土木在线论坛 \ 建筑结构 \ 结构资料库 \ 医院建筑更新改造:网格浮雕式立面设计
医院建筑更新改造:网格浮雕式立面设计
发布于:2023-06-28 14:57:28 来自:建筑结构/结构资料库 [复制转发]
位于埃根堡的圣约翰医院的消失,以及将其整合到格拉茨中心的Marschallgasse的新址,意味着除了对医院的构成进行修改外,它还获得了新的外观,与历史悠久的老城区保持一致。
The dissolution of the Hospital of St. John of God in Eggenberg and its integration into the new site in Marschallgasse in the center of Graz meant that in addition to a revision of the hospital’s composition, it also received a new appearance, one which keeps with the historic old town.
这些措施的特点是增加了两个大项目。通过创造一个连贯、宽敞的内庭院,并将各种建筑元素连接成一个大的整体,从城市规划和建筑的角度来看不令人满意的原始情况被“治愈”了。庭院被清空,一个线性的建筑结构被开发出来,以一种特定的、精确的方式与现有的建筑相关联。
The measures are characterized by two large additions. Through the creation of a coherent, spacious inner courtyard and the joining of the various building elements into one large whole, the original situation, which was unsatisfactory from an urban planning and architectural point of view, was “healed”. The courtyard was cleared and a linear building structure was developed that relates to the existing building in a specific, precise way.
在结构和设计上有问题的地方被拆除,取而代之的是与新设计相一致的特征。围绕庭院的结构和功能环现在通过一个精心融入周围环境的新建筑实现。平屋顶被设计成屋顶花园等,并作为病人和工作人员逗留和放松的地方。
Structurally and design-wise questionable elements were demolished and replaced by characteristics that are consistent with the new design. The structural and functional ring closure around the courtyard is now achieved by a new building that is carefully integrated into the surroundings. Flat roofs were designed as roof gardens, among other things, and serve as places for patients and staff to linger and relax.
外墙是根据数学原理用网格和浮雕来调制的。这导致了表面和线条的谨慎、生动的相互作用,以及由一层楼高的白色预制混凝土元素组成的雕塑般的立面设计,俏皮地拾起并延续了历史悠久的老城区的立面形象。
The facade was modulated according to a mathematical principle with grids and reliefs. This resulted in a discreet, lively interplay of surfaces and lines and a sculptural fa?ade design of storey-high, white prefabricated concrete elements that playfully picks up and continues the facade image of the historic old town.
区位图
平面图
轴测分析图
建筑师:Dietger Wissounig Architects
地点:奥地利
面积:25100平方米
年份:2021
结构资料库
41.29 万条内容 · 428 人订阅
PFS 数字榫卯,不需要“钉子”的建筑
? Partyfriendship Office ? Partyfriendship Office 功能的思考 一个邀请公众参与建造的开放式空间 PFS 数字榫卯是一个新概念的纯木质榫卯结构建筑。这个不需要“钉子”的建筑,并不是一个新的概念,反而是一个老的传统,因为中国人千年前就用木头制作房屋,这个也会让附近的居民产生快速的认同和讨论。
