土木在线论坛 \ 园林景观 \ 景观规划设计 \ 梦想的诗意住宅 | 巴西·RN House
发布于:2024-04-09 10:13:09 来自:园林景观/景观规划设计 [复制转发]
RN House 是由Rodrigo Oliveira Paisagismo设计景观,Jacobsen Arquitetura设计建筑的。它被构想为一对夫妇、他们的子女和孙辈在巴西米纳斯吉拉斯度过周末和假期的度假屋。
With landscaping designed by Rodrigo Oliveira Paisagismo and architectural project by Jacobsen Arquitetura, RN House was conceived as a vacation home for a couple, their children, and grandchildren to spend their weekends and holidays in Minas Gerais, Brazil
位于巴西米纳斯吉拉斯州伊托纳的这块土地坐落在一个大型水库旁,已经为这个家庭所享受,并且他们在水域边尽可能靠近的地方建造了一座房屋,遵循了周围大多数房屋的模式。以风景如画的景观和植被作为项目的前提,雅各布森建筑团队决定将房屋迁至一个新的更高位置,使其可以无障碍地俯瞰水库,而以前被树木挡住了。一棵原生树种,Vinhático品种,曾经位于现有建筑物的后方,现在被重新安置在地块中心,以便房屋可以围绕它建造。
The land located in Itaúna, Minas Gerais (Brazil) sits by a large reservoir and was already enjoyed by the family, who had a construction placed as close to the water's edge as possible, following the pattern of most houses around. Using the scenic landscape and vegetation as the premise for the project, the Jacobsen Architecture team decided to relocate the house to a new higher location, allowing an unobstructed view of the reservoir – previously blocked by trees. A native tree, Vinhático species, which previously stood behind the existing construction, was given a prominent place, being repositioned in the center of the plot, so that the house could be built around it.
虽然对新可能性持开放态度,但业主希望重复使用大部分现有植物,这些植物根据项目的需要进行了移植,并要求提供易于维护的解决方案。在保护了树木的情况下,创造了与周围环境融为一体的大型花坛和宽敞的低矮花园。根据负责该项目的Rodrigo Oliveira的说法,良好的景观设计应该被创造为“框住”已经存在于现场的自然环境。
While open to new possibilities, the owners wanted to reuse a large part of the existing plants, which were relocated according to the project's needs, and requested easy maintenance solutions. With the trees preserved, large flowerbeds were created to blend with the surroundings and a spacious, low garden. According to Rodrigo Oliveira, responsible for the project, good landscaping should be created to "frame the nature" already present at the site.
根据根部水平的定义,创建了一个平坦的景观区域,地面层呈现出不对称的轮廓,容纳了客厅、阳台,以及后面的卧室,确保房屋的所有区域都能够享有宽阔的户外景观,并且通过在Vinhático树冠上创建一个木甲板,与花园相连。在整个住所内,使用了花岗岩和freijó木材等材料作为装饰,让人联想到巴西农舍的风格。
The root level defined the creation of a flat, landscaped area, where the ground floor assumes asymmetrical contours and houses the living rooms, verandas, and, at the back, the bedrooms, ensuring all areas of the house have wide views of the outdoors, and, with the creation of a wooden deck over the canopy of the Vinhático tree, a connection with the garden. Materials such as granite and freijó wood were used as finishing throughout the residence, reminiscent of a Brazilian farmhouse.
景观规划设计
25.18 万条内容 · 282 人订阅
三亚华润置地海棠悦府 | 被切片的度假时光
对于华润海棠悦府最初的想象 源于对三亚自然美景的片段式回忆 一条蜿蜒的小径,一朵轻盈的云 一束柔和的光线,一片宁静的海面 一卷起伏的浪花,一脚柔软的沙滩 一盏指引的灯塔 .…… 对三亚的片段式回忆 FRAGMENTARY MEMORIES OF SANYA'S NATURAL BEAUTY
