土木在线论坛 \ 建筑设计 \ 公共建筑设计 \ 现代简约设计风格校园
现代简约设计风格校园
发布于:2023-05-08 09:27:08 来自:建筑设计/公共建筑设计 [复制转发]
孩子们在学校里度过了相当长的成长时期,因此建筑环境是塑造他们发展方式的关键。由于学校被正确地称为学生的 "第二个家",家必须是一个舒适、成长、安全和授权的地方。此外,不管是小孩子还是青少年,他们在自己经常去的地方看中一个小角落、旮旯或壁龛,并把它作为自己的 "位置",在那里无忧无虑地度过几个小时,这是很常见的。
Children spend a considerable duration of their formative years in a school, and hence the built environment is key in shaping their developmental approach. As a school is rightly called a student’s “second home”, home must be a place of comfort, growth, safety, and empowerment. Additionally, whether a small child or an adolescent, it is not uncommon for them to fancy a small corner, nook or niche anywhere in a place that they frequent and to make it their “spot” where they can spend hours carefree.
学校的设计旨在创造一个和谐和刺激的学习环境,优先考虑学生的参与和幸福感。虽然整体的体量看到了一种 "俄罗斯方块堆叠 "的情况,但块状的和谐组成散发出一种支配性的但又是保护性的感觉。外墙在其周围显得很骄傲,但进入后,变成了一个C形的计划,绕过了球场和操场。它的设计采用了现代和简约的方法,创造了一个圆滑和有凝聚力的设计。建筑的jali立面,用红色突出显示,为设计增加了一个特色元素。从功能上讲,它可以实现交叉通风和令人兴奋的光影游戏,随着一天的进展,太阳的运动而充满活力。
The school's design aims to create a harmonious and stimulating learning environment that prioritizes student engagement and well-being. While the overall massing sees a “tetris-stacking” of sorts, a harmonious composition of blocks exudes a dominative yet protective sense. The facade seems proud in its surrounding but on entering, becomes a C-shaped plan, skirting the field and playground. It is designed with a modern and minimalistic approach to create a sleek and cohesive design. The building's jali facade, highlighted in red, adds a characteristic element to the design. Functionally, it enables cross ventilation and an exciting play of light and shadow that is dynamic with the movement of the sun as the day progresses.
设计中包含了几个休息空间,如种植的庭院、较小的非正式走廊,以及供儿童在教室外进行非正式交流的游戏区。内部的景观庭院提供了一个欢迎和开放的氛围。这些空间被战略性地放置在整个建筑中,以提供内部和外部空间之间的连接和整合感。景观被小心翼翼地融入到设计中,绿色植物无缝地融入到建筑的整体美学中。
The design incorporates several break-out spaces either as planted courtyards, smaller informal corridors, and play areas for children to informally interact outside the classroom. The internal landscaped courtyards provide a welcoming and open atmosphere. These spaces are strategically placed throughout the building to provide a sense of connectivity and integration between the interior and exterior spaces. The landscape is carefully integrated into the design, with greenery seamlessly blending into the building's overall aesthetic.
形状图
三层高的切口是一个突出的设计特点,用鲜艳的色彩加以强调。从建筑的外立面或内立面看去,由于它们两侧有细长的悬臂,它们似乎创造了独特的腔室,打破了原本平缓的外立面的单调性。由于它们相对于上层建筑的表面穿孔的规模,它们创造了一种宏伟和开放的感觉,同时为整个建筑提供了充足的自然光和通风。
The triple-height cut-outs are a prominent design feature highlighted in vibrant colors. When viewed from the outer or inner facade of the building, since they have slender cantilevers on either side, they seem to create unique chambers that break the monotony of the otherwise flushed facade. Due to their scale with respect to the surface punctures on the superstructure, they create a sense of grandeur and openness while providing ample natural light and ventilation throughout the building.
大胆的色彩使用,独特的设计特点,以及内部和外部空间的无缝整合,为学校的现代、动态,以及因此而产生的 "年轻 "美学做出了贡献。
The use of bold colors, unique design features, and seamless integration of interior and exterior spaces contribute to the school's modern, dynamic, and hence “young” aesthetic.
项目图纸
平面图
平面图
平面图
平面图
平面图
平面图
平面图
平面图
项目信息
建筑师:Abin Design Studio
地点:印度
面积:10000 m2
年份:2022
摄影:Niveditaa Gupta
全部回复(4 )
  • co1490678108228
    简约大气
    2023-05-26 11:45:26
  • nageshijie
    nageshijie 板凳
    图文并茂,感谢分享!!!
    2023-05-11 08:45:11
公共建筑设计
51.18 万条内容 · 448 人订阅
扎哈事务所的又一作品:三个相互连接的塔楼,组成的圆形建筑——武汉·泰康金融中心
扎哈-哈迪德建筑师事务所设计的武汉泰康金融中心有三座相互连接的塔楼 three interconnected towers shape zaha hadid architects' taikang financial center in wuhan 闸北区泰康金融中心正在建设中 ZHA’S TAIKANG FINANCIAL CENTER IS UNDER CONSTRUCTION
