土木在线论坛 \ 建筑设计 \ 居住建筑设计 \ 国外住宅:极简现代的公建化立面
国外住宅:极简现代的公建化立面
发布于:2023-11-21 11:29:21 来自:建筑设计/居住建筑设计 [复制转发]
该项目由塔楼和酒吧两座主要建筑组成,位于一个曾经是重要啤酒生产基地的公园内。
The project consists of two main buildings – the tower and the bar- and is located in a park that was a former important beer production site.
塔楼共 20 层,总高度 70 米,公寓面积 9000 平方米;这座地标建筑由并列和偏移的棱柱组成,不仅突出了体量,还提供了充足、多样和开阔的景观。
The tower develops over 20 levels for a total height of 70 meters and 9000 m2 of apartments; this landmark is composed of juxtaposed and offset prisms, that not only allow for an accentuation of the volume’s mass but also offer ample, diversified, and open views towards the context.
外墙几乎完全透明,南侧外墙完全由木廊组成,使每套公寓都能直接通往室外空间。
The facades are almost completely transparent and the southern facade is exclusively made up of loggias, allowing each apartment to have direct access to an outdoor space.
通过面板和铝型材的韵律,进一步加强了体量构成所产生的垂直感。
另一方面,酒吧的长度超过 140 米,高度为 6 层,住宅和商业项目的总面积为 19000 平方米。酒吧是一个与花园直接对话的水平物体,其特点是根据楼层的不同而形成不同的体积。
The verticality generated by the composition of the volume is furthermore enhanced by the rhythm of the panels and that of the aluminum profiles. The bar, on the other hand, develops over 140 meters in length, 6 levels in height, for a total of 19000 m2 of housing and commercial programs. Conceived as a horizontal object, in direct dialogue with the garden, the bar is characterized by a fractional volumetry according to the floors.
一楼是公寓大堂、活动空间以及朝南和朝向公园的露台。
On the ground floor, the lobby of the apartments is situated, together with spaces for activities and terraces oriented towards the south and the park.
项目图纸
平面图
平面图
平面图
平面图
剖面图
剖面图
剖面图
示意图
示意图
模型图
模型图
模型图
模型图
模型图
模型图
项目信息
建筑师:XDGA - Xaveer De Geyter Architects
地点:比利时
面积:28000 m2
年份:2022
摄影:Maxime Delvaux
全部回复(3 )
  • 加倍努力
    加倍努力 沙发
    学习了国外住宅:极简现代的公建化立面设计理念,多谢了。
    2023-12-03 08:40:03
  • 真仙
    真仙 板凳
    也不错的设计!感谢分享!
    2023-11-22 10:47:22
居住建筑设计
28.74 万条内容 · 423 人订阅
乡村的多样性与现代性 - 乡村住宅
    ?  Shinkenchiku-sya   建筑师通过在城市之外一望无际的广阔空间中找到每一个建筑的特殊性,进而寻求多样性的现代价值观。
