土木在线论坛 \ 建筑设计 \ CAD下载及教程 \ 如何开发网页版CAD的样条曲线功能
如何开发网页版CAD的样条曲线功能
发布于:2023-05-26 11:19:26 来自:建筑设计/CAD下载及教程 [复制转发]
以下是网页CAD中使用 和 HTML5 Canvas 绘制样条曲线的示例代码:
HTML 代码:
<!DOCTYPE html>
<html>
<head>
 <title>Spline Curve</title>
 <meta charset="UTF-8">
 <style type="text/css">
  canvas {
   border: 1px solid black;
 </style>
</head>
<body>
 <canvas id="canvas" width="800" height="500"></canvas>
 <script src="spline.js"></script>
 <script>
  // 绘制样条曲线
  var canvas = document.getElementById(39;canvas39;);
  if (canvas.getContext) {
   var ctx = canvas.getContext(39;2d39;);
   ctx.fillStyle = 39;white39;;
   ctx.fillRect(0, 0, canvas.width, canvas.height);
   var points = [
    { x: 50, y: 100 },
    { x: 200, y: 150 },
    { x: 300, y: 250 },
    { x: 400, y: 200 },
    { x: 500, y: 300 }
   var tension = 0.5;
   var segments = 50;
   var splinePoints = getSplinePoints(points, tension, segments);
   drawCurve(ctx, splinePoints);
 </script>
</body>
</html>
代码(spline.js):
// 计算样条曲线上的点
function getSplinePoints(points, tension, segments) {
 if (points.length < 2) return [];
 // 初始化矩阵
 var m = [];
 for (var i = 0; i < points.length; i++) {
  m = [1, points.x, points.x * points.x, points.x * points.x * points.x];
 // 计算常数向量
 var b = [];
  b = [points.y];
 // 计算系数矩阵
 var mt = math.transpose(m);
 var a = math.multiply(mt, m);
 var ai = math.inv(a);
 var x = math.multiply(ai, mt);
 x = math.multiply(x, b);
 // 计算曲线上的点
 var curve = [];
 for (var i = 0; i < (points.length - 1); i++) {
  for (var j = 0; j < segments; j++) {
   var t = j / segments;
   var t2 = t * t;
   var t3 = t2 * t;
   var h00 = 2 * t3 - 3 * t2 + 1;
   var h01 = -2 * t3 + 3 * t2;
   var h10 = t3 - 2 * t2 + t;
   var h11 = t3 - t2;
   var px = h00 * points.x + h01 * points[i + 1].x + h10 * tension * (points[i + 1].x - points.x) + h11 * tension * (points[i + 2].x - points[i + 1].x);
   var py = h00 * x[0] + h01 * x[i + 1][0] + h10 * tension * (x[i + 1][0] - x[0]) + h11 * tension * (x[i + 2][0] - x[i + 1][0]);
   curve.push({ x: px, y: py });
 return curve;
// 绘制曲线
function drawCurve(ctx, points) {
 ctx.lineWidth = 2;
 ctx.strokeStyle = 39;black39;;
 ctx.beginPath();
 ctx.moveTo(points[0].x, points[0].y);
 for (var i = 1; i < points.length; i++) {
  ctx.lineTo(points.x, points.y);
 ctx.stroke();
使用这个代码,你可以在网页中绘制出指定点的样条曲线。代码中的 points 数组包含要绘制曲线的点,tension 参数控制曲线的平滑度,segments 参数控制曲线的精细度,以上是在线CAD中样条曲线的开发思路,有其他问题可以到梦想CAD控件官网查看云图产品文档。
CAD下载及教程
52.09 万条内容 · 690 人订阅
CAD高版本转低版本小程序
CAD高版本转低版本
