分配给该项目的土地正在开发中,作为Roissy更新计划的一部分,位于Roissy 1号航站楼附近,该航站楼旨在容纳多家酒店和办公楼。
因此,未来的各种酒店项目将沿着城市轴线设置,最终将有轨电车、有轨电车两侧的双服务道路以及沿线的自行车和步行道结合起来。酒店的前院。我们的土地位于这条主轴的东端,就在它通过滑行道之前,滑行道专用于起飞前后的各种飞机运动:轴端的这种情况使项目完全可见。
The various future hotel projects will therefore be set up along an urban axis, eventually combining the tram, a double service road on either side of the tram, and bicycle and pedestrian paths along the lines. forecourt of the hotels. Our land is located at the eastern limit of this major axis, just before it passes under the taxiway dedicated to the various aircraft movements before and after takeoff: this situation at the end of the axis gives the project total visibility.
该项目由两个酒店组成,分为两个独立的体量:拥有229间客房的Courtyard酒店和拥有106间客房的Hotel Residence Inn酒店。这两个卷一个在另一个后面,通过一个基座连接,允许共享一些公共区域。
The program consists of two hotels designed in two separate volumes: the Courtyard Hotel with 229 rooms and the Hotel Residence Inn with 106 rooms. The two volumes sneak one behind the other and connect by a base, allowing to share some common areas.
两种类型的功能通过两种不同的体积实现:房间的重复性、紧凑性和规则性,而公共部分的设计则是以流动的精神进行的,并对外开放,完全玻璃化。
Two types of functions are materialized by two different types of volumes: that of the rooms is repetitive, compact and regular, when that of the common parts is designed in a fluid spirit and open to the outside, fully glazed.
立面由与房间相对应的彩色模块组成,形成了一个大的渐变,从底部从最暗到最亮。每个模块的独立性通过形成一个大网格的轮廓来体现,这是明智的安排。
The facades are composed of colored modules corresponding to a room, creating a large gradient, from the darkest to the lightest from the bottom. The independence of each module is materialized by outlines that form a large grid, as wisely arranged.
区位图
平面图
剖面图
模型图
手绘图
建筑师:Manuelle Gautrand Architecture
地点:法国
面积:14000平方米
年份:2022
返回版块140.17 万条内容 · 2232 人订阅
中学校园:60班规模,从规划到立面,绿色低碳的设计策略济南历城二中彩石校区 同圆设计 ? 时差影像 缘起 成立于1958年的济南历城二中,在中国经济社会全面发展的滚滚浪潮中,作为中国教育文化的缩影,从一座典型的农村中学发展成为享誉国内的齐鲁名校,2020年初彩石校区启动规划设计工作,校区因选址于彩石虎山脚下,良好的自然生态环境与人文环境促发了我们思考如何营造一所能够融入自然的绿色低碳校园。
