DESCRIPTION
The AP6067 is a constant current, constant voltage Li-Ion battery charger controller that uses a current mode PWM step-down (buck) switching architecture. With a 500kHz switching frequency, the AP6067 provides a small, simple and efficient solution to fast charge one (4.2V) or two (8.4V) cell lithium-ion batteries. The AP6067 charges the battery in three phases: conditioning, constant current, and constant voltage. An external sense resistor sets the charge current with ±10% accuracy. An internal resistor divider and precision reference set the final float voltage to 4.2V per cell with ±
1% accuracy. An internal comparator detects the near end-of-charge condition while an internal timer sets the total charge time and terminates the charge cycle. The AP6067 automatically re-starts the charge if the b attery voltage falls below an internal threshold, 4.05V per cell. The AP6067 also automatically enters sleep mode wh en DC supplies are removed. The AP6067 is available in the 8-lead SOP and 10-l ead TDFN packages.
FEATURES
Wide Input Supply Voltage Range: 4.8V to 20V – 4.2 Version 8.9V to 20V – 8.4 Version 8.9V to 20V – 8.4A Version
500kHz Switching Frequency
End-of-Charge Current Detection Output
7 Hour Charge Termination Timer
±1% Charge Voltage Accuracy
±10% Charge Current Accuracy
Low 10?A Reverse Battery Drain Current
Automatic Battery Recharge
Automatic Trickle Charging of Low Voltage Batteries
Automatic Sleep Mode for Low Power Consumption
Battery Temperature Sensing
Stable with Ceramic Output Capacitor
Support up to 3A Charge Current
8-Lead SOP and 10-Lead TDFN Packages
RoHS Compliant and 100% Lead (Pb)-Free Halogen-Free
APPLICATIONS
Small Notebook Computer
Portable DVD
Handheld Instruments
返回版块97.93 万条内容 · 2230 人订阅
电阻柜都有哪些特点?电阻柜都有哪些特点? 1、采用优质非金属特种材料或不锈钢材质镍铬合金(cr20Ni80),电导率高,温度系数高,最高可耐1400℃的高温,耐腐蚀,稳定性好。 2、也可以使用各种中压配电系统中,如无中性点加接地变压器可与之配合使用。抑止系统过电压、防止各种冲击有很好的作用。 3、电阻柜阻值可从0.1欧姆到2000欧姆,电流从2安培到2000安培设计。 4、电阻柜一般用于户内,柜体采用喷塑冷轧钢板或不锈钢板制成,耐腐蚀,防护等级高。
