土木在线论坛 \ 建筑设计 \ 居住建筑设计 \ 住宅设计:流动的曲线、极简、纯白立面
住宅设计:流动的曲线、极简、纯白立面
发布于:2023-02-02 13:32:02 来自:建筑设计/居住建筑设计 [复制转发]
该项目位于西班牙Antonio Ferrandis街,是PP Quatre Carreres的一部分。该地理位置特别优越,因为它位于城市的南部边缘,将两个完全相反的地块和规模分开,延伸至阿尔布费拉自然公园的大片果园,并在视觉上延续到大海。
This project is located on Antonio Ferrandis Street and is part of the P.P. Quatre Carreres. The location is especially privileged because it is located on the southern edge of the city, separating two radically opposite plots and scales, admiring the large expanse of an orchard that extends to the Albufera Natural Park and with visual continuity to the sea.
▲场地平   面   图
该项目建   立在一个矩形几何地块上。   目前的规划确定了可建造的体量,两座大约27 x 17米的塔楼,它们的设计方案相同,主体由地下室连接地面和一层。
The project is built on a plot of rectangular geometry. The current planning defines the buildable volume, in such a way that two towers of approximately 27 x 17 m are executed, identical in their program and formal resolution, joined by a basement body on the ground and first floors.
▲东北立面图
▲剖面图
该项目本质上是住宅,包括位于地面和一楼的三级建筑区域,其朝向与城市空间相连。其余的楼层由100个住宅区域占据。底层是社交空间,通过连廊连接通向游泳池和儿童游乐区的路线。伴随着入口路线的垂直花园脱颖而出,在果园和城市之间的过渡中闪烁着光芒。
The program, essentially residential, contains a tertiary building area located on the ground and first floor, whose orientation is connected to the urban space. The rest of the floors are occupied by the program of 100 dwellings. The ground floor is configured as a space for social relations, generating a route through arcaded spaces and where the swimming pool and children's play area are located. The vertical garden that accompanies the entrance route stands out and winks at the transition between the orchard and the city.
▲细节图-带露台立面
▲细节图-无露台立面
使用一种基本的元素组成原理,打造出一个令人瞩目的、清晰的、形式上极简的建筑。每个体量都是由一个严谨的矩形平面生成的,该平面在每个顶点扩展和增长,为每个房子创建露台。立面是曲面连续的,包含了露台空间,遵循着具有建筑几何特征的曲线。为了使起伏的表面具体化,使用了白色铝板复合材料。
Using an elemental compositional mechanism, a resounding, clear, and the formally simple building has been sought. Each of the volumes is generated by a rigorous rectangular plan that expands and grows at each vertex, creating terraces for each house. The facade is conceived as a continuous skin that embraces these terraced spaces following a curved line that characterizes the geometry of the building. To materialize the undulating surfaces, white aluminum composite plates are used.
由于楼层高度城市规划参数的限制,最后几层建筑层高适当减小,构成了综合体的最终外观。
The alternation of the floors in height of these growths, together with the reduction of the dimensions of the building in the last floors conditioned by urban planning parameters, configures the final appearance of the complex.
▲地面层平面图
▲首层平面图
▲2层平面图
▲3、5、7、9层平面图
▲4、6、8层平面图
▲13层平面图
▲14层平面图
▲15层平面图
▲-1层平   面图
▲-2层平面图
▲东南立面图
▲西北立面图
▲西南立面图
▲剖面图
建筑师:NAC Arquitectos
地点:西班牙
面积:273102平方英尺
年份:2020
摄影:Alejandro Gómez Vives
  • lijiawei411
    lijiawei411 沙发
    2023-03-08 14:54:08
  • lijiawei411
    lijiawei411 板凳
    2023-02-07 18:34:07
居住建筑设计
28.74 万条内容 · 423 人订阅
建筑立面后期控制手册-公寓及配套
来源:网络  如有版权问题,请联系删除
