背景概述
From "an import hub of the Pearl River Delta rail transportation" to the living room and portal hub economic zone of the Guangdong-Hong Kong-Macao Bay Area, Guangzhou South Railway Station has undergone six adjustments and upgrades in planning and positioning during the past fifteen years. In the future, the core area of Guangzhou South Railway Station will also be developed into a worldwide large TOD new city, which will transform "people flow " into "talent flow, information flow, capital flow, and business flow".
Located in the core area of Guangzhou South Railway Station, Faxian Plaza is 150 meters away from Shibi Station of Guangzhou Metro Line 2. The site is bordered by South Railway Station South Road in the southeast, Shizhou Middle Road in the northeast, which is facing Guangzhou South Railway Station with convenient transportation and the green ecological square in the central axis of South Railway Station in the north, boasting rich landscape resources and open view.
概念生成
As the urban road interface of Shizhou Middle Road of Guangzhou South Railway Station, the architects designed the project with the area development plan and the surrounding building clusters in mind, making full use of the landscape resources around the project to make it a new type of office building that is ecological, energy-saving and environmentally friendly, and providing an extendable shared space for the site.
The overall layout of the project breaks through the rectangular plan pattern of a traditional tower office and creates a unique sculptural image of a business office building by rotating the two square-shaped blocks between the high and low areas, creatively solving the problems of building orientation and high plot ratio under the constrained site conditions. At the same time, the naturally formed breezeway corridor provides better natural ventilation for the office space on each floor and provides multi-level garden platforms for the office, creating a unique sense of place.
The rotating and stacking of high and low blocks better realize the dialogue between buildings and urban space, and greatly enliven the urban nodes, echoing the city skyline and making them elements of the urban landscape.
形体生成示意图
Following the principle of high efficiency and functionality, the project adopts a modular approach to the combination of structure and space, using a high-strength steel structure as the overall skeletal framework of the building, complemented by clear and clean main materials such as glass curtain walls and metal panels, to form a recognizable building fa?ade.
In response to the needs of space lighting, ventilation, and heat insulation, the exterior of the building is given a skirt with ecological and energy-saving functions, and the form and performance are optimized on the basis of modulized design, making it a sun-shading component for the interio r. The transparent surface of the building further expands the indoor viewing area and provides effective noise reduction for the office environment while maintaining visual openness.
The curtain wall surface of the project adopts concealed opening fan, which solves the problem of natural ventilation while setting vertical sun-shading louvers on the east and west sides, effectively reducing the energy consumption of the building.
品控细节
The details of the fa?ade are designed rationally and restrainedly, and the vertical lines emphasize the upward trend to make the overall building mass more towering and upright. The semi-permeable vertical sunshade louvers on both sides bring a change of texture and density to the whole building facade.
业态分布
The bottom floor of the building is commercial office space, and the 3rd to 28th floors of the tower are standard office floors (of which the 4th and 15th floors are refuge floors), which can be flexibly divided into office spaces of different sizes according to actual usage requirements, providing efficient, flexible, comfortable and convenient office and supporting functional spaces for the moving-in enterprises.
结语
With the continuous development and improvement of the industrial supporting system of Guangzhou South Railway Station, office buildings as the development carrier of modern industry, Guangzhou South Railway Station Faxian Plaza organically blends modern architecture with the urban landscape, making the architecture an important constituent element of the urban landscape and responding to the needs of urban development with an open and shared scene.
区位图
总平面图
平面分割图
剖面图
局部剖切轴测示意图(遮阳百叶)
立面开启扇、遮阳百叶示意图
650X650mm网格下的立面模数
尺度宜人的入口大堂空间
功能分区图
项目名称: 广州南站发现广场
建筑团队: XAA建筑事务所
主创建筑师: 詹涛
设计团队:田望、余庆、杨涛、徐泳辉、陆思德、谢志权、赵玉娟
项目详细地址: 广东省广州市番禺区广州南站
项目设计时间:2012年
项目完成年份:2021年
用地面积(平方米):4220 平方米
建筑面积(平方米): 505091 平方米
业主单位:广州市奥耀企业管理咨询有限公司
建筑施工图:广州瀚华建筑设计有限公司
幕墙设计:同程建筑技术有限公司
摄影师:吴荫天
免费1人已点赞
公共建筑设计
返回版块51.18 万条内容 · 448 人订阅
度假酒店:多层"U "形对称布局若昂-佩索阿是一个热带的沿海城市,它的城市结构规则而平坦,沿着广阔的旅游海滩发展。巴拉酒店有126个房间,面积不等--22、32、52和72平方米--位于一个面向海滩的街区,可从卡布兰科大道进入。这条街道是一条与海滩平行的车辆轴线,是一条自行车道,也是步行者、运动员和流行节日的休闲空间。 Joao Pessoa is a tropical, coastal city with a regular, flat urban fabric that develops along an extensive tourist beach. The Ba'ra hotel, with 126 rooms of variable areas -22, 32, 52, and 72m2- is located in a block facing the beach and accessed from Avenida Cabo Branco. This street is a vehicular axis parallel to the beach, a cycle path, and a recreational space for walkers, athletes, and popular festivals.
只看楼主 我来说两句 抢板凳从“珠三角轨道交通重要枢纽”到粤港澳大湾区客厅与门户枢纽经济区,广州南站在十五年间经历六次规划定位的调整升级。未来,广州南站核心区还将打造成世界性的大型 TOD 新城,拟将“人流”,转化为“人才流、信息流、资本流、商务流”。
