土木在线论坛 \ 建筑结构 \ 混凝土结构 \ 多层公寓:弧形起伏阳台立面设计
多层公寓:弧形起伏阳台立面设计
发布于:2022-12-28 11:22:28 来自:建筑结构/混凝土结构 [复制转发]
住宅项目 "城市公园Lehen "位于进入萨尔茨堡的主要道路之一。这个地方的独特之处在于各种结构的互动。毗邻的Ignaz-Harer-Stra?e大街是一个人流量很大的城市核心区,可以容纳大量的游客、路人和居民。该物业的另一侧是一个安静的公园,被用作整个社区的娱乐区。此外,该地块标志着大规模街区开发和松散的异质定居结构之间的界限。
The residential project "City Park Lehen" is located on one of the main roads into Salzburg. The unique characteristic of the location is the interaction of a diverse range of structures. Lending itself to vast number visitors, passers-by, and residents, the adjacent Ignaz-Harrer-Stra?e is a highly frequented urban core zone. On the other side of the property is a quiet park, used as a recreation area for the entire neighborhood. In addition, the site marks the boundary between large-scale block developments and loose, heterogeneous settlement structures.
设计的目的不是在道路和城市公园之间建立一个不透水的屏障,而是创造一个具有大型开口的结构,这将提高公共空间的质量,并允许与公园的视觉连接。
Rather than building an impermeable barrier between the road and the city park, the aim of the design is to create a structure with large openings which will enhance the qualities of public spaces and allow visual connections to the park.
该结构还实现了高度调节,模仿了从城市规模的街区发展到附近的低矮建筑的过渡。
The structure also implements a height modulation which mimics a transition from urban scale of block development to the low buildings in the vicinity.
特定特征的引入使建筑具有了个性化的特征,并使其用户--以及当地居民能够认同它。这主要是通过逐渐变化的穿孔与外墙模块颜色的协调变化来实现的。
The introduction of specific features lends the building its individual identity and allows its users - as well as the local residents to identify with it. This is achieved mainly by gradually shifting perforations combined with coordinated changes in the color of the fa?ade modules.
为了进一步强调规模的变化,面向公园一侧的起伏阳台类型在小尺度上呼应了整体建筑质量的衔接。这就形成了一个差异化的、多样的城市景观,为社区增添了一个建筑自信的锚。
To further accentuate the shift in scale the undulating balcony types facing the park side echo - on a small scale - the articulation of the overall building mass.This results in a differentiated, varied cityscape, adding an architecturally confident anchor to the neighborhood.
区位图
平面图
立面图
剖面图
细部节点
建筑师:Martin Oberascher & Partner Architekten ZT GmbH, PLOV ZT GmbH
地点:奥地利
面积:10500 m2
年份:2018
140.17 万条内容 · 2232 人订阅
先进的、可持续的香港科技大学(广州)校区
转自公众号:KPF建筑设计事务所     ? 从中央枢纽看向行政大楼   中央枢纽及两侧呈放射形排布的研究大楼 占地267英亩的香港科技大学(广州)校区与今年9月开学并正式投入使用,项目从规划、设计到建成共历时三年。
