土木在线论坛 \ 园林景观 \ 景观规划设计 \ 基于共享居住的理念 | 巴厘岛·The Founder共享居住空间
发布于:2022-12-01 09:05:01 来自:园林景观/景观规划设计 [复制转发]
转自公众号:Hhlloo设计网
这个项目位于巴厘岛乌布市中心,其设计愿景是基于共享居住的概念,创造一种新的生活与工作模式,让企业家们能够找到自己的私人生活空间以及工作、灵感碰撞和与他人聚会的地方。
Located in the center of Ubud, Bali. The vision of Clan Living was to create a new model of micro living where the entrepreneur finds their own space for private living as well as places to work, share ideas and gather with others.
设计根据现有结构建筑,将弯曲的竹子作为立面和结构,与其他天然材料(如天然石头、咖啡枝、木材)相结合以增强该建筑的亮点,同时将可持续性发展的理念贯彻其中。这种拱形竹子结构能够传达数字化时代工作的灵活性,在建筑立面使用中空的造型进行布置,可以增加建筑与环境的相互呼应关系,同时也可以提高阳光照射,增添能见度。
Designed from the existing structural building, Ruang Nyaman created the curved bamboo facades as the protagonist material, combining with other natural materials such as natural stones, coffee branches, wood to react and enhance the cultural context of this site, and developed with sustainable considerations. For the facade, arch shaped bamboo conveys the sense of flexibility towards the digital nomads era of working. Using a secondary skin facade that is arranged in a hollow and with enlarged shape on top of it, as a natural response to the surrounding environment, from visibility to sun exposure.
▽立面效果
公共区域设置了一个巨大的竹子屋顶,横跨两层,两层之间有一个木制坡道连接。在上层,他们可以一边工作一边欣赏池景和美丽的曲线图案,让眼睛平静下来,唤起一种舒缓的氛围。下层则是互动和聚集空间,可以将脚浸入水中玩耍。除了公共空间,这里还设有设备齐全的厨房和食品贮藏室,供大家聚会和共享。
The communal area is set with a massive bamboo roof, spanning two levels with a wooden ramp connecting the two floors. On the upper level, they can work and enjoy the work while enjoying the pool view and curves pattern calming the eyes, evoking a soothing atmosphere. The ground level boosts interactions and gathering while soaking their feets under water. In addition to the communal space, it features a fully equipped kitchen and pantry as they gather and share.
▽共享空间
私人区域建有3层,每层都有不同的体验。一楼包括一个大露台,上面摆放着咖啡枝制成的躺椅,可以从房间直接进入游泳池。第二层的阳台躺椅同样是用咖啡树枝建造的,不同的是,它还拥有一个向外延伸的吊床,以不同的方式来体验阳台带来的乐趣。三楼阳台上有一张长长的工作凳,可以看到周围令人兴奋的景色。房间内的设计采用带有独特楼梯的夹层系统连接客厅和卧室,这样做可以最大限度地提高住户的舒适感,将工作和度假巧妙结合起来。
The private areas were built with 3 floor levels, ensuring each level has a different experience. The ground level includes a big terrace with arranged coffee branches as the lounge chair, with direct access to the pool. Second level was built with the same coffee branches, in addition giving the hanging nets as a hammock as the focal point to give a different way to experiencing the balcony. And the third floor features a long work stool table with exciting views towards its surroundings. The interior design uses a mezzanine system with a unique staircase to connect the living room and bedroom. They are all designed to maximize the user’s sense of comfort, combining work and vacation.
▽一层室内空间
▽二层室内空间
▽三层室内空间
▽卫浴、楼道空间
这种共享空间的理念将随着时间的推移而不断发展,并通过新的视角为理解空间奠定坚实的基础,正如我们为美好的明天而努力奋斗一样。
The Clan Living will grow throughout time, and make it a strong foundation in understanding spaces through new ways of view to achieve a new perspective of a good living space, as we create and build today for tomorrow's living.
▽总平图
▽楼层平面图
▽立面图
▽剖面图
景观规划设计
25.18 万条内容 · 282 人订阅
上海共青森林公园的花境
共青森林公园位于上海市杨浦区,东濒黄浦江,西临军工路,全园总占地1965亩。公园本来是黄浦江边的滩涂沼泽,1956年上海市政府疏浚河道开垦荒地后辟为苗圃。 1958年春团中央书记胡耀邦带领在上海开会的全国青年积极分子栽植果树。在圃内建立了青春实验果园,取名为共青苗圃,共青森林公园得名于此。 该园是以森林为主要景观的特色公园,共种植200余种树木,总数达30多万株。公园分为南北两园,北园占地1631亩称为共青森林公园,南园占地239.6亩称为万竹园。南北园风格各异,北园着重森林景色,有丘陵湖泊草地,南园则小桥流水一派南国风光。
