土木在线论坛 \ 建筑结构 \ 结构资料库 \ 层层退的公寓设计
层层退的公寓设计
发布于:2023-07-05 15:59:05 来自:建筑结构/结构资料库 [复制转发]
由MVRDV为开发商Provast设计的两座住宅楼已经在海牙完工。高达120米和100米的Grotius公寓位于Grotiusplaats,离城市的中央车站只有一箭之遥,并与荷兰皇家图书馆相邻。这两座塔楼拥有醒目的堆叠式公寓,在城市中心增加了可负担得起的租赁住房,门前就是公共交通枢纽。在该建筑群的655套公寓中,114套用于社会租赁,另有295套针对中端市场的租赁部门。
Two residential towers designed by MVRDV for developer Provast have been completed in The Hague. The Grotius Towers, which are 120 and 100 metres tall, are located on Grotiusplaats, a stone’s throw from the city’s Central Station and alongside the Royal Library of the Netherlands. With their striking crowns of stacked apartments, the towers add affordable rental housing at the very centre of the city, with a public transport hub on the doorstep. Of the 655 apartments in the complex, 114 are intended for social rent, with a further 295 targeted at the mid-market rental sector.
Grotius公寓在其顶端向上延伸,形成一幅曲折和梯田的景观。从远处就能看到这些王冠,为海牙的天际线增添了一个引人注目的新亮点。在一个每平方米都必须被智能使用的区域,MVRDV设计了两栋总建筑面积为61800平方米的公寓楼。通过巧妙地塑造塔楼的足迹,设计团队能够保留穿过的街道,创建新的广场,并开发了两个建筑,从新的角度看,似乎微妙地改变形状。
At their tops, the Grotius Towers extend upwards into a landscape of setbacks and terraces. These crowns are visible from afar, making an eye-catching new addition to the skyline of The Hague. In an area where every square metre has to be used intelligently, MVRDV designed two apartment buildings with a total floor area of 61,800 square metres. By cleverly shaping the footprints of the towers, the design team was able to preserve through-streets, create new squares, and develop a duo of buildings that appear to subtly change shape when viewed from new perspectives.
设计特别关注了塔楼的顶部:通过允许它们在最顶层不对称地“倒塌”,创造了层叠露台的特色景观,南侧的露台比北侧更多。颜色和材料的变化给楼顶带来了额外的亮点,梯田和外墙采用了可持续的竹子复合材料。在塔楼的底部,颜色的渐变--从上面的米色到底层的烟灰色--也确保了在地面上的软着陆。
The design gives particular attention to the top of the towers: by allowing them to ‘crumble’ asymmetrically at the uppermost levels, the characteristic landscape of stacked terraces is created, with more terraces on the south side than on the north side. A change in colour and material gives the crowns an extra accent, with a sustainable bamboo composite on the terraces and the fac?ades. At the base of the towers, a colour gradient – from beige above to anthracite grey on the bottom floors – also ensures a soft landing on the ground level.
虽然Grotius公寓在租金和面积上各不相同,但即使是最小的角落公寓也能看到美丽的景色,每个公寓都有大窗户。每个居民都有一个户外空间;在上层,居民可以走到屋顶的露台上,而塔的其余部分是部分突出的阳台,部分作为凉廊设置在公寓内。
While the apartments in the Grotius Towers vary in rent and size, even the smallest corner apartment offers beautiful views, with large windows realised in each apartment. Each resident is given an outdoor space; at the upper levels, residents can step out onto the terraces of the crown, while on the rest of the tower are balconies that partly protrude, and partly set back into the apartment as a loggia.
MVRDV的创始合伙人Winy Maas说:“通过这个设计,我们在这个已经繁忙的区域创造了一个新的空间。”“尽管塔楼看起来很窄,但它们包含了很大的建筑面积和混合住宅。顶部的“村庄”实际上是整个设计的顶部。除了视野之外,这一叠露台也允许居民之间的轻松接触。设计让你的邻居更平易近人;租客很快就会觉得自己住在一楼,随意地邀请对方喝杯酒或吃顿饭。”
“With this design, we have created a new space within this already busy area,” says MVRDV founding partner Winy Maas. “Although the towers appear narrow, they contain a large floor area and a mix of homes. The ‘village’ at the top literally crowns the design. In addition to the view, this stack of terraces also allows easy encounters between residents. The design makes your neighbours more approachable; tenants will soon feel as if they live on the ground floor, casually inviting each other for a glass of wine or dinner.”
天然石材和可持续复合竹子的外墙,无气体住宅,以及大约1500个自行车停车位(除244个汽车停车位外),Grotius公寓也是可持续的。在设计中,我们注意了良好的绝缘和热回收系统的能源效率。这些塔楼也是多功能的:除了租赁住房外,底层还有各种设施,从餐馆、咖啡馆到服务。我们特别为居民开发了一个应用程序,他们可以通过这个程序相互联系,进行体育或餐饮预约,这将促进社会凝聚力。
With fac?ades of natural stone and sustainable composite bamboo, gas-free homes, and approximately 1,500 bicycle parking spaces (in addition to 244 for cars), the Grotius Towers are also sustainable. In the design, attention was paid to energy efficiency in the form of good insulation and heat recovery systems. The towers are also multifunctional: as well as rental housing, there are a variety of facilities on the ground floor, from restaurants and cafes to services. An app has been developed especially for residents with which they can get in touch with each other for sports or dining appointments, which will promote social cohesion.
乌得列切特斯班公路和向Bezuidenhout社区方向延伸的步行路线。Grotius公寓为这里的公共空间提供了一个新的维度,是海牙进一步致密化和绿化的开始。
Utrechtsebaan highway and extending the pedestrian route in the direction of the Bezuidenhout neighbourhood. The Grotius Towers give the public space here a new dimension, serving as the start of further densification and greening in this part of The Hague.
Grotius公寓,正式名称为The Roofs,由MVRDV设计,Provast开发,由房地产投资管理公司a.s.r. real estate和CBRE投资管理公司投资。
The Grotius Towers, officially known as The Roofs, were designed by MVRDV and developed by Provast an   d are an investment by real estate investment management firms a.s.r. real estate and CBRE Investment Management.
平面图
户型图
顶层平面图
轴测分析图
设计构思
外箱细部
建筑师:MVRDV
地点:荷兰
面积:61800平方米
年份:2022
结构资料库
41.29 万条内容 · 428 人订阅
"精制钢"的设计与应用,国内精制钢幕墙的发展和瓶颈
1. 前言 随着城市的发展,建筑越来越向高处发展,钢材也扮演了越来越重要的角色,从混凝土中的钢筋,到主体钢结构。作为“工业之母”的钢材,因为其杰出的结构性能和易加工性,是现代建筑最不可取代的材料之一。 作为建筑的外维护结构的幕墙,铝型材因为其几乎可以挤压成任意希望的形状,以及重量轻,防腐性能好,易于切割加工等优异的性能,成了建筑幕墙最重要的框架结构材料。钢材基本上是属于辅助的角色,用在埋件,连接码件,以及不可视部位的结构构件,或者是结构上铝没法做到的部位,比如说雨篷,采光顶的结构部位。
