奇妙的游戏云结构
Fantastic Game Cloud Structure
在伊斯坦布尔市出现了奇妙的游戏云结构。
它们是巴基尔科伊区购物中心Marmara Forum屋顶公园上一个新的露天游乐场的标志性建筑。
Fantastic play cloud structures have arisen in the city of Istanbul.
They are the iconic landmarks of a new open-air playground on the roof park of Marmara Forum, a shopping centre in the Bakirk?y district.
“云”游乐场
Cloud playground
随着一天中日光的变化,云朵的窗户会神奇地变换颜色。
虽然此刻一片寂静,很快,孩子们兴奋的欢声笑语传遍整个场地。
The windows of the clouds magically change colours as daylight changes throughout the day.
While in silence at the moment, soon the happy sounds of excited children will be covering the site.
夜晚下的游乐场
A playground at night
这是Carve为Marmara Forum屋顶露台上的游乐场设计,该露台高于街道24米。
Carve was asked to make a design for the playground on the rooftop terrace of Marmara Forum, 24 metres above street level.
平面图
Site plan
露台和美食广场的重新改造,其目的是将改造后的 Forum成为一个著名的购物中心,它需要一个与这种吸引力相匹配的新游乐场。
The terrace and the food court had been renovated to re-establish the Forum as a prominent shopping centre, and it needed a new playground that matches that allure.
效果图
Effect pictures
触摸云层的体验
The Experience of Touching the Clouds
CarveCarve旨在通过这些结构重现触摸云层的体验,这些结构离地面约八层楼。
Carve aimed at reproducing the experience of touching the clouds through these structures, being about eight storeys above the ground.
设计概念
Design concept
云结构
Cloud structures
此外,考虑到露台的有限空间以及对遮阳和避雨的需求,设计的出发点之一是考虑具有大体积的高大结构:从内部完全可以玩耍。
Also, given the limited space of the terrace along with the need for shade and cover from the rain, one of the starting points was to think of tall structures with big volumes: fully playable from the inside.
设计概念
Design concept
游乐场由四个区域组成,以满足不同年龄组的需要:从小到大。
The playground consists of four areas that cater for different age groups: from small to tall.
四个区域
Four areas
这里有一个幼儿空间、一个攀爬圆顶、一个更大的球体组合和一个接近8米高的带有内部滑梯的攀爬塔。
There is a toddler space, a climbing dome, a larger ensemble of spheres and a near eight-metre tall climbing tower with an internal slide.
梦幻般的游乐场
A dreamy playground
泡泡的内部完全由游戏元素组成。
The interior of the bubbles is completely furnished with play elements.
五颜六色的“泡泡”
Colorful "bubbles"
孩子们可以在吊床森林中休息、攀爬、滑行,还可以从窗后眺望城市天际线体验高度。
Children can climb, slide, lounge in a forest of hammocks and experience height from behind a window looking at the city’s skyline.
云结构里的空间
Space in the cloud structure
设计到施工上的挑战
Design to Construction Challenges
在过去,游乐场大多是由当地市政当局促成的,而现在往往是商业方在这个(半)公共和自由进出的游乐空间领域采取主动。
那些真正敢于为儿童提供一些令人惊叹的东西的一方,Marmara Forum游乐场就是此类倡议的一个很好的例子。
Where in the past playgrounds were mostly facilitated by local municipalities, nowadays often commercial parties are the ones to take initiative in this field of (semi)public and freely accessible play spaces.
Parties that really dare to offer children something spectacular. The playground of Marmara Forum is a fine example of such an initiative.
”泡泡“窗户内外
"Bubble" inside and outside the window
在设计和工程过程中有许多技术挑战。
例如,考虑到特别是最大的八米高的建筑的尺寸和现有屋顶的负载限制。
There were many technical challenges during the design and engineering process.
For example, considering the size of in particular the largest eight-meter tall construction and the load limits of the existing roof.
施工现场
Construction site
但这个问题被创造性地解决了,通过在建设性点之上设计一个自支撑结构,同时分散荷载。
This issue was creatively solved by designing a self-supporting structure on top of a constructive point, and at the same time, spreading the loads.
图纸
Drawing
多彩的“泡泡”结构
Colorful "bubble" structures
所有游戏云的球体都是由六边形和五边形的面板构成,总共有275块不同的面板。
The spheres of all the play clouds together are constructed out of hexagonal and pentagonal panels, 275 different panels in total.
多彩的”泡泡“
Colorful "bubbles"
从街道上往下看24米,你可以看到阳光在白色的游戏结构上闪闪发光,而二向色窗则为“泡泡”的内外增色不少。
Looking up from street level to 24 meters below you can see the sun glitter on the white play structures, while the dichroic windows colour the in- and outside of the structures.
阳光下的球体
The orb in the sun
到了晚上,"泡泡 "就成了一个迷人的灯光奇观。光线从窗框后散发出来,将泡泡变成一个可以从周围看到的灯塔。
At night the Bubbles make an intriguing spectacle of lights. Light radiates from behind the window frames turning the Bubbles into a beacon that can be seen from the surroundings.
夜晚下的灯光景观
The light landscape at night
项目信息
设计:Carve
项目地点:土耳其
设计年份:2019
建成年份:2019-2020
摄影师:Asli Dayioglu
游乐场制造商设备:Playdium
Design: Carve
Project Location: Turkije
Design year: 2019
Year Built: 2019-2020
Photographer: Asli Dayioglu
Manufacturer of playground equipment: Playdium
素材来源: archdaily.com、landezine,由园景人转译
网址:http://www.cnlandscaper.com
注:部分图片来源于 archdaily.com、landezine ,其他来源于网络, 图文系园景人 (ID: xyzwin) 原创整理, 欢迎转载, 转载请输入“转载”授权,请注明来源!
景观规划设计
返回版块25.18 万条内容 · 282 人订阅
在“奇幻丛林”中游逛 | 青岛未来城万科广场转自公众号:CLOU Architects CLOU柯路建筑受万科委托,负责全新的青岛未来城万科广场四层中庭的室内设计。位于青岛市北区的未来城万科广场是青岛老城区城市商业更新的重要布局之一,将为周边商圈及整个老城区注入新的活力。 CLOU architects was commissioned by Vanke to design the fourth ?oor atrium of the newly opened Future City Mall in Qingdao. Located in Qingdao's northern district, Vanke Future City is a brand-new shopping and leisure destination devoted to the mingling of aesthetics, creativity and social experiences, hoping to bring a fresh vitality to Qingdao’s old town and its surroundings.
只看楼主 我来说两句 抢板凳来自 土木在线APP
