arrangement.
⊙ 蜗牛菜园平面图
菜园地面采用荧光石铺装,每到夜深人静的时候,地面的星空与天上的银河遥相呼应,河岸的萤火虫在身边飞来飞去,营造无比浪漫的乡村氛围,是“偷菜”与饮酒的绝佳场所。
Use fluorescent stones as the ground paving material for the garden, to create starry sky on the ground in the evening that echoes the galaxy in the universe, together with the fireflies along the riverside to create a romantic countryside atmosphere, a perfect space to drink and "vegeteal".
大地酒馆 LAND TAVERN
“ 四向木屋 ”
Four Directional Wooden house
大地酒馆位于蜗牛菜园后的第三个半岛,起到承上启下的作用,是人们停留聚集时间最长的空间区域。东侧为入口方向,有一座长满竹林的小山丘和几户农家,西侧三面环水,远眺丘陵农田风光,南边开阔拥有充足的阳光,北侧与美术馆和菜园遥相呼应。
Land tavern sits at the third peninsular after the snail garden, is a space where people spend most of the time to stay and connects the front and back. The entrance is on the east side with bamboos and farmhouses, the west side is surrounded by water with a view to the farmland, the south has full of sunshine and the north facing museum and vegetable garden.
⊙ 大地酒馆 | 1-1平面图、1-2、1-3立面图
⊙ 体量生成
建筑体量直接呼应四个方向所拥有的不同环境及视线关系,将一个十字体量空间在竖向上拆分为两个部分,底层东西向架空形成一个通透的灰空间,首层南侧体量顺河岸延伸以引入更加充足的阳光。一横一竖的空间组织用一种打破河流围合感的方式呼应了场地的空间关系,建筑与河流之间的灰空间变化丰富,让人们与河的关系也随之不停的变换。
The architecture mass talks to the environment and sight relationship of the four directions directly. Separate a cross vertically into two parts, a half external space goes through the bottom from east to west, the south body extend along the river to bring in more sunlight. The space structure of a cross breaks the enclosure feeling from the river, creates a better relationship to the site which has more variation distance between people and the river.
首层南侧空间具有较好的采光,为咖啡下午茶空间,北侧采光较少,为厨房及酒吧空间,二层东侧是满足项目运营的用餐大厅,西侧拥有下午较好的光影和风景设置为用餐包房。各功能板块之间相对独立又通过架空层及楼梯通道进行有机串联,上下层空间方向的变化在一个小尺度空间中营造出既丰富又清晰的体验感。
The south wing has good sunshine which is suitable for coffee and tea in the afternoon. The north part has less sunshine which is the kitchen and bar. The east part on the second floor is the main dining room as a big space and south part are three private rooms. Each part is well separated and connected with the central grey space and stairs.
“村口”大树
The tree aside the entry
大地酒馆东北方向既有机动车入口,又有从大地美术馆和蜗牛菜园方向来的步行桥,一颗高大的柿子树以优雅的姿态迎接人们的到来,树下的木质平台提供了人们在“村口”树下的各种行为活动可能性,迎接送别、休息交流。
One big persimmon tree stays at the entrance to welcome the guest and a timber platform around the tree to create variety possibilities at the entry of the village.
“底层架空与下沉花园”
Elevated space and sunken garden
建筑东西向下方为一个整体架空的通廊,串联入口,咖啡厅,酒吧,楼梯以及半岛尽端的下沉庭院。靠近下沉庭院的部分两组 V 字柱轻松的界定了两桌用餐区域,结合架空层带来良好的通风和遮阳营造十分舒适的用餐氛围。下沉庭院在半岛尽端,三面环水,夏日可以烧烤篝火跳舞歌唱,冬日可以烤羊煮酒,还原乡间原本应有的自然轻松和生活氛围。
One half external space on the ground floor goes from east to west, connects the entrance with cafe, bar, stair and a sunken garden at the end of the peninsula. Two group of V shape columns creates beautiful dinning atmosphere together with the shade control and ventilation from the space. The sunken garden is surrounded by water which provides the possibility of barbecue in the summer and campfire in the winter.
