NTRY STATIC ANALYSIS FOR NONLINEAR.
ITERATION NO. : 1 DISPLACEMENT ERROR NORM .. : 0.10000E+01 CONVERGENCE TOLERANCE .. : 0.10000E-01
WARNING : NODE NO. 9 DX DOF MAY BE SINGULAR.
WARNING : EQUATION NO. 7
WARNING : NODE NO. 8 RZ DOF MAY BE SINGULAR.
WARNING : EQUATION NO. 6
WARNING : NODE NO. 8 RY DOF MAY BE SINGULAR.
WARNING : EQUATION NO. 5
WARNING : NODE NO. 8 RX DOF MAY BE SINGULAR.
WARNING : EQUATION NO. 4
WARNING : NODE NO. 8 DZ DOF MAY BE SINGULAR.
WARNING : EQUATION NO. 3
WARNING : NODE NO. 8 DY DOF MAY BE SINGULAR.
WARNING : EQUATION NO. 2
ITERATION NO. : 2 DISPLACEMENT ERROR NORM .. : 0.14022E+00 CONVERGENCE TOLERANCE .. : 0.10000E-01
ITERATION NO. : 3 DISPLACEMENT ERROR NORM .. : 0.27070E-01 CONVERGENCE TOLERANCE .. : 0.10000E-01
ITERATION NO. : 4 DISPLACEMENT ERROR NORM .. : 0.45725E-02 CONVERGENCE TOLERANCE .. : 0.10000E-01
CONSTRUCTION STAGE RESULTS SAVED TO FN.CA6 FILE
CONSTRUCTION STEP NO. : 51 / 74 STAGE NO : 25 STEP NO : 2
ENTRY PHASE FOR RENUMBERING
ENTRY NUMBERING_EQN
ENTRY FORM_STIFF_MASS_LOAD
THE INDIVIDUAL ELEMENT STIFFNESS AND LOAD MATRICES WILL NOW BE FORMED.
ELEMENT NO. : 43 OF 60
ENTRY SOLUTION PHASE
ENTRY LOAD_BLOCK
TOTAL NUMBER OF VALID DOFS IN MODEL : 264
ENTRY ASSM_STIFF_LOAD ( FORM GLOBAL EQUILIBRIUM EQUATIONS IN BLOCKS )
ENTRY STATIC ANALYSIS FOR NONLINEAR.
ITERATION NO. : 2 DISPLACEMENT ERROR NORM .. : 0.10000E+01 CONVERGENCE TOLERANCE .. : 0.10000E-01
ITERATION NO. : 3 DISPLACEMENT ERROR NORM .. : 0.51989E-01 CONVERGENCE TOLERANCE .. : 0.10000E-01
ITERATION NO. : 4 DISPLACEMENT ERROR NORM .. : 0.96402E-02 CONVERGENCE TOLERANCE .. : 0.10000E-01
CONSTRUCTION STEP NO. : 52 / 74 STAGE NO : 26 STEP NO : 1
ENTRY NUMBERING_EQN
ELEMENT NO. : 53 OF 60
ENTRY LOAD_BLOCK
TOTAL NUMBER OF VALID DOFS IN MODEL : 330
WARNING : NODE NO. 58 RZ DOF MAY BE SINGULAR.
WARNING : EQUATION NO. 312
WARNING : NODE NO. 58 DX DOF MAY BE SINGULAR.
WARNING : EQUATION NO. 307
WARNING : NODE NO. 58 DY DOF MAY BE SINGULAR.
WARNING : EQUATION NO. 308
WARNING : NODE NO. 58 DZ DOF MAY BE SINGULAR.
WARNING : EQUATION NO. 309
WARNING : NODE NO. 58 RX DOF MAY BE SINGULAR.
WARNING : EQUATION NO. 310
WARNING : NODE NO. 58 RY DOF MAY BE SINGULAR.
WARNING : EQUATION NO. 311
WARNING : EQUATION NO. 37
WARNING : EQUATION NO. 36
WARNING : EQUATION NO. 35
WARNING : EQUATION NO. 34
WARNING : EQUATION NO. 33
WARNING : EQUATION NO. 32
ITERATION NO. : 2 DISPLACEMENT ERROR NORM .. : 0.13031E+00 CONVERGENCE TOLERANCE .. : 0.10000E-01
ITERATION NO. : 3 DISPLACEMENT ERROR NORM .. : 0.27443E-01 CONVERGENCE TOLERANCE .. : 0.10000E-01
ITERATION NO. : 4 DISPLACEMENT ERROR NORM .. : 0.51144E-02 CONVERGENCE TOLERANCE .. : 0.10000E-01
CONSTRUCTION STEP NO. : 53 / 74 STAGE NO : 26 STEP NO : 2
ENTRY NUMBERING_EQN
ENTRY LOAD_BLOCK
ERROR NORM IS NaN or INFINITE
THE PROGRAM IS ABORTED
MIDAS
返回版块5.84 万条内容 · 317 人订阅
MIDAS GTS NX上下协同分析的耦合建模迈达斯岩土系列产品简介: midas GTS NX midas GTS NX(New eXperience of Geo-Technical analysis System)是一款针对岩土领域研发的通用有限元分析软件,支持静力分析、动力分析、渗流分析、应力-渗流耦合分析、固结分析、施工阶段分析、边坡稳定分析等多种分析类型,适用于地铁、隧道、边坡、基坑、桩基、水工、矿山等各种实际工程的准确建模与分析,并提供了多种专业化建模助手和数据库。
只看楼主 我来说两句 抢板凳顶一个,感谢楼主,谢谢楼主分享,先来试一试!
