土木在线论坛 \ 电气工程 \ 照明工程 \ DIALux 4.5 新版发布!
DIALux 4.5 新版发布!
发布于:2008-04-04 22:40:04 来自:电气工程/照明工程 [复制转发]
Dear DIALux user
You will be able to see the new 4.5 version of DIALux at the “Light+Building” in Frankfurt from 6 to 11 April. Why don’t you visit us at our Stand A80 in Hall 3.0 and we can show you the latest features. We look forward to seeing you!
Of course the latest version is available as a download as of April 6th. You will find detailed information in the DIALux version history:
Link download: http://www.dial.de/CMS/English/Articles/DIALux/Download/Download_d_e_fr_it_es_cn.html
Link version history: http://www.dial.de/CMS/English/Articles/DIALux/Download/Versionshistorie_Link.html
Here are the important new features and enhancements at a glance:
DIALux is now even faster: Just one mouse click and you will have the results within a much shorter time and just as correct. This is of particular advantage for complex plans.
Solution finder: This helps you to select the most suitable streetlight from a wide range and explains why.
Positioning aids: You only need to mark the wall or the architectural elements and DIALux positions the luminaires automatically in a way which makes good planning sense.
New 3DS assistant: Integrate simple models from the Internet in DIALux (3DS format).
Decoration objects: Declare geometric shapes such as furniture as decoration objects and the calculation will be very much simplified. This reduces the calculation time dramatically.
Enhanced CAD interaction: The export of planning results in .dxf and .dwg files has been greatly improved.
New DIALux partners
We would like to welcome iGuzzini from Italy, Nikkon from Malaysia and Ardatovskij svetotekchnicheskij zavod from Russia as new DIALux partners.
The electronic catalogues of our new partners will be available soon as offline and online plugIns.
New electronic catalogues on the market
Since the last newsletter the following new catalogues for DIALux have come onto the market: Bright Special Lighting and Megalite. Updates are available for the following plugIns: Erco, Elba, Luxo ASA, Solar and Fagerhult.
Seminars
Would you like to learn more about light planning or use DIALux more efficiently? We offer exciting, practice-oriented seminars on all topics related to lighting and building technology. You will find an overview under the following link:
http://www.dial.de/CMS/English/Articles/Seminare/Seminare_Link.html
General information
If at any time you are at your wits?end or have a really good idea, then you can contact the DIAL hotline (German/English) free of charge under +49(0)2351/1064-365 or hotline@DIALux.com. In the menu “online” you can contact us directly from DIALux.
On our website www.dial.de you can find tips about DIALux, light planning and building technology.
Best wishes from Lüdenscheid
Your DIALux Team
全部回复(10 )
  • 爱芳的日子
    英文????头大了!!!1
    2009-08-20 21:57:20
  • bassjiang
    bassjiang 板凳
    好消息阿!!!!!!!!!!!!!!
    2009-02-18 16:09:18
照明工程
14.05 万条内容 · 453 人订阅
单元可视对讲机怎么布线?
刚学布线问各位师傅,单元可视对讲机怎么布线?
