由六边形种植模块组成的齿轮花园?鲁冰
齿轮花园是大小景观又一个在可持续设计思考指引下设计建造的低成本、可被回收再利用的展示花园,位于四川省德阳市。
GearGarden located in Deyang City, Sichuan Province.It is a low-cost and recyclabledisplay garden designed and constructed under the sustainable design thinking.
德阳是国家大工业建设基地,也是四川最早的工业区之一。设计团队在研究德阳在地文化的过程中发现,二重(中国第二重型机械集团)是属于德阳市民的独家记忆,历史的工业基因在这座城市随处可见,它们已深植于市民的日常生活之中。
2023年齿轮花园?鲁冰
齿轮花园延续了大小景观可回收花园的模块化设计手法。模块的基因源自于德阳这座老工业城市,设计师提取其中的齿轮元素,并将其转化成边长500mm直径1000mm的六边形模块,这样的形状为设计过程中对道路与休憩空间的尺度搭建,以及后期施工阶段的定位及摆放均提供了便利。
TheGear Garden continues the team’s previous modular design approach forrecyclable gardens. The module typology comes from Deyang, an old industrialcity. We extracted the gear elements and transformed them into hexagonalmodules with a side length of 500mm and a diameter of 1000mm. This shapeprovides convenience for the scale construction of roads and resting spaces inthe design process, as well as the positioning and placement in the laterconstruction stage.
A Heavily Rusty Garden
在最初的模块材质选择上,设计师首选了耐候钢,他们认为唯有耐候钢这种厚重的质感才能完整表达这座城市的历史与精神。但由于成本控制的原因,必须寻找一种能够替代它的低成本材料。经过对市面上的锈工艺大量的调查和研究以及在工厂反复多次的材料试验,终于得到了既有耐候钢质感,又能很好控制成本的材料——设计师通过在特殊处理过的镀锌钢板表面喷涂铁粉和反应剂快速生成锈迹,迅速达成锈钢板的最佳展示效果。
Inthe initial module material selection, we preferred corten steel. The teambelieve that only the heavy texture of weathering steel can fully express thehistory and spirit of this city. However, due to cost control reasons, the teamhad to find a low-cost material that could replace it. After a lot of investigationand research on rust craft on the market and multiple material tests in thefactory, the team finally found a material that has the texture of weatheringsteel and can control costs well. Through spraying iron powder on the surfaceof specially treated galvanized steel plates and reacted quickly to generaterust marks, the material achieved the best display effect of rusted steelplates.
装置表面铁锈的反应过程 ?陈翔
从入场建造到花园开放,仅仅用了20天的时间。这也进一步印证了模块化建造的优势:快速实现设计想法,精确控制质量和成本。
Fromconstruction entry to garden opening, it only took 20 days. This furtherconfirms the advantages of modular construction: rapid realization of designideas, precise control of quality and cost.
施工现状场地为一块有一米高差的坡地,在汲取漩花园(大小景观先于齿轮花园的一座模块化可回收展示花园)建造经验的基础上,设计师快速决定在顶部装置主体支撑柱落位之后,其余模块只需顺应地势排布即可,不再对场地做过多的干预。
After entering theconstruction site, the team found that the current site was a slope with aheight difference of one meter. Based on the experience of building the Vortex,the team quickly decided that after the main support column of the device wasinstalled at the top, the remaining modules only needed to be arrangedaccording to the terrain, without too much intervention in the site.
在花园的建造过程中,有一位路过的老人停留并观察了很久,他告诉驻场设计师:看着这座花园,让他想起了自己曾经在工厂上班的日子。这座锈迹斑驳的花园体现出了这座城市的气质,也让这座城市曾经的建设者们产生了共鸣。
During the constructionof the garden, an elderly passerby stopped and observed for a long time. Hetold the team that looking at this garden reminded him of the days when he usedto work in the factory. A rusty garden can reflect the temperament of a city.The team were honored and happy that this rusty Gear Garden can resonate withthe builders of this city.
