土木在线论坛 \ 建筑设计 \ 公共建筑设计 \ 市政厅办公楼:独特的外墙,混合了香槟色的元素和大型玻璃板
发布于:2023-06-06 10:17:06 来自:建筑设计/公共建筑设计 [复制转发]
在H?je-Taastrup,你会发现丹麦最创新和独特的市政厅之一。公民之家 "的设计雄心勃勃,具有前瞻性--以良好的工作环境、可持续的解决方案和加强当地社区的愿景为特色。九层楼。引人注目的透明外墙,具有俏皮的角度。大型、诱人的屋顶露台,可向公众开放。H?je-Taastrup的市政厅作为一个重要的建筑地标脱颖而出。该建筑是由PLH Arkitekter公司与ALL公司和COWI公司合作设计的,目的是为员工开发现代、灵活的工作环境,同时也是对城市和市民的回馈。
In H?je-Taastrup you find one of Denmark's most innovative and unique city halls. The "Citizens' House" is ambitious and forward-looking in its design – featuring a great work environment, sustainable solutions, and visions of strengthening the local communities. Nine floors. Eye-catching, transparent facade with playful angles. Large, inviting rooftop terrace, which can be opened to the public. H?je-Taastrup's city hall stands out as a significant architectural landmark. The building is designed by PLH Arkitekter in collaboration with ALL and COWI out of a vision of developing modern, flexible work environments for employees, while at the same time giving back to the city and its citizens.
一个露台、阳光平台和舒适的座位区围绕着建筑。三个大楼梯、小路和靠近建筑的植物有助于与附近的城市公园形成自然的凝聚力。独特的外墙的特点是混合了香槟色的元素和大型玻璃板,它们相互之间有轻微的角度,创造了一个动态的和受欢迎的表达。
A terrace, sun deck, and cozy seating areas surround the building. Three large stairs, paths, and plantings close to the building help create a natural cohesion with the nearby city park. The unique facade is characterized by a mix of champagne-colored elements and large glass panels, which are angled slightly in relation to each other, creating a dynamic and welcoming expression.
其目的是创造一个既是员工的现代工作场所,又是市民的自然、诱人的聚会点的房子。进入37米高的大中庭,你会发现面向市民的功能,如接待处、就业中心、市民服务,以及可供市民借用并直接通往城市公园的议会厅。因此,室外区域可以包括在会议厅内举行的婚礼等活动中。
The aim has been to create a house that is both a modern workplace for employees and a natural, inviting gathering point for citizens. Entering the large, 37-meter-high atrium you find citizen-oriented functions such as reception, job center, citizen service, and the council chamber, which can be borrowed by citizens and has direct access to the city park. Thus, the outdoor areas can be included in events such as weddings held in the chamber.
在中庭,你还可以找到建筑的中央楼梯。它的设计使它可以被用作表演和集会的护民官,或者只是在白天提供一个休息的地方。从楼梯到第一层,你会发现多会议厅,它可以用于会议和公共活动。接下来的楼层包含围绕开放的中庭组织的工作区,可以清楚地看到不同楼层的情况,以支持一致性和知识共享。工作站被放置在大窗户旁,提供充足的日光。为了适应未来的需要,办公区的设计是灵活的,因此可以很容易地根据新的需求和工作方法进行重新配置。
In the atrium, you also find the central staircase of the building. It is designed so that it can be used as a tribune for performances and gatherings, or simply offer a place to rest during the day. From the staircase, you reach the first floor, where you will find the multi-meeting hall, which can be used for meetings and public events. The next floors contain work areas organized around the open atrium with a clear view of the different floors to support coherence and knowledge sharing. The workstations are placed by the large windows providing plenty of daylight. To future-proof the office areas, the design is flexible, so it can be easily reconfigured for new needs and work methods.
在建筑的顶部,有一个大型的屋顶露台,可用于举办活动并向公众开放。该平台被设计成一个建筑景观,分为几个不同的层次。可持续的解决方案已经成为项目的一个组成部分。市政厅周围的绿色植物增加了生物多样性。同时,建筑的二氧化碳排放量也得到了减少,因为该建筑的地基是由该市被拆除的公寓楼回收的混凝土组成的。
At the top of the building, there is a large rooftop terrace that can be used for events and opened to the public. The terrace is designed as an architectural landscape divided into several different levels. Sustainable solutions have been an integrated part of the project. The greenery around the city hall increases biodiversity. At the same time, CO2 emissions from the construction have been reduced, as the building’s foundation consists of recycled concrete from demolished apartment buildings in the municipality.
项目图纸
平面图
平   面图
平   面图
平   面图
平   面图
平   面图
平   面图
剖面图
项目信息
建筑师:PLH Arkitekter
地点:丹麦
面积:9659 m2
年份:2022
摄影:Emil Lund Pedersen, Kontraframe
公共建筑设计
51.18 万条内容 · 448 人订阅
生物医药产业园:设计8大独特性
BioBAY苏州生物医药产业园四期 三个层面回应生物医药人才未来需求 FTA 在最新的“中国生物医药产业园区竞争力”排名中,苏州工业园区的综合竞争力位列全国第一方阵。苏州工业园区生物医药产业园(BioBAY),作为国内发展水平较高的生物医药专业园区,其四期与六期均由FTA操刀设计。
