土木在线论坛 \ 园林景观 \ 园林景观实景 \ 对处于自然山水之中的现代空间的思考、探索和回答,阆中·赛城游客中心
发布于:2023-10-09 15:53:09 来自:园林景观/园林景观实景 [复制转发]
项目位于阆中市河溪镇,是星盟赛城的游客中心和形象入口。阆中作为历史文化名城,山围四面、水绕三方。星盟赛城项目规划为大型体育文旅项目,游客中心作为大量人群到达和离开的中转站,要求具备强烈的标志性和引导性。
The project is located in Hexi Town, Langzhong City, serving as the visitor center and the scenic entrance for the Starsallianz Sports Town. Langzhong is a historic and culturally renowned city surrounded by mountains and water, which makes the natural environment here unparalleled. The sports town plan is a large-scale sports and cultural tourism project. The visitor center will serve as a transit hub for a large number of visitors arriving and departing, and needs to be strongly iconic and guiding.
▼主入口形象,Entrance
▼项目与不远处的嘉陵江,Project and the Jialing River nearby
01 自然山水的吸纳、融合及反差
Absorption, Integration and contrast of Natural Landscape
项目位于嘉陵江与巍巍大山之间,其中山环水抱的建筑应呈现出怎样的姿态,成为了设计的焦点。建筑呈四角星形布局,联通入口广场和景区内外,形成“门”的空间定义,并作为景框截取远处的连绵山水画;两侧作为游客中心的功能空间:一侧为售票大厅,一侧为展示和休憩大厅。
当游客由入口穿过外高内低的通廊空间,如同穿越峡谷,视线飞扬落入一汪湖水豁然开朗。建筑两翼向天空延伸飞展,与群山高低起伏的天际线轮廓构成一种微妙的对话关系。自然与人工,以一种现代但有机的形象融合为一体。
The site is located between the Jialing River and majestic mountains. So, the architectural posture in the landscape became our focus. The visitor center adopts a star-shaped form with four corners. connecting the inside and outside to define the "gateway" space. The corners also serve as frames to capture the continuous mountain and water to the visitors. The two lateral corners function as ticketing, exhibition and relaxation respectively.
As visitors pass through the outer high and inner low corridor space, akin to traversing a gorge with their view flying to a lake. The wings extend towards the sky, forming a subtle dialogue with the undulating skyline of the surrounding mountains. Thus, nature and artificial elements merge into a modern yet organic image.
▼区位图,Location map
▼场地的GIS分析图,GIS analysis of the site
▼建筑与周边环境的关系,Relationship between the building and the surroundings
▼建筑与内部的景观湖,The building and the lake inside
▼走出建筑的各条通路,Paths from the building
▼建筑周边的山与水,The landscape around the building
▼基地航拍图,Aerial view
02 面对开阔场地的多向丰富性
Embracing Site Variability
游客中心提取”运动“的语言,形成充满动感的多向丰富形体,呼应了周边场地开阔的特征——能使人在不同角度和距离都能明显感受到一个新建筑的介入,由此自然引导、收敛、汇聚到入口的巨大灰空间下,暗合了标识性和引导性的意图。
The visitor center extracts the concept of "movement" to form a dynamic form with diverse transformations in appearance. This multi-directional richness aligns with the open characteristics of the surrounding site,which allows people to feel the intervention of a new building from different angles and distances, and makes them to be naturally guided, and gathered into the huge gray space at the entrance, implying the intention of signage and guidance.
▼体育主题的物化,The materialization of sports themes
考虑到阆中时常烟雨连绵,入口通廊回应在地气候成为游客集结停留的场所——既是景区的一道门,也是联系两翼功能之间的半室外缓冲空间。两翼的室内空间由干净通透的曲面落地玻璃围合,纳入周边自然景   观,与金色两翼塑造出一个兼具科技感和自然美感的“插入式   ”空间。
Considering Langzhong's frequent rainy weather, as a response to the local climatic conditions, the entrance corridor of the visitor center also serves as a place for visitors to gather and linger. It serves as a gateway, as well as a semi-outdoor buffer space connecting the wings. The indoor space under wings is completely enclosed by transparent curved floor glass, incorporating natural landscape view around and collectively shaping a "plug-in" space that blends technology and natural beauty with the golden wings.
