土木在线论坛 \ 建筑设计 \ 居住建筑设计 \ 高端住宅:独特“凹槽式”立面,创新的材料和施工方法
发布于:2023-06-07 09:45:07 来自:建筑设计/居住建筑设计 [复制转发]
斯图亚特街212号位于两个社区之间,与历史悠久的海湾村的亲密住宅规模和波士顿高脊柱的高层建筑规模相协调。摒弃了城市中比较传统的全玻璃高层建筑,该团队试图为城市的外墙带来质量和深度。该建筑采用了创新的材料和施工方法,其独特的立面由凹槽式桥墩组成,其规模在整个围护结构中有所不同,并与历史街区的砖石细节产生共鸣。
Situated between two neighborhoods, 212 Stuart Street negotiates the intimate residential scale of historic Bay Village and the high-rise scale of Boston’s High Spine. Moving away from the more traditional all-glass high rises in the city, the team sought to bring quality and depth to the urban fa?ade. Employing an innovative approach to materials and construction, the building’s distinctive fa?ade consists of fluted piers that vary in scale across the envelope and resonate with the masonry detailing of the historic neighborhood.
示意图
示意图
斯图亚特街212号在城市的几个尺度上运作。从远处看,该建筑以独特的轮廓与天空相接。在街道上,建筑与地面相接,立即与人行道和街景接触,因为门廊、花盆和铁制品与海湾村的住宅环境形成了对话。这座19层高的建筑还包含两座联排别墅,使海湾村的北侧街景更加完整。
212 Stuart Street operates at several scales in the city. When viewed from a distance, the building meets the sky with a distinctive silhouette. At the street level, the building meets the ground in a way that immediately engages with the sidewalk and streetscape as stoops, planters, and ironwork create a dialogue with the residential context of Bay Village. This nineteen-story building also contains two townhouses that complete the north side of the Bay Village streetscape.
平面 图
该项目的位置--一个小的、不规则形状的场地,以前被用作停车场--带来了一些设计限制,包括其紧张的城市环境。在设计和施工的早期阶段,建筑围护结构与预制混凝土制造商和外墙安装商进行了协调,以减少施工中的摩擦。该设计突破了多层凹板的制造极限,通常有20或30英尺高,跨越8个主要模具,通过优化施工顺序来减少安装时间。不规则间隔的凹板(由BPDL在当地制作)和多层凹陷的玻璃填充板强调了建筑的垂直度,创造了一个部分与整体的关系,使212斯图尔特街在波士顿的天际线上与众不同。
The project’s location—a small, irregularly shaped site that was formerly used as a parking lot—presented several design constraints, including its tight urban context. The building envelope was coordinated with precast concrete fabricators and fa?ade installers in the early phases of design and construction to minimize friction during construction. The design pushes the limits of the fabrication of the multi-story concave panels, typically either 20 or 30 feet high, across eight primary molds to reduce installation time by optimizing construction sequencing. The irregularly-spaced concave panels (fabricated locally by BPDL) and multi-story, recessed glass infill panels emphasize the building's verticality and create a part-to-whole relationship that makes 212 Stuart Street distinct within Boston’s skyline.
这些面板在工厂被仔细地标记和订购,并按照确切的安装顺序装上卡车。在现场,用起重机直接从卡车上取下面板,挂在建筑物上,省去了耗时的分阶段过程。住宅单元的玻璃采用了从地板到天花板的窗墙形式,在混凝土板上有隔板玻璃。玻璃板的厚度从两端的12英寸到中间的5英寸不等,这就使得建筑的深度和阴影都很明显,同时也使得外墙可以部分自我遮挡。
The panels were carefully tagged and ordered at the plant and loaded onto trucks in the exact sequence they would be installed. At the site, the panels were picked by crane directly from the truck and hung on the building, saving a time-consuming staging process. Glazing for the residential units takes the form of a floor-to-ceiling window wall with spandrel glass at the concrete slabs. The thickness of the panels ranges from 12 inches at the ends to five inches at the center which allows for dramatic depth and shadow while also allowing for the facade to be partially self-shaded.
项目信息
建筑师:H?weler Yoon Architecture, Sasaki
地点:美国
面积:146000平方英尺
年份:2022
摄影:Chuck Choi
全部回复(3 )
  • zhihuawng
    zhihuawng 沙发
    很有创意,平面方正条件一下也可以做出立面的凹凸感
    2023-07-06 08:32:06
  • 阿巅2019
    阿巅2019 板凳
    谢谢偻主 我会好好学习的
    2023-06-30 12:18:30
居住建筑设计
28.74 万条内容 · 423 人订阅
住宅底商设计要点分析
来源:网络             如有版权问题,请联系删除
