土木在线论坛 \ 建筑设计 \ 建筑方案设计 \ 粤港澳大湾区高性能医疗器械创新中心
粤港澳大湾区高性能医疗器械创新中心
发布于:2024-04-09 11:48:09 来自:建筑设计/建筑方案设计 [复制转发]
一个致力于生物医学研究与技术研发的空间
来源|CA当代建筑
编辑|计成
粤港澳大湾区高性能医疗器械创新中心(以下简称“IHM创新中心”)位于广州市蓬勃发展的国际生物岛——一个致力于生物医学研究与技术研发的空间。IHM创新中心内设科研实验室、交流互动空间、办公协同空间,致力于高性能医疗器械创新研发。
Innovation Center for High-Performance Medical Devices Guangdong-Hong kong-Macao Greater Bay Area Industy in the (IHM·GBA) is located in the heart of Guangzhou's thriving international Bio Island, a dedicated zone for the development of biomedical research and technology. The building is used to develop high-performance medical devices, which requires a design that combines laboratories and spaces for research with areas for informal communication and open office spaces.
三个漂浮的体块_three floating volumes ?田方方 Tian Fangfang
设计将多种功能编织在一个“X”形平面中,从而最大限度地利用了地块:“X”的两个翼板分别用于布置实验室或办公空间,而交叉点则用作公共空间。实验室的柱网更加密集,而办公空间的柱网则更开阔。
The design weaves these programs together in an X-shaped floor plan which makes optimal use of the square plot: each bar of the "X" is devoted to either laboratory or workspaces, while the intersections function as communal spaces. The column grid is denser in lab areas, and more open in the wings dedicated to office spaces.
中庭_atrium ?田方方 Tian Fangfang
“X”形的平面布局将自然光引入建筑的核心地带,且让每个翼板空间都拥有多角度的优质景观。“X”形内侧凹角被设计为曲面形态,与建筑平直、方正的外轮廓形成强烈对比。曲面立面创建出动态的线条组合,为使用者带来更好的视觉体验。
The shape of the floor plan allows for light to reach into  the heart of the building, with lush vistas in multiple directions  from every wing. The corners on the inside of the X are  curved, in contrast to the sharp outer edges, adding to the  quality of the views and creating a dynamic composition of  lines along the facade.
设计策略_design strategy ?HENN
功能分布_program distribution ?HENN
IHM创新中心由三段漂浮的体块组成。其中:底部体块容纳了公共功能,如前厅、展厅、演示实验室和咖啡厅;中间体块则包含了实验室、会议室、多功能厅等;顶部体块是办公区域。体块中间由露台隔开,双层通高的露台空间既增加了体块间转换的趣味变化,又为空中花园的营建提供了场地。
The Innovation Center is composed of three floating volumes separated by multi-storey, open-air terraces that function as sky gardens. These double-height spaces  create a playful rhythm of shifting volumes. The lower volume hosts public functions, including a lobby, exhibition hall, a show lab and cafe; the middle volume above houses laboratories, meeting rooms, multipurpose rooms, and the top floor contains offices.
前厅_lobby ?田方方 Tian Fangfang
几何形体_geometry ?田方方 Tian Fangfang
IHM创新中心是高密度、垂直建筑的新型代表,它将研发场地与协作工作环境紧密结合。海茵建筑的设计作为创新的“脚手架”,为推动高端医疗器械领域创新研发提供了有力的建筑支撑。
The Innovation Center represents a new typology in highdensity vertical architecture, combining experimentation and research spaces with collaborative work environments. HENN's design functions as a scaffolding for innovation that boosts progress in the development of high-performance medical devices.
空中花园_sky garden ?田方方 Tian Fangfang
主入口_entrance ?田方方 Tian Fangfang
两种幕墙类型_two types of facade ?田方方 Tian Fangfang
平行世界_speaker's corner ?田方方 Tian Fangfang
一层往二层楼梯_staircase from ground floor to second floor ?田方方 Tian Fangfang
形体切割处的景观_scenary from bikini level ?田方方 Tian Fangfang
错落的花园_shifting gardens ?田方方 Tian Fangfang
其他图纸:
Other Drawings:
室内设计一层平面图 _interior design floor plan Level 1 ?HENN
室内设计二层平面图 _interior design floor plan level 2 ?HENN
  室内设计三层平面图_ interior design floor plan level 3 ?HENN
标准墙型图_standard wall type drawings  ?HENN
  • 加倍努力
    加倍努力 沙发
    学习了粤港澳大湾区高性能医疗器械创新中心设计理念,多谢了。
    2024-04-11 08:24:11
建筑方案设计
21.19 万条内容 · 304 人订阅
工业旧改 多层办公建筑设计:韩国 · 停机坪(码头) 工厂和办公
在以年轻时尚氛围著称的 Sungsoo 区,工业建筑的改造催生了一种独特的建筑风格,其特点是粗糙的混凝土饰面,以及用宽大的玻璃店面取代传统外墙。 与 Sungsoo 的大多数工业建筑一样,设计团队选择的工厂也是两层 L 型混凝土结构,外墙为砖砌。主厂房用途广泛,包括标签生产、仓储和办公空间,而位于南端的附属建筑则由混凝土块和金属梁建成,专门用于仓储、浴室和餐饮设施,面积1052㎡。
