土木在线论坛 \ 建筑设计 \ 公共建筑设计 \ 悬挑结构 竹编工艺为灵感的立面:成都交子公园金融总部产业园
发布于:2023-06-15 11:29:15 来自:建筑设计/公共建筑设计 [复制转发]
MVRDV设计的成都交子公园金融总部产业园(七期)项目正式动工,项目包含三栋办公塔楼和一座会议中心,由一座环形的商业裙楼串联起来。设计考虑了诸多背景因素,环形的商业村落呼应了基地曾经存在的传统建筑。
Construction has begun at the last remaining empty sites in Chengdu’s Jiaozi Park Financial and Business District, where MVRDV has designed a complex comprised of three mixed-use office towers and a conference center united by a ring-shaped plinth. The building shape and functional structure are informed by its surrounding context, with a retail village that references the traditional structures that were once located on the site.
三栋塔楼分别高约80米、100米和130米,与会议中心各自占据矩形基地的一角。会议中心面向天府国际金融中心,采用了戏剧化的悬挑结构和以成都本地竹编工艺为灵感的立面肌理。
办公塔楼和会议中心的矩形平面与将塔楼串联起来的环形商业裙楼在地块中心共同构成一个圆形的内部庭院。裙楼在靠近会议中心的部分设置了到达地面层的阶梯,同时创造了视觉链接,将人们吸引到项目的中心位置。此外,裙楼还拥有另外三条通向内部庭院的通道。
The three office towers, measuring 80, 100, and 130 meters in height, respectively, are displayed around the conference center and the open spaces in the middle of the site. The conference center, therefore, acts as the main focal point of the complex, with its distinctive image of cantilevered volumes and fa?ade details inspired by the bamboo-weaving traditions of the region. A ring-shaped plinth encircles the four structures to define the interior courtyard. In the proximity of the conference center, the plinth steps down to the street level to create a visual connection and invite people to the center of the site. Additionally, three other access points are provided at different locations.
圆形庭院内以现代风格的单层和双层建筑为主,呼应了基地现场的历史特征:直到二十世纪中期,这里还是一个传统的小村庄,但如今都已消失不见。
MVRDV将这些被移除的建筑以原来的大小和位置重建,作为零售、咖啡馆、酒吧和餐厅,进而融合成为一个商业村落,在环形的庭院内营造出迷人而充满活力的氛围。在MVRDV的方案中,为了减少隐含碳,这些小型建筑将采用木材和回收材料建造。
The central courtyard represents a modern reinterpretation of one- and two-storey buildings. The area is designed to reference the small traditional village that was present on site until the mid-2000s. The now-demolished structures are reimagined to serve as a retail village, featuring cafés, bars, and restaurants. The structures are proposed to be constructed from wood and recycled materials.
MVRDV为三座办公塔楼赋予了微妙而优雅的立面细节,使其能够与周围朴素的建筑群融为一体,这些细节也是可持续发展的关键。
基于周围林立的建筑群,MVRDV对项目进行了深入的采光分析,能够准确定位阳光照射在建筑表面的具体位置和对应的具体时间,并依此对立面设计上的遮阳翼进行三种不同角度的精确调整,有效控制日晒。
在遮阳翼的内侧设置了金属开启扇,允许用户自主控制自然通风,降低对机械制冷的依赖,从而减少办公室所需的运行能源。
The design of the three office towers was created to blend with their surroundings, while also integrating features to ensure the tower’s sustainability. A shadow study of the site identified the optimal orientation of the towers’ surfaces, allowing the design team to adapt the facades to limit solar gain. Vertical fins of the curtain-wall fa?ade are employed for this purpose, while the back-side of these fins features openable panels to allow for user-controlled natural ventilation, thus reducing the need for mechanical cooling, which requires additional operational energy.
“交子公园金融总部产业园是一个非常难得的项目,它为寸土寸金的成都交子商圈添加了最后一块拼图。”MVRDV创始合伙人Jacob Van Rijs说,“很难想象,这里在20年前还是一片乡村,我们在疫情期间参加了这个项目的设计竞赛,从地图上发现了这里曾经还是一座村庄。
于是我们决定在历史与当下之间创造一个新的村落,在三栋全新的塔楼之间,人们可以感受到这片土地经历的飞速变迁。”
With the Jiaozi Courtyard Towers, we were given an opportunity that is rare in China: a design project that adds the final puzzle piece to a new district. It is hard to imagine that this entire district was still rural 20 years ago. We entered this competition during the pandemic and discovered the village via Google Earth. With that in mind, we decided to create within the stake and historic world. Seeing this while surrounded by three new towers, you become aware of the rapid transition that this place has gone through. - MVRDV founding partner Jacob van Rijs
最近,MVRDV被选中领导杭州炼油厂工厂园区的设计,这是一个广泛的项目,旨在将前工业区改造成一个设置在绿色环境中的文化中心。该事务所还披露了德国海尔布隆一个专门用于人工智能研究的新创新园区的总体规划,以及荷兰东部的Noviotech园区的扩建计划。
Recently, MVRDV has been selected to lead the design of the Hangzhou Oil Refinery Factory Park, an extensive project aiming to transform the former industrial district into a cultural center set in a green environment. The office has also revealed the master plan of a new innovation park dedicated to artificial intelligence research in Heilbronn, Germany, and the plan for the expansion of the Noviotech Campus in the eastern Netherlands.
公共建筑设计
51.18 万条内容 · 448 人订阅
有一种建筑叫做圆形的建筑
        我们为什么需要圆?
