土木在线论坛 \ 建筑设计 \ 公共建筑设计 \ 德国园区多层办公大楼
德国园区多层办公大楼
发布于:2023-05-04 08:54:04 来自:建筑设计/公共建筑设计 [复制转发]
平面图
在2016年完成物流和生产的第一个建设阶段后,机械工程公司乌尔曼的总体规划的下一步于2021年初完成。
After the completion of the first construction phase for logistics and production in 2016, the next step in the master planning for the mechanical engineering corporation Uhlmann was completed at the beginning of 2021.
一座四层楼的办公大楼为公司在劳普海姆的园区提供了约300名员工的空间。该建筑直接位于Uhlmannstra?e,是2013年总体规划的基础设计原则--"蜿蜒 "的一个重要组成部分。它与物流和生产大楼一起,形成了一个300米长的正面,从而标志着参观者对园区的代表性介绍。
A four-story office building provides space for about 300 employees on the company’s campus in Laupheim. Located directly on Uhlmannstra?e, the building is an important building block of the “meander,” the foundational design principle of the master plan from 2013. Together with the logistics and production building, it forms a 300 m long front and thus marks the representative introduction to the campus for visitors.
立面图
可通过窗扇用于自然通风的玻璃表面与白色玻璃制成的不透明面板的结合,确保了该建筑拥有一个节能的外立面。同时,银色阳极氧化铝鳍片和玻璃开口的相互作用,占据了物流和生产建筑的形式语汇。
A combination of glass surfaces that can be used for natural ventilation through window sashes, and opaque panels made of white glass, ensures that the building has an energetically economical fa?ade. At the same time, the interplay of silver anodized aluminum fins and glazed openings take up the formal vocabulary of the logistics and production building.
在内部,正交的办公室平面图、两个由裸露的混凝土制成的核心部分的严格排列以及外墙网格的规则性与KINZO设计的工作环境形成了有趣的对比,后者的特点是俏皮的形状和强烈的色彩点缀。
Inside, the orthogonal office floor plan, the rigorous aligning of two cores made of exposed concrete, and the regularity of the fa?ade grid stand in interesting contrast to the work environments designed by KINZO, which are characterized by playful shapes and strong touches of color.
项目信息
建筑师:Barkow Leibinger, Kinzo
地点:德国
面积:68570平方英尺
年份:2020
摄影:David Franck, Philip Kottlorz
公共建筑设计
51.18 万条内容 · 448 人订阅
江三迪曼哈顿行政中心
三迪曼哈顿行政中心
