York University’s School of Continuing Studies (SCS) was dispersed across a series of temporary accommodations-a critical shortcoming for the School’s students and faculty. In response, the University articulated the need for a dedicated building to assert the School’s identity and culture, define a campus gateway, and meet ambitious sustainability targets.
The bold twisting form creates a new home for the School and defines the south edge of the campus and shapes a new pedestrian plaza. The building accommodates highly flexible learning environments, social and collaboration spaces, and offices for students and faculty in a space that is lofty, and bright promoting community, culture, and identity for SCS.
At the core of the project are the goals of reducing embodied carbon and improving occupant health. The design explores the potential for Net-Zero Energy and Net-Zero Carbon and is designed to achieve LEED Gold certification. Strategies include a building envelope designed using Passive House strategies, direct outdoor air ventilation, and active chilled beams throughout. The use of Passive House design strategies combined with highly efficient HVAC and energy systems reduce energy loads greatly, minimizing the extent of the renewable energy production needed to aid the project in achieving the Net-Zero Energy target.
The design approach formally departs from the surrounding built fabric with a strict economy of means. With high energy efficiency and occupant comfort targets, the budgetary premium associated with the twisting form needed to be minimized. The design, in response, deploys a rigorous geometry that optimizes the repetition of standard, off-the-shelf components. Thus, the building’s dynamic form is generated through simple geometric logic, with rectangular floor plates rotated around a common centroid.
The rotation of the overall form introduces a two-way curve into the north and south facades. As the building rotates about its centroid, a triangulated panel pattern takes advantage of regular and biaxial symmetry to create zones of repeat panel shapes on both the long and short facades of the building. Through this simple twisting gesture, the brief of creating a striking new home for the School of Continuing Studies, which promotes the combined agendas of energy efficiency, occupant well-being, and campus building, is accomplished.
平面图
平面图
平面图
平面图
剖面图
剖面图
剖面图
剖面图
示意图
示意图
示意图
轴测分析图
模型图
项目信息
建筑师:Perkins&Will
地点:加拿大
面积:11200 m2
年份:2022
摄影:Doublespace Photography, Tom Arban Photography
免费1人已点赞
建筑构造
返回版块7.65 万条内容 · 196 人订阅
伦佐·皮亚诺新作:伊斯坦布尔现代博物馆Istanbul Modern New Building 伊斯坦布尔现代博物馆 伊斯坦布尔现代博物馆是土耳其的第一家现代和当代艺术博物馆,于 2004 年首次开放。经过五年的重建工程,该博物馆于 2023 年 5 月 4 日重新开放。
只看楼主 我来说两句 抢板凳约克大学的继续研究学院(SCS)分散在一系列的临时住所中,这对学院的学生和教师来说是一个关键的缺陷。作为回应,大学明确表示需要一个专门的建筑来维护学院的身份和文化,定义一个校园门户,并满足雄心勃勃的可持续发展目标。
