土木在线论坛 \ 装修设计 \ 公装设计 \ 加拿大Vention科技公司办公空间
加拿大Vention科技公司办公空间
发布于:2023-06-21 14:47:21 来自:装修设计/公装设计 [复制转发]
Vention是一家位于蒙特利尔的科技公司,主要开发定制铝材挤制模型,为制造商们提供简单的工业自动化模具。随着公司持续不断的发展,他们需要一个更大的办公室。去年,该团队决定将他们14000平方英尺的Saint-Henri仓库改造成工作空间。
Vention is a Montreal based technology company that developed system of customized aluminium extrusions that simply industrial automatization for manufacturers. The company being in constant evolution, their need for bigger offices quickly emerged. It was last year that their team decided to transform their current 14 000 square foot Saint-Henri warehouses into work spaces.
▼由仓库改建的办公空间
▼入口处
从一开始,设计的意图就是创造一个简单的办公环境,并突出公司及其产品的特点。该公司产品的美学以及标志性的“Vention蓝”成为了贯穿空间概念的决定性因素。
From the start, the design intention was to create a simple environment that put forward the identity of the company and of their product. The esthetic of their pieces, their perforations and their signature “Vention blue” colour were determining factors in the conception of the space.
▼简单的办公室环境
这些位于同一工业建筑中的办公空间被成两个不同的房间,所有的墙壁、天花板、结构性和机械性系统都被粉刷成白色,混凝土地板上也覆盖着一层相同颜色的环氧树脂涂层。该办公室是由大部分通体白色的家具组成的开放型空间。
The offices are separated into two distinct rooms in the same industrial building. All of the walls, ceilings, structural and mechanical systems were entirely painted white, and the existing concrete floor was covered with an epoxy coat of the same colour. The majority of the square footage consists of open space offices with all white furniture.
▼会议室
▼开放的办公空间
▼机器人室
▼其他工作室空间
在这个中性浅色调的背景中心放置着一些覆盖着穿孔金属板的蓝色巨石,模仿放置在装配线上的巨大的Vention机器。空间中包含了公司所有封闭的协作空间,例如会议室、非正式头脑风暴室和呼叫室。
空间内部,从地毯到墙壁的色彩均使用了“Vention蓝”。   设计师用一系列玻璃墙将这些孤立的空间对外展示出来,使在其中长时间工作的人们能够更加舒适。当需要更多私密空间的时候,可以关闭安装在天花板极薄的蓝色窗帘。
At the center of this light neutral background can be found these blue monoliths covered in perforated metal sheets, mimicking large Vention machines placed in an assembly line. These objects consist of all of the closed collaborative spaces for the team, such as conference rooms, informal brainstorming rooms and call rooms.
On the inside, the entire material palette brings back the “Vention blue”, from the carpet to the painted walls. A series of glazed walls open up these isolated spaces, making them more comfortable for longer periods. Ceiling high blue sheer curtains can be closed for the times when more privacy is required.
▼覆盖着穿孔金属板的蓝色巨石
▼穿孔金属板细部
空间中的多个区域,霓虹灯被隐藏在穿孔钢板之后,营造了独特的视觉效果。例如,入口处,这些霓虹灯被展示在由白色挤压件制成的中央柜台后面;厨房中,一个内部发光的结构被悬挂在中央岛台之上,作为功能区和聚集区的分隔。
In several areas, neon lights are hidden behind the perforated steel sheets, creating unique visuals and putting a spotlight on some feature elements of the project. At the entrance, for example, they are displayed behind the central counter made of white extrusions manufactured specifically for the occasion. In the kitchen, a structure lit up from the inside hangs above the island and acts as a division between the functional and the gathering areas.
▼安装在穿孔板上的霓虹灯
▼充满公司特色的蓝色定制桌椅
空间中所有的桌子都是与Vention团队合作定制设计的,并使用了他们的蓝色铝制材料。桌子的顶部由海军蓝色的烟熏玻璃板组成,能够展示其独特支撑结构。Vention使用独特的挤压组装技术创造了可以代表公司特点的家具组件。整个项目受到了由Vention的标志性产品和其卓越的公司文化的启发。
All of the tables in the space were custom designed in collaboration with the Vention team with the use of their blue aluminum extrusions. The tops consist of navy blue smoked glass panels that showcase the unique structures that hold them. Vention’s specific extrusion assembly techniques served to create furniture pieces that truly represent them. The project in its entirety was greatly inspired by the Vention’s signature products and exceptional company culture.
▼空间01平面图
▼空间02平面图
公装设计
8.03 万条内容 · 210 人订阅
叠水问山 | 深圳问山叠水驿
  同济原作设计工作室 场地初见 深圳环西丽湖绿道(一期)全长约3.5公里,在一级水源地保护范围外圈与各类城市用地间纵向延展。本项目的探索始于对这条线性压缩空间的一些放大的尝试。绿道的北段已然深入山林,在林地范围线、基本农田与水源保护范围线的空隙之中,我们发现了这片由一些杂乱工棚占据的硬质场地。
