土木在线论坛 \ 园林景观 \ 园林景观实景 \ 四象限四空间 | 墨西哥·恩索之屋
四象限四空间 | 墨西哥·恩索之屋
发布于:2023-05-06 09:16:06 来自:园林景观/园林景观实景 [复制转发]
当开始研究这栋小房子时,经过全面的历史研究,得出的结论是,在墨西哥很少有像瓜纳华托这样具有强烈的建设性特征的地方。这清楚地反映在它的建筑、厨房用具、水渠、传说,甚至是这里的英雄,如皮皮拉,他身背一块巨石,这样保守派的子弹就不会打到他的军团里。
When work began on this small house and after a thorough historical research, it was concluded that there are few places in Mexico with a constructive identity as strong as Guanajuato. This is clearly reflected in its architecture, kitchen utensils, aqueducts, legends, even in its heroes suchas the Pípila, who carries a huge rock on his back so that the bullets of the conservatives would not reach his regiment.
在这个国家的这个地区,石头是深深扎根于任何形式的文化表达中的一个元素。出于这个原因,这个建筑作品的材料选择非常容易和自然。此外,附近有个材料库和有能力的劳动力;鼓励人工和环境之间的对话。整个建筑群是在十字形规划的基础上组织起来的;因此,空间被定义为路径的石头小巷的十字架分成了四个象限,框住了所有的时刻,并将象限与象限分开。
In this area of the country, stone is an element deeply rooted in any form of cultural expression. For this reason, the material for this architectural piece was very easily and naturally chosen. In addition, there was a materials bank and capable labor nearby; a dialogue of respect between the artifice and its environment was encouraged. The entire complex is organized on the basis of a cruciform plan; thus, the space is divided into four quadrants by a cross of stone alleys defining the paths, framing all moments, and separating one quadrant from the other.
一经划分,每个象限都被赋予了“使命”:右下角象限是第一象限,在居民到达时接待他们;它的使命是容纳地方花园,加强、保护和欢迎生物和人类。
Once divided, a "vocation" was assigned to each of these quadrants: the lower right quadrant, which is the first one, receives the inhabitants upon their arrival; it has the vocation of housing an endemic garden that reinforces, protects, and welcomes living beings and humans.
第二象限放汽车;在建设过程中对树木进行了特别的照顾,因为它们可以为汽车提供阴凉,以保护车辆免受阳光照射。
The second quadrant hosts the cars; special care was taken to the trees during construction, as they would provide shade to protect the cars from the sun.
最重要的是,一堵长长的、几乎没有弧度的石墙保护着入口,挡住了向屋内看的视线,并强调了背景山体的水平存在。
To top it off, a long, barely arched stone wall protects the entrance, avoids looking inside the house, and emphasizes the horizontal presence of the mountain in the background.
第三象限是一室一厅的房子;公共空间与私人空间被一个包含浴室、更衣室和服务区的单一体量所分隔,这打破了开放的平面图。
In the third quadrant is the one-bedroom house; the public spaces are separated from the private ones by a single volume containing bathrooms, dressing room, and service area, which breaks with the open floor plan.
这些空间的分散迫使人们在空间之间进行永久的朝圣;它使你与大地、空气和山峰接触,仿佛它是一座古老的修道院,框住了景观,但同时也形成了它的自然部分。
In the fourth quadrant is the office; this is the only visibly prominent vertical element that contrasts with the horizontality of the landscape and the rest of the elements, seeking with this gesture to flirt with the iconic volumes of the Santa Brígida mine in Mineral de Pozos. The dispersion of these spaces forces a permanent pilgrimage between spaces; it makes you come into contact with the earth, the air, and the mountain as if it were an ancient monastery, framing the landscape but at the same time forming a natural part of it.
▽屋顶平面图
▽建筑楼层平面图
▽西立面
▽北立面
▽东立面
▽南立面
PROYECT DESCRIPTION:
Architects: HW STUDIO
Website: www.hw-studio.com
Contact e-mail: hwarcstudio@gmail.com
Facebook: @hwstudioarquitectos
Instagram: @hwstudioarq
Google maps link: https://goo.gl/maps/5trwbJpnUQJJK7XYA
Completion Year: 2022
TECHNICAL INFO:
Leads Architects: Rogelio Vallejo Bores
Architects: Oscar Didier Ascencio Castro,Nik Zaret Cervantes Ordaz
Clients: Cem Turgu y Adriana Alegria
Budget: 300,000.00 USD
PHOTO CREDITS:
Photo credits: Cesar Bejar
Photographer's website: www.cesarbejarstudio.com
Video: Montse Roma
园林景观实景
37.75 万条内容 · 296 人订阅
韩国文人园林——潇洒园
作为文化强国,我们很容易忽略身边相对弱势的文化。韩国园林就是如此,韩国和日本一样都继承了我国的唐风宋月,但鲜有人去了解,那天和网友聊天被问到韩国园林一时除了景福宫和雁鸭池说不出第三个来,后来回想起潇洒园,就分享给大家吧。 潇洒园是朝鲜王朝中期典型的文人园林,是梁山甫退隐后的居所,园林中充满了周敦颐和陶渊明的理想。即便抛开文化,单从审美角度看也很不错,三间建筑错落布置,这些空间都是当时的儒家文人谈论学问和风月的地方。园林位于一个山谷的西侧,临流而建,只是今日溪水太小,少了点感觉。值得一提的是园林水系是人工和自然交融在一起,尽显山水的秀丽。
