土木在线论坛 \ 电气工程 \ 照明工程 \ AP1230 LDO 低压差线性稳压器
AP1230 LDO 低压差线性稳压器
发布于:2022-12-26 10:57:26 来自:电气工程/照明工程 [复制转发]
AP1230 series are highly precise, low power consumption, high voltage, positive voltage regulators manufactured using CMOS and laser trimming technologies .The series provides large currents with a significantly small dropout voltage. The series is compatible with low ESR ceramic capacitors .The current limiter’s foldback circuit also operates as a short protect for the output current limiter and the output pin.
Features
Highly Accurate:±2%
Output voltage range:1.5V~5.0V ( selectable in 0.1V steps)
 Low power consumption:8uA(TYP.)
 Large output current:300mA (VIN=4.3V,VOUT=3.3V)
 Input voltage: up to 6 V
 Excellent Input Stability
 Be available to regulator and reference voltage
Packages:SOT23-3,SOT89-3,SOT23,TO-92
Typical Application
 Battery powered equipment
Communication tools
Mobile phones
Portable games
Portable AV systems
Cameras, Video systems
Reference voltage sources
照明工程
14.05 万条内容 · 452 人订阅
一款多功能能打动您的电源驱动方案
集成MCU,充电芯片,MOS的三合一数字控制芯片 ? 工作电压范围: (GPIO)、PB[5:0]。 ? PB[3:0]可选择输入时使用内建下拉电阻。 ? 输入有三种组态可选(TTL/CMOS/Without Schmitt) ? PB[3]内建上拉电阻及输出高推功能。 ? PB[5:0]可选择上拉电阻或开漏极输出(Open-Drain)。
