土木在线论坛 \ 园林景观 \ 景观规划设计 \ 独一无二的粉色几何体块,墨西哥·TULIX住宅
发布于:2023-08-25 14:52:25 来自:园林景观/景观规划设计 [复制转发]
在建筑内部,所有建筑体量形成了一个循环的椎体结构,两端均设置有一个大厅,用于接待访客和保证空间的安全。这个交通轴线还通过后院和露台连接了所有住宅,从而促进了共同生活、社区感和社会归属感。
Inside, a circulation vertebra develops throughout the entire complex, which ends at each end with a lobby for reception of visits and security. This axis of circulation likewise connects all the houses through their backyards and terraces, thus promoting coexistence, a feeling of community and social belonging.
本项目为当局提供了一个能够吸收辐射的卫生网络,用于项目的本次和未来开发。值得一提的是,除了建筑内外部的呈现的效果与传统建筑截然不同之外,建筑群中所有的土壤都是透水性和亲植物的,例如公共区域和停车场区域。
A sanitary network with absorption pits was provided to the municipality for this and future developments on the site. Finally, it is pertinent to mention that outside of the internal rebellion of houses, all the soil in the complex is made up of permeable and vegetal soil, such as common areas and parking lots.
TULIX是一个独一无二的项目,这是一套独特的住宅,其内部空间经过了精心的考虑和设计,为寻求宁静、空间、舒适和豪华的业主打造。本项目位于图卢姆一片专门开发社区住宅的区域。
TULIX is a one of a kind project; a set of exclusive residences, with spaces carefully thought out and designed, especially for you, who are looking for tranquility, space, comfort and luxury. TULIX “Barrio Maya” is located in Tulum, the residential development proposal that generates community.
项目的平面布局与用地的两边平行,人们能够在建筑群内自由移动,该布局还能够促进对建筑内外植被的保护,这些植被占具了透水土壤的55.70%,其中包括透水土壤和植物体。
The layout of the project is aligned parallel to the ends of the land, allowing free movement within the complex and promoting the conservation of vegetated areas inside and outside the property, representing 55.70% of permeable soil and plant body.
建筑体量之间的相互作用促使阴影投射到相邻的建筑物和房产内部,从而在植被岛屿中创造微气候。另一方面,每个建筑单体都是由大型的体块组成,这样的设计减少了房屋内部的热效应,同时又不影响所有空间的交叉通风,房间内部的窗户、拱顶和日光浴室也同样帮助解决了这一问题。
The game of volumes facilitates the projection of shadows onto neighboring bodies and into the interior of the property, creating microclimates from islands of vegetation. On the other hand, each volume is made up of a large number of solids that reduce the calorific energy gain inside the houses, without compromising the cross ventilation of all the spaces, this in turn is solved by means of internal windows, domes and solariums.
所有的住宅模块都配有一个小花园或家庭花园,来鼓励人们种植植物和培育农作物以实现自我生产。
All the housing modules have a small garden or home garden to encourage the care and proliferation of plant species, as well as the self-production of food.
这一系列的体块的组合形成了有着不同表面的城市雕塑,随着这些表面的节奏韵律发生变化,创造出了一系列被特有植物包围着的不同框架结构。设计者使用淡粉色的作为外墙饰面来保持项目自身的特色。从另一个角度来说,这种饰面手段可以减小对整体视觉效果的维护和修复成本。
The succession of volumes generates an urban sculpture of different blind planes that change in rhythm and create a series of different frames surrounded by endemic vegetation. A reddish paste exterior finish was used to maintain the project’s own identity. On the other hand, the use of this technique allows to eliminate the costs and maintenance and modifications that alter the visual of the whole.
▽首层平面图,grond floor plan .
▽二层平面图,first floor plan .
▽顶层平面图,second floor plan .
▽立面图,elevation .
▽剖面图,section.
▽剖面图,section.
▽总平面图,site plan.
Architect: COYOTE
Direccio?n: TULUM REGIO?N 07 MANZANA 494 LOTE 1, MUNICIPIO DE TULUM, QUINTANA ROO ME?XICO.
Credits: COYOTE
Onnis Luque (Photo)
Builder: BLACK Development Group
developer : BLACK Development Group
景观规划设计
25.18 万条内容 · 282 人订阅
城市度假·诗意栖居,南京万科·朗拾·雨核
01 营造美好生活  Crate A Better Life
