土木在线论坛 \ 建筑设计 \ 建筑方案设计 \ 生物制药办公园区—— 被动式可持续性元素
发布于:2024-01-05 09:43:05 来自:建筑设计/建筑方案设计 [复制转发]
Biofarma 是一家生产和销售家禽、猪和牛等动物饲料的公司。该项目源于一次私人竞赛,竞赛要求为在一块 39 870 平方米的土地上建造一座包括行政办公楼和其他配套建筑在内的工业厂房设计总体规划。获得一等奖后,我们的任务是制定办公楼的执行项目。
在设计该建筑时,我们考虑到在总体规划中我们有一个自由的周边环境和战略位置。我们提出了两个矩形楼层,由面向外墙的办公区组成,中间由两个内部庭院连接,创造出协作空间。两端的两个垂直流通核心区使不同楼层的员工之间有了更多的互动。上层的项目不仅包括办公室,还包括会议室、打印区和咖啡休息区。公司经理办公室分布在一个双层高的空间内,与底层的分层入口相连接,加强了机构的识别感。与入口相连的是一个小型礼堂和培训室。
Biofarma is a company that produces and markets animal feed for the poultry, swine, and cattle industries, among other species. The project originated from a private competition, which called for designing a master plan for the construction of an industrial plant that includes an administrative office building and other complementary structures, on a plot of 39,870m2. After receiving the first prize, we were tasked with developing the executive project for the offices. To design the building, it was considered that we had a free perimeter and a strategic location within the master plan. Two rectangular-shaped floors were proposed, consisting of office bands towards the facades connected by two internal courtyards in the center, creating collaborative spaces. Two vertical circulation cores at the ends allow for greater interaction between employees on different levels. The program on the upper floor includes not only the offices but also meeting rooms, printing areas, and a coffee break space. The company managers' offices are distributed around a double-height space that connects with a hierarchized entrance on the ground floor, reinforcing the sense of institutional identity. Together with the mentioned entrance, a small auditorium and training rooms are located.
建筑采用独立的钢筋混凝土结构,配有轻质楼板和平梁。围护结构由多层简易结构组成,是一种被动式可持续性元素,可提高建筑的隔热性能。在外围的柱子和梁上设计了一个带有整体前铝制细木工板的封闭结构,双层密封玻璃固定在混凝土柱上。
标准型材的支架被固定在上面,由金属管组成的下部结构被支撑在支架上,上面还铺设了一层预先涂漆的灰色镀锌膨胀金属板,与铝制细木工板相隔 70 厘米,从而起到防晒作用。它与地面隔开,给人一种轻盈的感觉,玻璃上投下的阴影又强化了这种感觉。这种表皮在项目中发挥了重要作用,因为它在玻璃封闭和外部之间形成了一个中间遮阳空间,减少了阳光的直接辐射,从而降低了建筑能耗。
为了避免成为外部和内部之间的视觉障碍,建议采用可根据时间打开的活动面板。作为补充,室内安装了垂直百叶窗,用户可以根据自己的需要调节所需的亮度。这也赋予了建筑公司的语言和机构特征。
An independent reinforced concrete structure was proposed, with lightweight slabs and flat beams. The envelope consists of several layers of simple construction, conceived as an element of passive sustainability that improves the building's thermal insulation. A closure with integral front aluminum joinery, with double hermetic glazing fixed to the concrete columns, was designed over the perimeter columns and beams. Brackets of standard profiles were anchored, on which a substructure of metal tubes was supported, and a pre-painted gray galvanized expanded metal sheet skin was placed on top, separated 70 cm from the aluminum joinery, thus creating a sun protection. Being separated from the ground gives a sense of lightness, reinforced by the shadows it casts on the glass. This skin plays a significant role in the project, as it forms an intermediate shaded space between the glass closure and the exterior, reducing direct sunlight radiation and, consequently, the building's energy consumption. To avoid being a visual obstacle between the exterior and interior, movable panels were proposed that can be opened depending on the time of day. As a complement, vertical blinds were installed inside, allowing users to regulate the required level of brightness according to their needs. It also gives the building the language and institutional character of the company.
在主立面,出现了不同的元素,如一个与其大小相称的标志,由于它打断了建筑的大型金属包层而引人注目,在它之前是不透明的夹层玻璃,作为标志的背景和服务区的围墙。此外,一个金属喷嘴的大窗户突出了用途的改变,这里是员工就餐区和带有休闲空间的露台,是办公室的延伸。
On the main facade, different elements appear, such as a sign proportioned to its size, noticeable because it interrupts the large metal cladding of the building, preceded by opaque laminated glass that serves as a background for the sign and enclosure of service areas. In addition, a large window accompanied by a metal nozzle highlights the change of use, where a dining area for staff and a terrace with recreational space as an extension of the offices are located.
