In addition to large-scale production halls, a new office building with approximately 4,000 m2 of functional space is being constructed. The openly flexible floor plan is surrounded by a glass facade that tapers from top to bottom. Projecting and recessed glass elements combine with folded metal elements to form a diamond-like structure, which is crowned by a laminated roof.
The goal was to use the company-designed glass panels Aepli Air control, which facilitates a double-skin facade technique. The space between the pre-glazing and the outer glass panel serves as a climate compensation buffer. It acts as a heat insulator during low temperatures and as a cooling insulator during high temperatures. The largest of the 154 facade elements boasts impressive dimensions of 6400x2950mm, weighing 2300kg.
The office spaces are predominantly designed as open spaces, with some individual offices also provided to accommodate the working style of Aepli Metallbau AG. In addition to a cafeteria, meeting rooms, seminar, and focus rooms, various outdoor areas also find their place, such as a large rooftop terrace for all employees. The sky lounge on the top floor also features a retreat space with its own garden.
Access to the different floors is provided by two interlocked staircases, with only one reaching all floors, while the second serves as an emergency staircase from the cafeteria level to the ground floor. The company has evolved into one of the leading and most modern facade construction companies in Europe.
平面图
平面图
平面图
平面图
平面图
平面图
平面图
项目信息
建筑师:StudioBoA, Waldburger Partner
地点:瑞士
面积:4000 m2
年份:2023
免费1人已点赞
公共建筑设计
返回版块51.18 万条内容 · 448 人订阅
Semmelweis大学健康科学学院新教学楼? Balázs Danyi 设计的核心理念旨在将新建体量和现有建筑融合为一个连贯的综合体。基本的设计原则基于与现有建筑的对话,并从这种对话中发展而来。
只看楼主 我来说两句 抢板凳Waldburger Partner 和 StudioBoA 将金属公司的产品巧妙地融入其中。瑞士建筑事务所 Waldburger Partner 和 StudioBoA 为著名的瑞士金属公司 Aepli Invest AG 设计了位于瑞士 Gossau 的新总部。