“十字”中心
Cross Central
两个体量在平面上重叠的部分是上下联通的交通空间,上方的走廊顺应下方建筑的方向向南北向延伸,正中心上方是一个圆形天井,引入蓝天、阳光和雨水。
The overlap of two parts is where two floors connect, one round patio sits just at the cross on the roof, brings in the light, rain and sky.
“大地酒馆材料及建造”
Material and construcion of the Land Tavern
材料的使用上,相对于大地美术馆“质朴“与”肃穆“的木纹清水混凝土运用,大地酒馆则更多将主题从敬畏农业转向亲近农业,”一座乡间的木制酒肆馆驿“是它的定调。
Different from the Land Museum's purpose to reflect plain and solemnity, Land Tavern position as "a wooden tavern in the country", to talk more about how to close to agriculture.
而在木材的选择上采用了上下两层材料分色的处理手法,一楼的木屋采用浅色灰化松木,使体量多变的一层建筑更加轻盈统一。二楼的架空体量则采用深灰色木材,形成乡间一道漂浮的黑色剪影。木饰面幕墙本身则采用节奏多变的凹凸面板与竖向肋板的构造,强化木材质感的同时通过细部尺度消减了整体体量对于乡野的压迫感。
The lower part chooses a lighter color to provide variety and makes the lower body looks lighter, while the upper part chooses to be darker, as a black floating silhouette in the countryside. The wood curtain wall has variable bump and vertical fins, to strengthen the texture of wood and decrease the oppressive feeling that the mass brings to the countryside.
板岩叠放为下沉庭院的座位,野草生长其中形成十分生态自然的状态。
Slate stacked on top of each other forms the seats of the sunken garden, wild grass grows in between creates strong feeling of nature.
小白花房 JOYBO FLOWER HOUSE
位于大地酒馆南侧的第四个半岛,选择了最简单的圆点作为空间原型,将一个曲面的玻璃房子摆在花境中央,内外的植物遥相呼应,曲面的超白玻反射出天空和植物的变化,具有丰富的层次和变化。
Located on the fourth peninsula to the south of Land Tavern, form as a simplest round spot, the flower house is a glass house sitting inside the herbaceous border with plants from inside out and reflection of the sky from the curved glass.
建筑整体抬高 1 米,在底部解决空调外机的放置,使得建筑外立面是一个完整的曲面玻璃而不被打断,同时也避免植物的遮挡,在半岛上形成一个显眼的视觉焦点。顶部用金属板进行遮阳处理,结合内部天井的拔风作用应对重庆夏日的极热天气。
Elevated by one meter to put the air conditional external unit underneath, which allows the whole facade as a continues curved glass surface and plants inside visible from views all around. Metal panels on the top to control the light and shade to deal with the extreme hot weather in the summer.
⊙ 小白花房平面图
乡村球场 COUNTRYSIDE SPORTS FIELD
在运动场设计中以打破常规的空间形态去引导探索不一样的运动体验,正方形的足球场可以让足球运动更加偏重左右转移,也可以设置 4 个球门进行游戏;圆形的篮球场可以满足成年人和儿童不同身高的篮球架需求,也可以设置 4 个篮筐的游戏规则。
To explore different sports experience by changing the shape of the field, square football pitch and round shape basketball pitch provides different possibility of games and rules.
球场卫生间 SPORTS FIELD TOILET
运动场紧邻花房,无论动静都可以在农庄找到属于自己的乐趣,配套的卫生间设有露天淋浴的小隔间,在一场酣畅淋漓的运动之后可以继续释放天性。
The toilet is set for the sports field with three open air shower rooms to provide the feeling of release nature after sports.
⊙  球场卫生间平面图
⊙ 球场卫生间 轴侧图
⊙ 球场卫生间 剖面分析图
植物地图 MAP OF PLANTS
项目名称:江小白的一亩三分地
景观规划设计
25.18 万条内容 · 282 人订阅
客户看了沉默,印尼设计大师职业生涯唯一没有任何修改的项目!
逃离都市环境 一头扎进人迹罕至的密林 曲径通幽 寻找鸟儿的芳踪 在阵阵柚木清香中入眠 △Omah Jati所在的柚树林 Omah Jati 是一座坐落在柚木森林中的别墅,位于印度尼西亚爪哇岛,设计师是来自印尼的世界著名建筑师 Andra Matin