建筑采用钢筋混凝土独立结构,楼板和横梁均为斜面。围护结构由几层简单的结构组成,是作为被动式可持续性元素设计的,可提高建筑的隔热性能。在周边的柱子和横梁上,设计了一个带有整体前木结构的围护结构,该围护结构由铝制成,带有固定在混凝土柱上的密封双层玻璃。
Se propuso una estructura independiente de hormigón armado, con losas alivianadas y vigas chatas. La envolvente está formada por varias capas de simple construcción, pensada como un elemento de sustentabilidad pasiva que mejora el aislamiento térmico del edificio. Sobre las columnas y vigas perimetrales, se dise?ó un cierre con carpintería de frente integral, de aluminio con doble vidriado hermético fijado a las columnas de hormigón.
普通的型材支架被固定在上面,由金属管组成的下层结构被支撑在上面,并在上面铺设了一层灰色的预涂镀锌未折叠金属板,与铝制细木工板相隔 70 厘米,从而起到防晒作用。由于与地面隔开,它产生了一种轻盈的感觉,而玻璃上的阴影又强化了这种感觉。
Se anclaron ménsulas de perfiles normales, sobre los cuales se apoyó una subestructura de tubos metálicos y sobre esta, se colocó una piel de chapa desplegada galvanizada prepintada color gris, separada 70 cm de la carpintería de aluminio, generando así una protección solar. Al estar separada del suelo, genera una sensación de liviandad, que se refuerza con las sombras que arroja sobre los vidrios.
这种表皮在项目中发挥了重要作用,因为它在玻璃围墙和外部之间形成了一个中间遮阳空间,从而减少了太阳直接辐射,进而降低了建筑能耗。为了确保它不会成为外部和内部之间的视觉障碍,我们提出了可根据时间打开的活动面板。
Esta piel juega un rol importante en el proyecto, ya que conforma un espacio intermedio de sombra entre el cierre del vidrio y el exterior, reduciendo así la radiación directa del sol y, por ende, el consumo energético del edificio. Para que la misma no sea un obstáculo visual entre el exterior y el interior, se propusieron pa?os móviles que pueden abrirse dependiendo la hora del día.
作为补充,大楼内还安装了垂直条形窗帘,用户可以根据自己的需要调节所需的亮度。同时,它还赋予了公司的机构语言和特征。
Como complemento de la misma, se colocaron en el interior cortinas de bandas verticales que permiten que los usuarios regulen, de acuerdo a su necesidad, el nivel de luminosidad requerido. A su vez, le otorga el lenguaje y carácter institucional de la empresa.
在主立面,出现了不同的姿态,例如一个与其大小相称的标志,它之所以引人注目,是因为它打断了工程的大型金属包层,前面是不透明的夹层玻璃,作为标志的背景和服务场所的围墙。此外,还有一个金属喷嘴的大窗户,突出了用途的改变,这里是员工食堂和带休闲区的露台,是办公室的延伸。
En fachada principal, aparecen distintos gestos como un cartel proporcionado a su tama?o, notorio porque interrumpe el gran revestimiento metálico de la obra, precedido por vidrios laminados opacos, que hacen las veces de fondo del letrero y cerramiento de los locales de servicio. Además, una gran ventana acompa?ada de una tobera metálica, que destaca el cambio de uso, donde se ubica un comedor para el personal y una terraza con espacio de esparcimiento como extensión de las oficinas.
项目图纸
平面图
  平面图
立面图
剖面图
剖面图
剖面图
轴测分析图
分析图
项目信息
建筑师:Santiago Viale Lescano Juan Manuel Juárez
地点:阿根廷
建筑方案设计
21.19 万条内容 · 304 人订阅
虎牙佛山总部项目设计:创新性的科创园区,绿色科技、塑造城市地标
佛山虎牙总部综合发展项目位于佛山市三山新城,三龙湾创新聚集区域重要标志性节点之一。 项目占地 29,258.41 平方米,总建筑面积为 180,084.10 平方米,包括两栋办公塔楼、一栋公寓塔楼、低层办公楼和商业裙房。北侧和西侧的工业用地将更新为高新产业园区和居民小区。根据规划部门和当地管理部门的意见,项目设计需结合佛山本土元素和现代科技感,协调周边建筑风格,创造出独特设计方案。
