The Spaarndammerhart restores the urban fabric of the Spaarndammer neighborhood. The street that disappeared in the 1970s for the construction of the local school, Spaarndammerschool, has been restored. The plan also brings back two street walls and adds a public courtyard to the neighborhood. Accessible through two large gates, it also connects to De Klerk's iconic ‘The Ship’ building. In fact, the neighborhood is characterized by several world-famous monuments of the Amsterdam School.
The project’s location is surrounded by not only De Klerk’s Het Schip and Spaarndammerplantsoen, but also Walenkamp’s Zaanhof and De Bazel’s Zaandammerplein. And while the architecture of Spaarndammerhart is unmistakably contemporary, it also has subtle references to these Amsterdam School classics. For instance, the building features rich and nuanced masonry in red and yellow brick, glazed bricks for the 'interior facades' of the courtyard, slender profile frames in an unambiguous facade structure, and ‘soft’ progressions along the building’s mass. In addition, visual art – in this case by Martijn Sandberg – is an integral part of the larger architecture and landscape design.
In the large block, houses and apartments have been designed in different categories and typologies: including social rental housing for starters, seniors and larger families, rental apartments for the private rental sector, and owner-occupied homes in a communal courtyard. The apartment entrances are located at two gates, which provide access to both the houses and the courtyard. The ramp to the underground parking garage is also located at the southern gate.
The balconies above the gates protrude so they clearly mark the entrances from the street. In the gates, the art of Martijn Sandberg depicts the 'connections in time' with the neighborhood. Two social spaces and a communal area for residents provide space for neighborhood functions and underline the concept of ‘collectivity’. A 'green cushion' has been laid out in the courtyard following a design by DS Landscape Architects. A collective garden is placed between the existing buildings and the new construction, which is also accessible to the surrounding houses.
The small block consists of ground-level living/working homes in four stories (owned sector). The characteristic of this block is the vertical articulation per house and the two narrow gates to the rear garden and the underground storage rooms. Here too, the gardens are collective in order to ensure the green character is retained for the long term. So-called 'encroachment zones' have been applied throughout the project. These are transition zones between the public street and the private home.
They consist of a deep recess paved with bluestone. It invites residents to appropriate these places. This fits in with an Amsterdam tradition of having houses oriented towards the street. The residential block comprises a total of 80 homes, including 26 social housing, 18 private sector rental, and 36 owner-occupied homes. In addition, there are two community areas, a common room, an underground parking garage for 56 passenger cars, and more than 100 facilities for insects, bats, and birds.
平面图
平面图
剖面图
免费2人已点赞
建筑方案设计
返回版块21.19 万条内容 · 304 人订阅
立体停车楼—— 8大精品案例停车难一直是城市发展的痛点,如何更好更优地解决? 立体停车已经成为未来发展趋势, 立体停车最大的优势就在于其能够充分利用城市空间,被称为城市空间的“节能者”。 停车相对集中,占地空间小; 出入方便高效快捷; 停车楼的设计使用年限较长,一般可达50年; 造价低,运行省,效益高;此外,停车楼立面可大面积开洞,方便采光通风,同样也节约了采光通风设备成本......