齿轮花园旁路过的儿童、中年人、老人 ?鲁冰
大小景观将齿轮花园视作一件连结设计师和老百姓的作品。创作与建造的过程是专业的,而花园的使用与欣赏则属于老百姓的。对设计师来说,最幸福的反馈是设计者与使用者之间的默契与共鸣。
The team regard the GearGarden as a work that connects designers and ordinary people. The process ofcreation and construction is professional, while the use and appreciation ofthe garden belong to the ordinary people. For designers, the happiest feedbackis the tacit understanding and resonance between the designer and the user.
热情高涨的阿姨们摆出各种拍照的POSE ?鲁冰
如果硬景设计需要做到精确的话,那软景设计则是相对精确。在形成关键的空间氛围与结构后,设计师们需要随时应对突发状况,做出战术性地调整。因此,这次的植物设计从前期到落地,不会纠结单个品种的存在,以及单株植物摆放的位置。
If hardscape designneeds to be precise, then softscape design is relatively precise. After formingthe key spatial atmosphere and structure, the team can respond to emergenciesand make tactical adjustments at any time. Therefore, the planting design fromthe early stage to the final implementation will not be entangled with theexistence of individual species or the placement of individual plants.
齿轮花园的植物设计会优先考虑植物群落结构的稳定性和可控性。在选择符合场地生境相对稳定的木本植物和多年生植物作为群落骨架后,根据现场具体情况进行添加和调配,比如让人眼前一亮的惊喜植物,或是不显眼的打底植物,抑或是不在花期的低调植物。设计师们用这种方法使植物在更长的时间维度上富有变化。
The planting design ofthe Gear Garden will prioritize the stability and controllability of the plantcommunity structure. After selecting woody plants and perennials that arerelatively stable in the site habitat as the community framework, the team willadd and adjust according to the specific situation on site, such as addingeye-catching surprise plants, inconspicuous base plants, or low-key plants thatare not in the flowering period. The team used this method to make the plantsrich in changes over a longer time dimension.
齿轮花园的植物设计?鲁冰
由于前期植物方案的确定和组团群落结构的搭建,具体的植物品种成了相对灵活机动的部分。这让设计师有更多的机会尝试新的植物品种和不同植物进行新的排列、组合,碰撞出的新效果,同时这为后期在结合现场具体的不同情况做出的植物调整提供了巨大的便利。例如在当地的稀缺品种或受季节影响价格波动较大的品种,就可以在前期搭建的植物框架的基础上,根据颜色、质感、高度等快速找到可替换的品种。
Due to the determinationof the early plant scheme and the construction of the group communitystructure, the specific plant species have become a relatively flexible andmaneuverable part. This gives the team more opportunities to try new plantspecies and different plant arrangements and combinations, and the new effectsgenerated by collisions. At the same time, this provides great convenience forthe team to make plant adjustments in combination with specific on-siteconditions in the later stage. For example, for local scarce species or specieswith large price fluctuations due to seasonal influences, the team can quicklyfind replaceable species based on the plant framework built in the early stageaccording to color, texture, height, and other factors.
齿轮花园的植物设计?鲁冰
开展前一天,设计师对部分种植效果不理想的植物进行调整 ?陈翔
摄影 鲁冰
景观规划设计
返回版块25.18 万条内容 · 282 人订阅
“空洞砖”演绎现代极简这座白砖房屋是由石匠工匠以一种非常手工艺的方式建造的,采用了缓慢而精确的过程。虽然这种建造过程在现今的巴西利亚并不是很常见,但使用外露的实心砖块具有建筑上的复杂性,需要精湛的技巧和构造的精致性,这些元素在巴西利亚最具代表性的公共建筑中非常突出。 The White Bricks House was built in an extremely artisanal way by masons-craftsmen, in a slow and precise process. Although it is a constructive process that is not very widespread in Brasília nowadays, the use of exposed solid bricks has a constructive complexity that requires precision and constructive refinement, elements that are very present in the most representative public buildings of Brasilia.
