MULTI-FRONTAL SOLVER
AVAILABLE MEMORY = 11.1 GBYTES
CONSTRUCTION STEP NO. : 1 / 14 STAGE NO : 1 STEP NO : 1
ENTRY PHASE FOR RENUMBERING
ENTRY NUMBERING_EQN
ENTRY FORM_STIFF_MASS_LOAD
THE INDIVIDUAL ELEMENT STIFFNESS AND LOAD MATRICES WILL NOW BE FORMED.
ELEMENT NO. : 150 OF 176
ENTRY SOLUTION PHASE
ENTRY LOAD_BLOCK
TOTAL NUMBER OF VALID DOFS IN MODEL : 906
ENTRY ASSM_STIFF_LOAD ( FORM GLOBAL EQUILIBRIUM EQUATIONS IN BLOCKS )
ENTRY STATIC ANALYSIS FOR NONLINEAR.
ITERATION NO. : 1 DISPLACEMENT ERROR NORM .. : 0.10000E+01 CONVERGENCE TOLERANCE .. : 0.10000E-01
WARNING : NODE NO. 76 RX DOF MAY BE SINGULAR.
WARNING : EQUATION NO. 454
ITERATION NO. : 2 DISPLACEMENT ERROR NORM .. : 0.00000E+00 CONVERGENCE TOLERANCE .. : 0.10000E-01
ITERATION NO. : 3 DISPLACEMENT ERROR NORM .. : 0.00000E+00 CONVERGENCE TOLERANCE .. : 0.10000E-01
CONSTRUCTION STAGE RESULTS SAVED TO FN.CA6 FILE
CONSTRUCTION STEP NO. : 2 / 14 STAGE NO : 1 STEP NO : 2
ENTRY NUMBERING_EQN
ENTRY LOAD_BLOCK
ITERATION NO. : 2 DISPLACEMENT ERROR NORM .. : 0.10000E+01 CONVERGENCE TOLERANCE .. : 0.10000E-01
WARNING : DISPLACEMENT DZ AT NODE NO. 17 IS ABNORMAL.
WARNING : DISPLACEMENT DZ AT NODE NO. 18 IS ABNORMAL.
WARNING : DISPLACEMENT DZ AT NODE NO. 19 IS ABNORMAL.
WARNING : DISPLACEMENT DZ AT NODE NO. 20 IS ABNORMAL.
WARNING : DISPLACEMENT DZ AT NODE NO. 21 IS ABNORMAL.
WARNING : DISPLACEMENT DZ AT NODE NO. 22 IS ABNORMAL.
WARNING : DISPLACEMENT DZ AT NODE NO. 23 IS ABNORMAL.
WARNING : DISPLACEMENT DZ AT NODE NO. 24 IS ABNORMAL.
WARNING : DISPLACEMENT DZ AT NODE NO. 25 IS ABNORMAL.
WARNING : DISPLACEMENT DZ AT NODE NO. 26 IS ABNORMAL.
WARNING : DISPLACEMENT DZ AT NODE NO. 27 IS ABNORMAL.
WARNING : DISPLACEMENT DZ AT NODE NO. 28 IS ABNORMAL.
WARNING : DISPLACEMENT DZ AT NODE NO. 29 IS ABNORMAL.
WARNING : DISPLACEMENT DZ AT NODE NO. 30 IS ABNORMAL.
WARNING : DISPLACEMENT DZ AT NODE NO. 31 IS ABNORMAL.
WARNING : DISPLACEMENT DZ AT NODE NO. 32 IS ABNORMAL.
WARNING : DISPLACEMENT DZ AT NODE NO. 33 IS ABNORMAL.
WARNING : DISPLACEMENT DZ AT NODE NO. 34 IS ABNORMAL.
WARNING : DISPLACEMENT DZ AT NODE NO. 35 IS ABNORMAL.
WARNING : DISPLACEMENT DZ AT NODE NO. 36 IS ABNORMAL.
WARNING : DISPLACEMENT DZ AT NODE NO. 37 IS ABNORMAL.
WARNING : DISPLACEMENT DZ AT NODE NO. 38 IS ABNORMAL.
WARNING : DISPLACEMENT DZ AT NODE NO. 39 IS ABNORMAL.
WARNING : DISPLACEMENT DZ AT NODE NO. 40 IS ABNORMAL.
WARNING : DISPLACEMENT DZ AT NODE NO. 41 IS ABNORMAL.
WARNING : DISPLACEMENT DZ AT NODE NO. 42 IS ABNORMAL.
WARNING : DISPLACEMENT DZ AT NODE NO. 43 IS ABNORMAL.
WARNING : DISPLACEMENT DZ AT NODE NO. 44 IS ABNORMAL.
WARNING : DISPLACEMENT DZ AT NODE NO. 45 IS ABNORMAL.
CONSTRUCTION STEP NO. : 3 / 14 STAGE NO : 1 STEP NO : 3
ENTRY NUMBERING_EQN
ENTRY LOAD_BLOCK
WARNING : NODE NO. 76 DX DOF MAY BE SINGULAR.
WARNING : EQUATION NO. 451
WARNING : NODE NO. 76 DZ DOF MAY BE SINGULAR.
WARNING : EQUATION NO. 453
WARNING : NODE NO. 76 RY DOF MAY BE SINGULAR.
WARNING : EQUATION NO. 455
ITERATION NO. : 2 DISPLACEMENT ERROR NORM .. : 0.10642E-02 CONVERGENCE TOLERANCE .. : 0.10000E-01
CONSTRUCTION STEP NO. : 4 / 14 STAGE NO : 2 STEP NO : 1
ENTRY NUMBERING_EQN
ENTRY LOAD_BLOCK
ITERATION NO. : 2 DISPLACEMENT ERROR NORM .. : 0.16586E+20 CONVERGENCE TOLERANCE .. : 0.10000E-01
ITERATION NO. : 3 DISPLACEMENT ERROR NORM .. : 0.30282E+21 CONVERGENCE TOLERANCE .. : 0.10000E-01
ITERATION NO. : 4 DISPLACEMENT ERROR NORM .. : 0.16631E+20 CONVERGENCE TOLERANCE .. : 0.10000E-01
ITERATION NO. : 5 DISPLACEMENT ERROR NORM .. : 0.30419E+21 CONVERGENCE TOLERANCE .. : 0.10000E-01
CONSTRUCTION STEP NO. : 5 / 14 STAGE NO : 2 STEP NO : 2
ENTRY NUMBERING_EQN
ENTRY LOAD_BLOCK
ERROR NORM IS NaN or INFINITE
THE PROGRAM IS ABORTED
ERRORS ENCOUNTERED. MIDAS JOB TERMINATED. REFER TO .OUT FILE
MIDAS
返回版块5.84 万条内容 · 317 人订阅
