土木在线论坛 \ 建筑结构 \ 混凝土结构 \ 公寓:红色混凝土外立面
公寓:红色混凝土外立面
发布于:2024-01-29 15:01:29 来自:建筑结构/混凝土结构 [复制转发]
Highnote 是阿尔梅勒的一座起步住宅楼,也是城市天际线上的最新建筑。在设计中,我们提出了一个独特的特点:一个三角形的基座完全由 "城市房间 "组成。它们是私密的城市室内和室外空间,相互交融,引人漫步其中。每个城市房间都有自己的奇妙之处,但总是留给你想象的空间。
Highnote is a residential tower for starters in Almere and the latest addition to the city skyline. For the design, we came up with a unique feature: a triangular plinth that consists entirely of 'urban rooms'. They are intimate, urban indoor and outdoor spaces, flowing into each other and enticing you to wander through them. Each urban room sparks its own sense of wonder, yet always leaves its use to your imagination.
沿着整个地块的边缘,一条连续的柱廊勾勒出城市房间的轮廓。它的外观既强烈又抽象,让人对它所环绕的空间产生自己的理解。城市房间共同构成了从喧嚣城市到塔楼私人住宅的渐进过渡。
Along the edges of the entire plot, one continuous colonnade contours the urban room sequence. Its appearance is strong yet abstract, inviting your own interpretation of the spaces it surrounds. Together, the urban rooms create the gradual transition from the buzzing city to the private homes in the tower.
分析图
阿尔梅勒市的年轻人和初入城市的居民数量迅速增加,但市中心的住房仍然有限。市政府的目标是让市中心变得更加可持续、绿色和密集。行人是优先考虑的对象:通过将现有的和未来的广场以及各具特色和功能的场所连接起来,一条新的绿色步行带正在市中心形成。
The city of Almere has a quickly rising number of young and starting city dwellers, yet there is still limited housing in the city center. The municipality aims to turn the center more sustainable, green and dense. Pedestrians are prioritized: by linking existing and future squares and places with their own characters and functions, a new green walking strip through the city center is emerging.
直到最近,在通往阿尔梅勒市中心的一条城市轴线上,仍有一片荒芜的石质残留地。市政府希望将这块地重新改造成一个新的城市旅游景点,为各类初学者提供高质量的住房,同时提供健康的生活空间和意想不到的功能,为公共场所增添新的活力。该地块紧凑的三角形为实现这一愿望带来了更多挑战。
Until only recently, there was a stony and barren residual site, lying fallow along one of the city axes to the heart of Almere. The municipality had the ambition to repurpose the site into one of these new urban destinations, merging quality housing for a wide range of starters with healthy living space and unexpected functions that generate new liveliness in public. The plot’s compact, triangular shape raised additional challenges for this desire.
其中的城市房间是聚会、工作、休闲和学习的新场所:它们是为激发灵感而设计的空间,让您可以根据自己的需要加以利用。因此,城市房间既富有特色,又尽可能具有多功能性,可以满足当前和未来的需求。
The urban rooms within are new places to meet up, work, relax, and study: they are spaces designed to inspire, fostering you to use them as you see fit. So, characterful yet as versatile as possible, the urban rooms are adaptable to current and future needs.
在我们的构想中,西侧的广场是透明和开放的,欢迎人们从市中心进入。这个广场,也就是我们所说的 Werf,最初将作为艺术装置和公共活动的场所,供居民和附近居民使用。与此同时,它还将作为一个室外工作空间,供邻近的创意制作空间在室内使用。沿着小巷是霍夫区--一个与之形成鲜明对比的隐蔽空间,带有座椅元素的新步行道蜿蜒穿过。
这个区域是一个绿意盎然的花园,为人们提供了一个宁静的空间,在一天中的某些时段,日光会洒满这里。在朝南的低层建筑顶部是 Dak,这是一个屋顶花园,为住户提供了 450 平方米的绿色空间,住户可以在这里举办生日派对、组织体育课,或者只是在喧嚣的城市中小憩片刻。塔楼底部是一个内部文化区,设有工作区,今年还将增设咖啡厅和餐厅。
We conceived the square on the west side to be transparent and open, welcoming the people entering from the city center. This square, or as we call it the Werf, is set to initially become the site for art installations and public events for residents and the neighborhood. In parallel, it will co-function as an outdoor workspace for adjacent creative maker spaces to be installed inside. Along the alley lies the Hof — a contrasting, sheltered space through which new walking paths with seating elements wind. This area brings a luscious green garden, providing a space of tranquility and flooding with daylight at certain times of the day. On top of the lower, south-facing volume lies the Dak, a rooftop garden offering the residents their own 450m2, green space to host a birthday party, organize a sports class or just take a break from the hustle and bustle of the city. At the base of the tower, is an internal cultural area with workspaces, to which a cafe? and restaurant will be added this year.
除此公共项目外,塔楼还容纳了 157 套住宅,其中 67 套 "朋友 "公寓是阿尔梅勒首次提供给两位合租者。Highnote 位于市政厅旁的显要位置,是通往城市中心的入口。
On top of this public program, the tower volume accommodates 157 homes of which, for the first time in Almere, 67 ‘friends’ apartments for two sharing tenants. On its prominent location next to the city hall, Highnote now marks the entrance to the heart of the city.
阶梯式的倾斜体量和标志性的颜色使 Highnote 在阿尔梅勒的城市景观中脱颖而出,从各个角度看,轮廓都在不断变化。我们选择了单色柔和的红色混凝土外立面,它在一天中似乎都在变换着颜色,使矩形网格更加柔和。每个体量都有自己的立面韵律,强化了建筑的堆叠结构。
The stepped, leaning volume and signature color make Highnote stand out in Almere's cityscape, with a changing silhouette from all angles. We opted for a monochromatic, soft red concrete facade that seems to shift in color throughout the day and soothes the rectilinear grid. Each volume has its own facade rhythm, reinforcing the stacked building configuration.
建筑外立面由坚固的混凝土柱构成,带有深而倾斜的凹槽,营造出光影交错的效果。在街道上,外立面流畅地与神秘的柱廊融为一体。我们在整个建筑中采用了承重的预制外立面构件,使建筑能够在很短的时间内建成,而且几乎不需要脚手架。Highnote 的结构使整个建筑无论现在还是将来都能保持灵活的配置。
The facade is built with robust concrete columns with deep, angled recesses that create a play of light and shadow. At street level, the facade flows smoothly into the mystical colonnade. We implemented load-bearing, prefabricated facade elements throughout, allowing the building to be constructed in a tight timeframe and virtually scaffold-free. Highnote's structure allows the entire building to remain flexible in its configuration, now and in the future.
项目图纸
区位图
平面图
平面图
分析图
140.17 万条内容 · 2232 人订阅
创鲁班奖工程总体要求.zip
创鲁班奖工程总体要求.zip创鲁班奖工程总体要求.zip
