土木在线论坛 \ 建筑设计 \ 公共建筑设计 \ 木结构:体育场馆
木结构:体育场馆
发布于:2023-03-31 14:58:31 来自:建筑设计/公共建筑设计 [复制转发]
受冰河时代末期米苏拉灾难性洪水形成的帕卢斯地区起伏景观形式的启发,这座拥有 4,000 个座位的多用途爱达荷中央信用合作社 (ICCU) 竞技场被设计为通往大学的戏剧性门户爱达荷校园。它是大学篮球项目的举办地,也是各种活动的聚集地,包括体育赛事、音乐会、集会和校园项目。
Inspired by the undulating landscape forms of the Palouse region, formed by the cataclysmic Missoula floods at the end of the Ice Age, the 4,000-seat multi-use Idaho Central Credit Union (ICCU) Arena was designed as a dramatic gateway to the University of Idaho campus. It serves as the home for the University’s basketball program and a gathering place for a variety of activities including athletic events, concerts, convocations, and campus programs.
新设施提供了亲密的观众体验,展示了该地区的独特特征以及与可持续自然资源的深厚联系。大量的木材设计和对自然光的大量使用代表了对传统钢和混凝土运动场类型的重大突破。该竞技场的设想是通过与区域林业和木制品行业合作伙伴的合作,促进可持续木材设计的创新。
The new facility provides an intimate spectator experience, showcasing the region’s unique characteristics and deep connections to sustainable natural resources. The mass timber design and abundant use of natural light represent a significant break from the traditional steel and concrete sports arena typology. The arena was envisioned to promote innovation in sustainable wood design, through collaboration with regional foresters and wood product industry partners.
该项目的形式和物质表达创造了一种植根于爱达荷州历史并展望未来的地方感。它是一个旨在庆祝运动成就的地方,并通过展示在胶合层压大跨度桁架中创新使用当地采伐的木材,以学习实验室的形式为大学林业和工程系的学生提供教育催化剂,以及销钉层压木材 (DLT) 结构元件。
The project's formal and material expression creates a sense of place rooted in Idaho’s history that looks toward the future. It is a place meant to celebrate athletic achievement and serves as an educational catalyst in the form of a learning laboratory for students in the University’s forestry and engineering departments by showcasing the innovative use of locally harvested timber in glue-laminated long-span trusses, and dowel-laminated-timber (DLT) structural elements.
从悬浮的朝西入口门廊向后延伸,屋顶分开,在北大厅上方形成重叠的轮廓形式,唤起了帕卢斯蜿蜒起伏的山丘轮廓。向东,屋顶轻轻地环绕着练习场并与地面相连。外侧壁被设计成被富有表现力的胶合层压结构所包围。
Extending back from the levitated west-facing entry porch, the roof splits apart to create overlapping contoured forms above the north concourse, invoking the sinuous rolling hill contours of the Palouse. To the east, the roof gently wraps down around the practice court and connects with the ground plane. The exterior side walls were designed to be embraced by the expressive glue-laminated structure.
木炭染色雪松墙的起伏纹理从该地区早期的宅基地结构中汲取灵感,并与光滑的预制梁并列。屋顶平面之间的开放裂缝充满了半透明的玻璃,为整个表演场提供漫射的自然光,全玻璃的木幕墙提供了进出竞技场的视野,那里的动作总是在展示。外露和起伏的花旗松屋顶结构为玩家和顾客创造了一种温暖和包容的体验。
The undulating texture of the charcoal-stained cedar walls draws inspiration from early homestead structures in the region and stands in juxtaposition to smooth fabricated beams. The open fissures between the roof planes are infilled with translucent glazing to provide diffused natural light throughout the performance court and a fully glazed wood curtainwall provides views in and out of the arena where the action is always on display. The exposed and undulating Douglas fir roof structure creates a warm and embracing experience for players and patrons alike.
为了实现木结构的诗意之美,必须将机械和电气系统集成到结构本身中。主要结构采用张开的门式桁架和重复的王柱桁架系统。门式桁架和特大柱式桁架采用双层胶合顶索设计,在结构之间形成间隙空间,用作“公用高速公路”以隐藏机械和电气部件。在竞技场的西侧,公用设施被隐藏在集成到运动办公室、更衣室和校友中心的拱腹后面,后者提供了一个俯瞰主球场的上层特殊活动室。
To realize the poetic beauty of the wood structure it was imperative to integrate the mechanical and electrical systems into the structure itself. The primary structure utilized a splayed portal truss and a repetitive king post truss system. The portal truss and king post trusses were designed with double glue-laminated top cords creating an interstitial space between the structure that was used as a “utility highway” to conceal mechanical and electrical components. On the west side of the arena, utilities were concealed behind soffits integrated into the athletic offices, locker room, and alumni center which provides an upper-level special event room overlooking the main court. Looking to the west patrons can also experience the Vandal terrace under cover of the robust cantilevered roof with views out to the rolling hills of the Palouse where the experience of place and community comes full circle.
区位图
平面图
剖面图
爆炸分析图
建筑师:Opsis Architecture
地点:美国
面积:66186平方英尺
年份:2021
  • 加倍努力
    加倍努力 沙发
    学习了木结构的设计案例:体育场馆,木炭染色雪松墙的起伏纹理从该地区早期的宅基地结构中汲取灵感,并与光滑的预制梁并列。屋顶平面之间的开放裂缝充满了半透明的玻璃,为整个表演场提供漫射的自然光,全玻璃的木幕墙提供了进出竞技场的视野,那里的动作总是在展示。外露和起伏的花旗松屋顶结构为玩家和顾客创造了一种温暖和包容的体验。多谢了。
    2023-04-02 08:32:02
  • lijiawei411
    lijiawei411 板凳
    2023-03-31 15:52:31
公共建筑设计
51.18 万条内容 · 448 人订阅
开启当代“一千零一夜”的奇幻建筑之旅【环球观筑】
  项目主题
