土木在线论坛 \ 建筑结构 \ 钢结构工程 \ 福斯特作品:310米高,摩天办公楼
福斯特作品:310米高,摩天办公楼
发布于:2022-11-08 09:03:08 来自:建筑结构/钢结构工程 [复制转发]
福斯特 合伙人公司已经完成了瓦尔索塔,它是HB Reavis在华沙的瓦尔索广场的一个组成部分。它的高度达到了破纪录的310米,是欧盟高塔。
Foster Partners has completed Varso Tower, an integral part of HB Reavis' Varso Place in Warsaw. At a record-breaking 310 meters, it is the tallest tower in the European Union.
坐落在Jana Pawla II和Chmielna街的拐角处,该塔楼形成了新开发项目的门户,吸引人们通过建筑走向其西端的公共广场,与邻近的建筑相连。该项目的社会中心是一个封闭在玻璃幕墙内的广场,广场上有全高的树木和长椅,供人们享受周围的环境。这个 "城市房间 "形成了在办公室工作的人与公众之间的无缝连接点--他们可以在休息时将其作为休憩场所--以进入邻近建筑的商店和餐馆。
Situated at the corner of Jana Pawla II and Chmielna Street, the tower forms a gateway to the new development and draws people through the building towards the public plaza on its western end that connects to the neighboring buildings. The social heart of the project is a plaza enclosed within a glazed screen, animated with full-height trees and benches for people to enjoy the surroundings. This ‘urban room’ forms the point of seamless connection between people who work in the offices – who may use it as a sit-out during breaks – and the public, to access the shops and restaurants in the neighboring buildings.
公共领域在塔顶继续,通过两个全景电梯从地面直接进入,在53层有一个观景平台。这是波兰有人居住的楼层,可以看到不间断的城市景观。49层不久将提供一个完全景观化的露台酒吧,有16棵树,打破了华沙花园的记录。
The public realm continues at the top of the tower, accessed directly from the ground via two panoramic lifts, with a viewing platform at level 53. This is the highest inhabited floor in Poland with uninterrupted views of the city. Level 49 will soon offer a fully landscaped terrace bar, with sixteen trees, breaking the record for Warsaw’s highest garden.
这些办公室由两组大容量的双层电梯提供服务,每辆车同时为两个楼层服务。该大厦拥有70,000平方米的优质办公空间,采用大跨度楼板,净高3米,适合开放式办公。该建筑获得了英国建筑性能评估体系(BREEAM)的杰出认证和WELL金奖认证,部分原因是其三层玻璃外墙。
The offices are serv   ed by two banks of high-capacity double-deck lifts, with each car serving two floors at any one time. With 70,000 square meters of premium office space, the tower features large-span floorplates with three-meter clear height for open-plan offices. The building achieves BREEAM Outstanding and WELL Gold certifications, due in part to its triple-glazed fa?ades.
平面图
立面图
剖面图
外墙细节
建筑师:Foster Partners 福斯特建筑事务所
地点:波兰
年份:2022
钢结构工程
46.53 万条内容 · 1223 人订阅
钢结构设计中应如何考虑抽柱、托梁与墙架柱
一、抽柱与托梁的设置 《门式刚架轻型房屋钢结构规法范》规定:“在多跨刚架局部抽掉中间柱或边柱处,可布置托梁或托架。”对此设计工程师一般都注意到了这一规定;有部分抽柱时,应该设置纵向水平支撑并向托梁或托架的两端各延伸一个开间,如(图1)所示,这一做法的目的。 除了加强整体刚度之外,还有一个十分重要的作用就是保证托梁或托架的平面外稳定,但有一些设计工程师忽视了这个问题,本世纪初,在福建就曾有国外设计的工程在托架处没有设置纵向水平支撑,导致在安装阶段出现倒塌的事故。
