土木在线论坛 \ 建筑结构 \ 结构新鲜事 \ 法国高层公寓:露台形式的立面设计
法国高层公寓:露台形式的立面设计
发布于:2022-12-07 09:42:07 来自:建筑结构/结构新鲜事 [复制转发]
在历史名城的边缘,圣洛克区(ZAC St Roch),一个在铁轨上征服的领土,促进了一个新的充满活力的、开放的、混合的和可持续的地区的出现。这个由SERM(蒙彼利埃地区设备公司)开发的大型项目位于SNCF火车站、Comédie和历史中心附近,地理位置优越,占地15公顷,很快将获得EcoCité标签。
On the edge of the historic city, the ZAC St Roch, a territory conquered on the rails, promotes the emergence of a new animated, open, mixed and sustainable district. Ideally located in the immediate vicinity of the SNCF train station, the Comédie and the historic center, this vast operation developed by SERM (Société d'équipement de la Région de Montpellier) covers 15 hectares and will soon receive the EcoCité label.
在这个正在开发的城市拼图中,三号地块占据了一个特殊的战略和特权地位,因为它的高度为50米,象征着通往新区的大门,因此必须连接两个城市历史:历史中心的历史和这个面向未来的新中心的历史,这是一个独特的房地产报价的载体。一个挑战!
In this urban puzzle under development, lot III occupies a particularly strategic and privileged place, because, with its height of 50 meters, it symbolizes the gateway to the new district and as such must link two urban histories: that of the historic center and that of this new center turned towards the future, a vector of a unique real estate offer. A challenge!
作为蒙彼利埃市中心的一个良好信号,标志性的Higher Roch塔楼是这个位于ZAC三号地块的庞大项目的组成部分之一,这个项目名为City Roch(12600平方米),包括一个3480平方米的R+6办公楼(Roch Office),一个1780平方米的商业基地(Roch N'store),以及一个SO ROCH辅助住宅楼(1776平方米)。
High Roch塔楼包括76个住房单元,分布在16层,面积为5560m2。SOGEPROM-PRAGMA公司和VINCI Immobilier公司在共同推动下,正在实施由Brenac & Gonzalez & Associés建筑公司签署的项目。
A well-tempered signal in the heart of Montpellier, the emblematic Higher Roch tower is one of the components of this vast program on lot III of the ZAC, a program called City Roch (12,600m2) comprising a 3480m2 R+6 office building (Roch Office), a 1780m2 commercial base (Roch N'store), and a SO ROCH assisted housing building (1776m2). The Higher Roch tower comprises 76 housing units distributed over 16 floors for a surface area of 5560m2. SOGEPROM-PRAGMA and VINCI Immobilier, in co-promotion, are carrying out the project signed by the Brenac & Gonzalez & Associés architectural firm.
他们一起孜孜不倦地工作,以实现多种混合,或称 "多元混合":当然是功能性的,但也是社会性和代际性的。
Together, they have worked tirelessly to achieve multiple mixes, or "poly-mix": functional, of course, but also social and generational.
城市-罗奇的独特之处。城市-罗奇的矿物基地的设计与历史上的低层城市相呼应。当代城市的高度密集化,被塔楼以其起伏的形式回答,其内部-外部的多孔性和与植被的重新连接被巧妙地加工。
The uniqueness of City Roch. The design of the mineral base of City-Roch echoes the historic, low-rise city. The contemporary city, densified in height, is answered by the tower with its undulating forms and whose interior-exterior porosity and reconnection with the vegetation are subtly worked.
建筑师们所做的第一个登记,是针对历史名城和下城区的,是由一个石质的混凝土基座实现的,有不同的高度。它在脚下的发展,就像一条石带,它的建筑正交性将构成该街区的所有项目结合起来。它整合了一个商店基地和面向车站的R+6办公大楼。
The first register on which the architects have worked, which addresses the historic city, the lower city, is materialized by a concrete base of stone color, with variable heights. Its development at the foot, like a ribbon of stone, and its architectural orthogonality bring together all the programs that make up the block. It integrates a base of shops and the R+6 office building facing the station.
第二个登记册,是针对远方的,针对上层城市的,其几何形状发生了变化,变得自由和有机。这就是Higher Roch塔,它包含76套公寓,分布在16层。  它的楼层和露台的起伏形式,让人想起水平的曲线,被堆叠起来并连续偏移。这些悬垂物通过一个巨大的金属网相互连接。
The second register, which is addressed to the distance, to the upper city, whose geometry changes, becomes free and organic. This is the Higher Roch tower, which contains 76 apartments spread over 16 levels.  The undulating forms of its floors and terraces, which recall the curves of levels, are stacked and successively offset. These overhangs are connected to each other by a giant metal mesh.
住宅的设计考虑到了气候;这是一座地中海式的塔楼,由于有非常宽敞的露台,它重视内部和外部之间的使用和流动性。
The dwellings have been designed with the climate in mind; it is a Mediterranean tower that values the uses and fluidity between inside and outside thanks to the presence of very generous terraces.
因此,户外空间被设计成连续的客厅,大小适中,介于光线和阴影之间。
Thus, the ou     tdoor spaces are designed in continuity as living rooms, generously sized, between light and shade.
平面图
立面图
剖面图
建筑师:Brenac & Gonzalez & Associés
地点:法国
面积:12600 m2
年份:2022
  • 阿巅2019
    阿巅2019 沙发
    相当不错的资料,感谢楼主无私的分享!
    2022-12-19 13:11:19
结构新鲜事
2942 条内容 · 87 人订阅
美国研究人员 3D 打印了一座完全可回收的天然材料房屋
美国目前面临历史性的住房短缺,缅因大学的研究人员认为他们可能已经找到了解决问题的办法。该大学的先进结构和复合材料中心(ASCC)使用世界上最大的 3D 打印机之一,最近建造了第一个完全由生物基材料制成的 3D 打印房屋。 IT之家了解到,找到一种大规模制造 3D 打印房屋的方法是近年来许多公司试图解决的一个挑战。迄今为止,大多数解决方案都必须使用混凝土或粘土和传统的建筑方法,如木质框架,而 ASCC 的“BioHome3D”3D 打印房屋则不同。