▼建筑主入口,Entrance
▼与周边绿树的融合及反差,Integration and contrast with trees nearby
▼作为景框的入口,Entrance as the scenic frame
▼动感的侧面形态,Dynamic lateral posture
▼掩映在夜色中,Set off in the night view
03 基于造型一体化的结构与材料考量
Integrated Approach to Structure and Materials
基于造型结构一体化设计理念,由自身大跨空间形态构成支撑钢结构,展现出形体的轻盈感。同时,呼应建筑简洁有力的形态和项目的运动主题,设计摒弃了常见的乡土材料,主要采用条形镀锌钢板、金属瓦及高透玻璃幕墙等现代轻质材料,与自然山水形成一种反差感,力求轻盈的介入环境之中。
Based on the integrated concept of form and structure, we employ a steel structure-the large-span spatial form constitutes the supporting structure to sculpt the sense of lightness. Meanwhile, to reply to the clean and powerful form, and the themes of sports and esports, we primarily use modern lightweight materials such as strip aluminum panels, metal composite tiles, and glass curtain walls instead of common rural materials, creating a contrast with the natural landscape to achieve a light integration into the surrounding.
▼3D打印结构模型,3D printing structure model
▼富有变奏感的通廊空间,Corridor space with a rich sense of variation
▼金属质感的通廊,The metallic corridor
▼游客中心大厅,Reception hall
▼大厅内部的斜切屋顶,The sloping roof inside the hall
▼室内的空间变化,Spatial changes indoor
▼镀锌钢板的转折面,Twisty surface of galvanized steel plate
▼镀锌钢板接地细节,Grounding details of galvanized steel plate
▼屋面金属瓦,Metal tiles on the roof
▼屋面金属瓦局部细节,Details of Metal tiles on the roof
▼施工中结构与饰面的关系,Relationship between the structure and facing
▼施工中的钢结构骨架,Steel structure under construction
入口空间是街道的延续,它不仅是薄薄的门板,也是具有厚度的公共空间。阆中赛城游客中心,是对处于自然山水之中的现代空间的思考、探索和回答。
Entrance spaces are extensions of streets, offering more than mere doorways; they possess substantial public character. The Langzhong sports town visitor center is our exploration and response to the possibilities of designing entrance spaces within a natural mountain and water landscape.
▼平面图,Ground floor plan
▼立面图1,Elevation1
▼立面图2,Elevation2
▼剖面图,Section
▼飞檐构造图,Detail  of the overhanging eaves
项目信息
项目名称:阆中赛城游客中心
项目完成年份:2023
建筑面积:1000㎡
建筑设计/室内设计/景观设计/公司/机构/单位:联创设计 有关工作室
事务所/公司/机构/单位简称:UDG About Sudio
事务所/公司/机构/单位网站:aboutstudio.udg.com.cn
项目地址:四川省阆中市河溪镇河溪街道
项目参与者
委托方:星盟体育
设计单位:UDG·有关工作室
主创设计师:陈伟鹏
设计团队:许一嘉、刘佳、杨帆、李一鸣
施工图团队:李晓斌、兰洋、刘川、沈云、李晓秋、刘渝
施工图设计:联创设计 重庆分公司
景观设计:重庆九禾园林
室内设计:汉嘉设计集团
幕墙设计:四川宏图都市
  • 阿巅2019
    阿巅2019 沙发
    感谢楼主分享,学习了
    2023-10-11 15:38:11
园林景观实景
37.75 万条内容 · 296 人订阅
杭州的苏式园林高家花园
在整个江南园林考察的旅途中,专门去了很多小众园林,接下来我们也把它们都盘点一下。 在杭州京杭大运河畔坐落着一处小巧且精致的苏式花园——高家花园。 高家花园是清末民初民族工业家高懿承的私人花园,位于运河天地文化艺术园区内。高家花园占地1200平方米,是杭州拱墅区唯一得以保存完好的清代建筑和私家花园。 高家花园的建造者高懿丞是安徽合肥人,晚清军机大臣李鸿章的远亲,也是近代中国民族工业的创始人之一。他曾供职于上海机器织布局,并创建了上海华盛、裕源纺纱厂。1903年,他凭借李鸿章之子李经方的投资接手了杭州通益公纱厂,1914年又通过自己组建的鼎新纺织股份公司,把通益公纱厂新公司租赁下来,并改名为鼎新纱厂。
