土木在线论坛 \ 建筑设计 \ 建筑构造 \ 竹子结构餐厅:轻盈的“弧形船形”茅草屋顶
发布于:2023-12-15 11:08:15 来自:建筑设计/建筑构造 [复制转发]
该餐厅位于龙成(Long Thanh)镇中心,该镇因越南南部最重要的国际机场项目正在建设中而迅速发展。餐厅建筑群由会议厅、私人餐厅、厨房、厕所和竹厅组成。竹制大厅以其轻盈的弧形船形茅草屋顶而引人注目,屋顶由类似楠木的竹子结构支撑,楠木是越南南部流行的一种河边植物。
Located in the center of Long Thanh, an animated town that is rapidly growing because there is a most important international airport project in southern Vietnam that is under construction. The restaurant complex consists of conference halls, private dining rooms, a kitchen, a toilet, and a bamboo hall. The bamboo hall stands out with its lightly curved boat-shaped thatched roof, supported by bamboo structures resembling nipa palms, a popular riverside plant in south Vietnam.
竹厅的底层设计非常简单,最多可容纳 180 位客人,位于交通便利的位置,与附属建筑的连接也很方便。餐厅的业主要求建筑师设计出令人印象深刻的建筑,使其成为建筑群的标志,并鼓励使用环保材料,而且施工速度要快。
The ground floor plan of the bamboo hall is very simple; it can accommodate up to 180 guests, it is located in a convenient position of access, and easily connects to the annex house. The restaurant’s owner required the architects to design an impressive architecture that would become the hallmark of the complex, environmentally friendly materials are encouragingly used, and the construction should be fast.
为了满足这些要求,竹子被用于建筑的结构和装饰。实竹 "在越南南部非常流行。它也被称为 "铁竹",这个名字说明它是非常坚硬的竹子,足以用于建筑施工。在传统建筑方法中,竹竿被用作柱、梁或桁架,跨度柱阶有一定限制。
在对各种结构表面进行研究后,我们采用了双曲抛物面(hypars),因为它具有极高的刚度和极强的吸引力。双曲抛物面因其弯曲的形状和在各个方向上的良好阻力,可以承受巨大的荷载,因此常用作屋顶结构。
In response to these requirements, bamboo is used for both structural element and decorative elements of the building. The “solid bamboo” species is very popular in southern Vietnam. It is also called “iron bamboo”, the name proves that it is very stiff bamboo, strong enough for building construction. In traditional construction methods, a bamboo pole is used as a post, beam, or truss with some limit of span column steps. After researching various structural surfaces, a hyperbolic paraboloid (hypars) surface is used because it is exceptionally stiff and extremely attractive. Hypars surfaces can carry great loads thanks to their curved shape and good resistance in all directions, so they are commonly used as roof structures.
竹厅由许多用作天花板和柱子的竹节组成。所有这些柱子相互连接,环环相扣,使悬挑的屋顶在檐口处高达 4 米。檐柱是一种双曲面和双规则面,可以很容易地用直结构件建造。
用竹竿建造hypar 结构是一个完美的组合。用笔直的竹竿建造弧形曲面,使施工变得简单而迅速。它们可以在不弯曲竹子的情况下实现非凡的刚度和迷人的外形。
The bamboo hall is composed of many hypars used as ceilings and columns. All of them are connected and interlocked with each other, allowing the overhanging roof to reach up to 4 meters at the gable roof. A hypar is a doubly-curved surface and doubly-ruled surface that can be easily constructed of straight structural members. Using the bamboo pole to build hypas structure is the perfect combination. The fact that curved surfaces are constructed of straight bamboo poles makes the construction easy and rapid. They can achieve exceptional stiffness and appealing form without bamboo bending.
然而,由于下垫面的双曲面,天然茅草的一条轴线呈 "凸 "形,而另一条轴线呈 "凹 "形,因此很难用于建造屋顶。为了解决这个问题,在凹面上增加了桁架和檩条,从而形成简单的斜屋顶。
这种组合形成了双层结构屋顶,增加了天花板的吸引力。竹制结构以一种戏剧性的方式上演。这个项目证明了竹子和 hypars 结构的巨大潜力。未来,这两种材料可能会成为可持续建筑的有效表现形式。
However, the double curvature of the hypars makes it difficult for roofing with natural thatch because it has a convex form along one axis, and a concave form along the other. To solve this problem, the truss and the purlin are added to the concave side to make simple sloped roofs. This combination creates a two-layer structural roof, increasing the appeal of the ceiling. The bamboo structure is staged in a dramatic way. This project proves the huge potential of bamboo and hypars structure. These two may be the efficient performance of sustainable construction in the future.
项目图纸
平面图
平面图
立面图
立面图
剖面图
  • 一竖三横
    一竖三横 沙发
    别强审.........防火绝对过不去。
    呵呵呵~~~~~~~
    2023-12-27 01:25:27
建筑构造
7.65 万条内容 · 196 人订阅
竹建筑:天然纤维结构
Mirador 是位于墨西哥图卢姆的一个房地产开发项目,图卢姆是墨西哥最重要的旅游胜地之一,以其丰富的自然和文化而闻名。使用竹子和硬木等材料建造的豪华设施展示了其在建筑方面的多重优势。 The Mirador is a real estate development located in Tulum, Mexico, one of the most important tourist destinations in the country, known for its natural and cultural richness. Luxury amenities using materials such as bamboo and hardwoods demonstrate their multiple benefits in construction.
