土木在线论坛 \ 园林景观 \ 景观规划设计 \ 沿轴线旋转,葡萄牙·Quinta do Rei住宅
发布于:2023-09-04 13:40:04 来自:园林景观/景观规划设计 [复制转发]
这座别墅位于莱里亚市一个高地区,地势陡峭。
The villa is located in an elevated area with a strong slope in the city of Leiria.
分区条件确定了这个塔楼的体量,可以俯瞰整个城市。我们的一个前提是将社交区域设置在上层,并在屋顶上设置游泳池,以享受360度的视野。
The conditions of the subdivision suggested a volumetry of a tower, a viewpoint over the city. One of our premises was that the social areas were located on the upper floors and the swimming pool on the roof, to enjoy the 360o view.
这座房屋是对一块普通的鹅卵石进行转动轴变换的结果,产生了一个新的、更具可塑性的形状,优化了阳光照射,并允许从地面到屋顶的阳台、遮阳和通道区域,犹如一座从大地通向天堂的阶梯。
The house is the transformation of a regular cobblestone with the rotation on an axis that generates a new, more plastic shape, which optimizes the sun exposure and allows areas of balconies, shading, and circulations, from the ground to the roof, being a ladder from earth to heaven.
建筑的结构和混凝土外表皮形成一个整体,呈现出18个水平环形的节奏,每个部分相当于2个台阶的高度,这种设计在充实与空虚之间形成了房屋的交错布局,创造出一种既能够阻隔阳光又能够提供私密性的保护性过滤,供居住其中的人使用。
The structure and the concrete outer skin are felt as a single body, rhythmic with 18 horizontal rings, a section corresponding to the height of 2 steps, which design the house in a game of full and empty, creating a protective filter, both solar and private. , for those who inhabit it.
在房屋的内部,由半层楼组成,将一些空间相互连接,同时使其他空间独立且自主。
Inside, the house consists of half floors that connect some of the spaces with each other, while making others separate and autonomous.
▽平面图,Plan.
▽立面图,Elevation.
Project name: Quinta do Rei
Studio name: CONTAMINAR Arquitetos
área: 1006 m2
Built area: 397 m2
Project start year: 2012
Year of completion of the work: 2022
Author(s) of the architectural project and names of team members: Joel Esperan?a, Ruben Vaz, Eurico Sousa and Joaquim Duarte
Collaborators: Filipa Pimp?o, Ana Carolina, Sara Fernandes
interior design CONTAMINAR arquitetos
Names of complementary designers and consultants
Builder: J.A.F. Gameiro Ltda
Photographer: Fernando Guerra | FG+SG
Visualization
Tools used: software used for drawing, modeling, rendering, post-production and photography zwCAD
Video: Building Pictures
Landscaping: Crivila Paisagismo Ltda
Civil Engineer: Dimeng Ltd.
Structural Engineer: Dimeng Ltd.
Environmental Engineering and MEP: Socilux Ilumina??o Ltda
Customer: Stemcells Ltd
Status: Build
Typology T4
List of suppliers:
Frames: Metaloavis, Lda
Carpentry: Eficema Carpintaria Ltda.
Ceramic coatings: Jofeper, Lda
 Toilets: Jofeper Ltda
Air Conditioning and Plumbing: Leiricanal, Lda
Electricity: Leirivolt, Ltd.
景观规划设计
25.18 万条内容 · 282 人订阅
张永和新作:广州春阳台 - 塱头艺文中心
塱头古村坐落在广州市北郊,建村至今已有六百余年。作为远近闻名的“书香科甲村”,塱头存有大量保存完好的书院、祠堂、民居、古巷等建筑空间。 ▲从入口侧俯瞰春阳台 ?田方方 ▲比邻古村的艺文中心 ?田方方 “塱”字的本意是江旁边的洼地,也引申为湖泽、池塘。古村被众多的水塘所环绕:荷塘、鱼塘、风水塘,微风拂过荷叶荡漾,俨然一派岭南水乡景象。我们设计的塱头文化中心——“春阳台”正是立于村头的一片荷塘之中。
