土木在线论坛 \ 建筑设计 \ 公共建筑设计 \ 大学校园:模块化、堆叠元素,裸露的混凝土立面
发布于:2023-06-08 10:59:08 来自:建筑设计/公共建筑设计 [复制转发]
中国台湾·NCCU公共和商业管理教育中心
JJP建筑和规划师事务所
公共与工商管理教育中心(CPBAE)为行业精英提供高管教育。该项目已经超越了原来的建筑,被认为是大学和城市的概念和建筑缩影。
NCCU Center for Public and Business Administration Education (CPBAE) provides executive education for senior civil servants and industry leaders. Having outgrown its original building, the project is conceived as both a conceptual and architectural microcosm of the university and the city.
该项目位于一个充满活力的多功能社区,将大学的基本功能浓缩在一个比郊区主校区小100倍的场地上。因此,主校区的横轴布置变成了垂直方向。然后使用模块化网格系统配置和堆叠程序元素,并分成两个体量。一个体量容纳了学术和会议元素,并覆盖着石头,而另一个体量包括100间客房,立面是裸露的混凝土。在中间,一系列透明的体量,即大厅、中庭和咖啡馆,将中心的内部运作投射到城市之外。
Situated within a vibrant mixed-use neighborhood, the project condenses the essential functions of the university onto a site that is 100 times smaller than its suburban main campus. Thus, the horizontal axis arrangement of the main campus is turned into a vertical orientation. The program elements are then configured and stacked using a modular grid system and split into two volumes. One volume houses the academic and conference elements and is clad in stone, while the other comprises 100 guest rooms with an exposed concrete facade. In between, a series of transparent volumes, namely the lobby, atrium, and cafe, project the center’s inner workings to the city beyond.
主要的功能空间可以通过一系列层次分明、顺序排列的公共区域到达,这些公共区域充满阳光,自然通风。一个30米高的中庭取代了传统的校园四边形,一个小会议室的玻璃舱戏剧性地突出到空间中,进一步活跃了校园四边形。
The major functional spaces are reachable through a series of hierarchically and sequentially arranged public areas, filled with daylight, and ventilated naturally. A 30-meter-high central atrium takes the place of the traditional campus quad, which is further enlivened by the glass pods of a small meeting room dramatically protruding into the void.
在街道层面,一层将现有和新种植的植被整合在一个多孔的场地边界内。入口广场的设计是为了聚集人群,举办活动,并为社区提供休闲活动。各种景观露台进一步促进了社会、学术和专业的互动。
At the street level, the ground floor integrates both existing and newly planted vegetation within a porous site boundary. The entrance plaza is designed to gather people, host events, and facilitate leisure activities for the neighborhood. The various landscaped terraces further foster social, academic, and professional interactions.
项目图纸
平面图
平面图
平面图
示意图
爆炸分析图
分析图
分 析图
分   析图
项目信息
建筑师:JJP Architects & Planners
地点:中国台湾
面积:26949 m2
年份:2021
公共建筑设计
51.18 万条内容 · 448 人订阅
行望居游式的扁舟微筑 - 四叶草堂
      ? 直译建筑摄影   以草堂为基点,茂林掩映。站在馆内远望,远山近湖,层林叠嶂,游人隐现于湖岸草地之间,颇似一幅动态的中国古典山水画卷。
