在齐瓦坦乔湾的格雷罗太平洋海岸,一座名为“Casa Acantila do”的建筑坐落在不断受到海浪冲击的悬崖上。 整个基地处于一个一年四季都能看到绿植的特有环境中。
On the Pacific coast of Guerrero belonging to the bay of Zihuatanejo, lies "Casa Acantilado" prostrated on cliffs that are constantly hit by the force of the sea. Located in an environment of endemic vegetation revealing each season in the region.
不同种类的鸟在山脊的斜坡上筑巢,这座房子就像一座灯塔向渔民发出警告,并在黑暗中提供光线。
Birds of different species nest on the slopes of the ridges and a small lighthouse warns fishermen and provides light in that immense darkness.
▽灯塔 Lighthouse
建筑运用了岩石的元素,通过使用当地材料和形式融于环境,将工艺技术和当地建筑风格付诸实践。
It is developed as an element that emerges from the rocks, mimicking the context thanks to the local materials and forms used, putting into practice the craft techniques and the vernacular architecture of the site.
建筑主体被分为两个旋转的几何体,这些部分的旋转有助于将视线指向太平洋,建筑所在的地形起到决定性因素。房屋可以从最顶层直接进入,没有正门,迎接住户的是一个四面敞开、完全暴露在周围悬崖中的大而温馨的房屋。
The main volume is based on two slightly rotated geometric elements, directing the views towards the Pacific; in this project the topography was a determining factor in the spatial organization. Entering directly from the upper floor, where there is no access door, a large palapa welcomes you and houses the social area completely exposed to the cliffs that surround it.
帕拉帕是由当地采购的石头、木材和棕榈叶等材料制成的,其形状引入了自然光和自然通风,减少能源消耗;
The palapa is made with regional material such as stone, wood and palm leaves, done by local labor, its shape allows the use of natural light and a natural cross ventilation reducing energy consumption;
作为点睛之笔,一个无边泳池部分连接在建筑主体上,产生了一种与太平洋直接相连的感觉。
As a finishing touch, an infinity pool is partially attached to the main structure, generating a sensation of direct connection to the Pacific.
▽无边泳池 Infinity pool
通往私人区域的楼梯带你沿着裸露的混凝土墙走,这让你可以看到树梢的运动,在受到保护的同时感受外部;最后的尽头是一个由混凝土墙砌成的水池,它构成了与太平洋的无限连续性。
The staircase to the private area takes you along uncovered concrete walls which allows you to see the movement of the treetops, feel the exterior while being protected; ending in a pool contained by concrete walls that frame the infinite continuity with the Pacific.
▽混凝土墙和楼梯 Concrete walls and stairs
大堂与客房相连,每间客房都设有私人露台,可供人欣赏难以置信的风景。
The lobby links to the rooms, each with private terraces that open to spaces of contemplation towards the incredible landscape.
▽大堂 The lobby
▽私人露台 Private terrace
▽屋顶平面图 Roof plan
▽底层平面图 Ground floor plan
▽一层平面图 First floor plan
▽面朝大海的正立面 Facade towards the sea
▽侧立面 Side facade
Project: Casa Acantilado
Architecture firm: Zozaya Arquitectos
Website: www.zozayaarquitectos.com
Mail: hola@zozayaarquitectos.com
Instagram: https://www.instagram.com/zozaya_arquitectos/
Office address: Centro Comercial Los Patios 111, Ixtapa, Guerrero, México. CP. 40884.
Year of completion: 2021
景观规划设计
返回版块25.18 万条内容 · 282 人订阅
韩国新地标:太空漫步 | 如过山车般的步行系统,你敢体验吗?「太空漫步」是韩国最大的体验艺术作品,由POSCO公司策划制作、安装并捐赠给浦项市民。这是一件在韩国很难看到的新概念步行体验艺术装置,是一件从观看者只能看不能碰转变为直接可以走进艺术、与艺术融为一体的雕塑 作品 ,也是代表浦项乃至整个韩国的地标性建筑。 项目由享誉世界的德国夫妻艺术家Heike Mutter和Ulrich Genth设计,从策划到完成历时两年零七个月,长57米、宽60米、高25米、轨道全长333米、使用约 317 吨钢材,造型流畅、曲折多变。
