土木在线论坛 \ 园林景观 \ 景观规划设计 \ 竹林上的的树屋 | 马尔代夫·“Terra”餐厅
发布于:2022-11-29 13:06:29 来自:园林景观/景观规划设计 [复制转发]
转自公众号:Hhlloo设计网
Stickman Tribe无与伦比的创造力和坚定的愿景体现在Terra的理想设计中。这家餐厅以树屋为灵感,当客人被茂密的树叶、环环相扣图案和摇曳的绿色植物包围时,会使人唤起一种电影般的体验。
Stickman Tribe’s unrivaled creativity and unshakeable vision manifests itself in Terra’s utopian design. Inspired by a treehouse, the restaurant evokes a cinematic experience as guests find themselves surrounded by thick foliage, the interlocking patterns of the structure, and the ocean breeze atop the swaying greenery.
Terra的设计灵感来自周围的自然环境。Terra这个名字在拉丁语中的意思是“地球”或“土地”的意思。场馆设有一些观景平台,并设有半私人餐厅和无与伦比的岛屿景色。
The design inspiration for Terra came from the surrounding natural environment. The name Terra was chosen for the meaning in Latin which translates to ‘earth’ or ‘land’. The intricate venue features a series of platforms with semi-private dining cocoons and unbeatable island views.
Terra经过非常巧妙的设计,使客人与自然融为一体。每一个吊舱都处在不同的高度,以确保没有吊舱可以看到其他吊舱,每个吊舱都提供了周围自然的良好视野。设计师利用树叶将吊舱进行分离。支撑吊舱的混凝土地板和柱子使用建筑构架建造,并让树叶自然地生长,将建筑与自然融为一体。
Terra has been very cleverly designed to ensure that guests feel at one with nature. The pods of the structure are strategically layered in heights to ensure that no pod looks into the other and each provide a great view of the surrounding nature. So, this led the team to explore using foliage to create an organic separator between the pods. The concrete-slab and columns that hold the pods were cleverly treated with an architectural mesh allowing for the foliage to naturally climb and thrive onto it accepting it as one with nature.
竹子被用作主要的装饰元素,使建筑结构融入自然景观。吊舱的支撑使用了混凝土结构和花岗岩材料。
Bamboo is used as the main decorative element so that the structure blends into the natural landscape. Concrete and granite have been used for the columns supporting the pods and the main floor slab.
Stickman Tribe团队与景观顾问和来自印度的竹子专家JANS Bamboo Products相互合作,通过合理的规划尺寸绘制出用餐区的布局和空间,以形成开阔的视野。
Stickman Tribe team worked closely with the landscape consultant and JANS Bamboo Products--the bamboo specialists from India--to map out the setting out of the dining pods, hand-sketching the ideal distances, setbacks and openings to frame the views.
Terra被提议设置在地形的最高点,为餐厅提供了最佳的观赏点。这样设计有两个目的,首先,占据了一个独特的位置,让客人感受到酒店与自然融为一体的感觉,其次,为后面的住宿区域形成一个背景景观。 Terra餐厅被巧妙地放置在所有后屋住宿的前面,以躲避客人的视线。
Terra was proposed to be located at the highest point of the topography of the location to give the best views of the island. It was to serve two purposes. Firstly, be a unique location that provides guests the feel of being one with the incredible nature that surrounds the hotel, and secondly, provide a screen for the back of house accommodations. Terra was strategically placed in front of all back of house accommodation to hide it from the view of the guests.
为了获得最好的视野,这些吊舱必须升高到一定的高度。然而,要让树木成熟和生长得足够快,以达到预期的设计是一项挑战。经过几次头脑风暴后,Stickman提议以这个概念创造一片竹林。这种简单但理想的解决方案带来了许多好处。
The pods had to be raised to a certain height to get the best views. However, it was challenging getting the trees to mature and grow quick enough to achieve the desired design. After a few brainstorming sessions, Stickman proposed to create a bamboo forest for this concept. This simple but ideal solution presented many benefits.
竹子是世界上生长最快的植物之一,在马尔代夫的气候条件下,这为竹子的茁壮成长提供了理想的沃土。竹林将有助于隐藏建筑的结构和柱子,这些奇异的柱子可以承载龙门架的负载,每个吊舱设置在不同的高度。客人会觉得自己身处于森林里,并且不与其他吊舱相邻。
Bamboo is one of the fastest-growing plants in the world and with the weather conditions in the Maldives, this presented an ideal fertile ground for the trees to thrive. The bamboo forests would help hide the structure or the columns, which was a series of singular columns that would carry the load of the gantry and each of the pods set in different heights and levels. Guests would seemingly feel that they're alone in the forest and not adjacent to other pods.
项目形式
项目名称:Terra
公司名称:Stickman Tribe
网址:www.stickmaribe.com
联系人电子邮件:namitha@stickmantribe.com, pr@stickmantribe.com
项目地点:马尔代夫Waldorf Astoria
竣工年份:2018年
建筑面积(m2):240 m2
其他参与者:客户-Urbacon贸易与承包,运营商-希尔顿全球
图片来源:Alex Jeffries摄影
景观规划设计
25.18 万条内容 · 282 人订阅
消极空间处理,景观设计技巧华丽来袭~
    我们生活的环境中 有很多边角空间、中介空间、废弃空间 它们都未曾被设计过 这些空间利用率差 影响环境的舒适性和宜人性 同时也降低了人们的生活品质 “这种空间具有无目的性,无向心性,无明确边界,无主要的活动主题等特性,因为种种因素,其未能满足人和社会的需求,此空间即为“消极空间(N-Space)。”
