土木在线论坛 \ 园林景观 \ 景观规划设计 \ 尊重环境的现代住宅 | 希腊·O Lofos之家
发布于:2023-05-12 11:24:12 来自:园林景观/景观规划设计 [复制转发]
绿色、狂野的克里特岛景观和传统手工艺的丰富和传承定义了 Block722 全新的、完全现代的住宅设计。该项目位于希腊岛东侧 Thrypti山的北麓,是一位私人客户的委托。他要求在一个斜坡上建造一个 280 平方米的住宅,包括两间客房和宽敞的户外区域。
The green, wild Cretan landscape and the richness and heritage of traditional crafts define this new, thoroughly contemporary residential design by Block722. Sat on the northern foothills of Thrypti mountain within the Greek island’s eastern side, the project is a commission by a private client. It called for a 280 sq m home on a slope, including two guestrooms and generous outdoor areas.
在建筑师的设计方案中,保证建筑的平衡和简洁的需求与结合了山脉、平原和地中海景观的自然环境是至关重要的。这座建筑是出于打造一座谨慎且尊重周围环境的现代住宅的愿望。通过层次而不是台阶来协场地的角度,对于塑造一个包含其设置的放松环境也至关重要。
Balancing the needs of the brief with the natural setting that combines vistas of mountains, plains, and the Mediterranean Sea, was critical in the architects’ design solution. The architecture was driven by a desire to create a modern house that is discreet and respectful of its surroundings. Negotiating the site’s angle through levels instead of steps was also critical in molding a relaxing environment that embraces its setting.
从主干道沿着斜坡向下的一条小路将游客引向住宅的入口。建筑的大小被巧妙地分解成更小的体积,它们通过循环路线和中间空间相互连接——一些在室内,一些在露天。主屋分为两座低矮的建筑,由一个带有水景的半封闭区域相连。该设计融合了当地常用的天然材料,如木材和石头。同时,这里的氛围非常现代,将Block722 固有的斯堪的纳维亚风情和有机极简主义与日本建筑的影响融为一体。这种对日本的致敬通过设计清新简洁、近乎简洁的线条展现出来,这些线条平衡了材料的自然、触觉和整体工艺丰富的方法。
A path down a slope from the main road leads visitors to the residence’s entrance. The complex’s size is cleverly broken down into smaller volumes, which are interconnected through circulation routes and in-between spaces - some indoors and some open-air. The main home is divided into two low buildings linked by a semi-enclosed area with a water feature. The design merges natural materials often used in the local vernacular, such as wood and stone. At the same time, the atmosphere is distinctly contemporary, blending Block722’s inherent Scandinavian sensibility and organic minimalism with Japanese architecture influences. This nod to Japan unfolds through the design’s refreshing simplicity of clean, almost austere lines that balance the materials’ natural, tactile nature and the overall craft-rich approach.
希腊强烈的阳光有助于定义形状和表面,利用纹理材料,建筑师在建筑的内部和外部都利用了环境的感觉和节奏。光线的旅程和客户一整天的习惯导致了室内的空间安排。每个路段和路线都经过精心规划,通过融合内外、自然和人为的视觉旅程和空间叙事来支持功能和框架远景。该设计旨在增强慢生活,从岛上的生活方式中汲取灵感。
The powerful Greek sunlight helps define shapes and surfaces, playing with the textured materials, as the architects drew on the feel and rhythm of the context for both interiors and exteriors. The journey of light and the clients’ habits throughout the day led to the spatial arrangement inside. Each section and route are carefully planned to support functionality and frame vistas, through visual journeys and spatial narratives that blend inside and outside, the natural and the human-made. The design seeks to enhance slow living, taking its cues from the island’s lifestyle.
Block722 在整个施工过程中与当地工匠合作,将专业的制造技能应用于房屋中的大量元素。这适用于高端建筑细节和家具,其中大部分是专门为这个项目定制和制作的,使用大理石、木材、石头和水磨石。所有部件共同构成了 Block722 的 ANATA 家具系列。这种方法富含艺术性和当地采购的天然材料,将设计提升为真正定制的住宅瑰宝。中性、大地色占主导地位,质量优先于数量。
Block722 collaborated with local artisans throughout the construction, applying expert manufacturing skills to a large array of elements in the house. This applies to both high-end architectural details and furniture pieces, the majority of which are bespoke and created specifically with this project in mind, using marble, wood, stone, and terrazzo. All the pieces together form Block722’s ANATA furniture collection. This approach, rich in artistry and locally sourced, natural materials, elevates the design into a truly custom-made residential gem. Neutral, earthy colors dominate, and quality is prioritized over quantity.
艺术品在整体构图中也至关重要,该项目现在拥有希腊艺术家 Pantelis Chandris 令人印象深刻的 2.8 x 1.5m 雕塑。这件特别委托的作品位于起居室,与建筑设计并行开发,精美地展示了度假胜地的规模和学科的完美结合。
The artwork was also crucial in the overall composition and the project now holds an impressive 2.8 x 1.5m sculpture by Greek artist Pantelis Chandris. The specially commissioned piece sits in the living room and was developed in parallel to the architectural design, beautifully displaying the retreat’s perfect marriage of scales and disciplines.
▽底层平面图,Basement floor plan.
▽平面图,floor plan.
▽剖面图,Elevation.
▽立面图,Section.
Architects: block722
Area: 280 m2
Year: 2022
Photographs:Ana Santl
Manufacturers:Novamix,Caneplex,CelineWright,ChrysaGeorgiou, Cocoon, Dedon, Desiree, Ethimo, Frama, Grok, Kruger, Kusiner, Libeco, Maru Meleniou, NANI MARQUINA S.L, Nikos Haritos, Olivelab, Studio Natural, Zanat
Lead Architect: Sotiris Tsergas
Lighting Consultant: Skia Lighting
Landscape Consultant: Outside landscape architecture
景观规划设计
25.18 万条内容 · 282 人订阅
深圳问山叠水驿及周边景观设计
同济原作设计工作室 场地初见 深圳环西丽湖绿道(一期)全长约3.5公里,在一级水源地保护范围外圈与各类城市用地间纵向延展。本项目的探索始于对这条线性压缩空间的一些放大的尝试。绿道的北段已然深入山林,在林地范围线、基本农田与水源保护范围线的空隙之中,我们发现了这片由一些杂乱工棚占据的硬质场地。
