土木在线论坛 \ 装配式建筑 \ 装配式施工 \ 创新住宅公寓:“未来式”的外立面设计
创新住宅公寓:“未来式”的外立面设计
发布于:2022-10-13 13:28:13 来自:装配式建筑/装配式施工 [复制转发]
The Lanes Residences占据了一个突出的角落位置,它被艺术地用来调和沿海边缘的高层开发和澳大利亚黄金海岸内部郊区的国内规模。四座住宅塔楼平衡了城市的联系和团结湖的景观,用流动的建筑语言模仿土地的轮廓和植物的生长。
The Lanes Residences occupies a prominent corner location that is artfully used to mediate between high-rise development along the coastal fringe and domestically scaled interior suburbs of Australia’s Gold Coast. Four residential towers balance the urban link and landscape of Lake Unity, with a fluid architectural language mimicking land contours and vegetal growth.
建筑结构表现在它的立面上,由玻璃钢混凝土的斜面垂直肢体组成的外观,上升到四座塔楼的摇篮,并部分遮挡其切面的玻璃墙。两座10层高的塔楼包括底层零售和商业空间(将与未来的零售村相连),两座12层高的塔楼设有居民设施,包括游泳池和露台、桑拿、水疗和健身房、游戏厅和会议室。
The building structure is expressed in its fa?ade, with an exoskeleton of mitred vertical limbs in glass-reinforced concrete, rising to cradle each of the four towers and partially shading their faceted glass walls. Two 10-storey towers include ground-floor retail and commercial spaces (that will link to a future retail village), and two 12-storey towers host resident amenities, including a swimming pool and terrace, sauna, spa and gymnasium, a games lounge, and meeting room。
对气候敏感的外墙设计减少了整个塔楼的热负荷。每根雕刻好的GRC柱子都直接与内部公寓配置相连,框住了公寓阳台,并保护建筑免受阳光照射。
The climate-sensitive facade design reduces the heat load across the towers. Each sculpted GRC column is directly connected to the internal apartment configuration, framing the apartment balconies, and protecting the building against sun exposure.
更多的被动式设计原则被纳入到建筑中,使居民能够在阳光充足的亚热带气候下实现可持续的生活,而不需要人工制冷。这包括开放的生活空间,最大限度地增加可开启的门的数量,以利于微风的渗透,以及深凹的阳台,以提供阴凉和舒适的户外生活空间。住宅与零售业的接近将支持居民更多地在当地生活,减少对交通化石燃料的依赖。
Further principles of passive design are incorporated into the building to allow the residents to achieve sustainable living in the sunny subtropical climate without the need for artificial cooling. This includes open plan living and maximizing the number of openable doors for breeze permeation, and deeply recessed balconies that provide shade and comfortable outdoor living spaces. The proximity of residential to retail will support residents to live more locally, reducing dependency on fossil fuels for transportation.
区位图
平面图
立面图
模型图
细部节点
建筑师:Contreras Earl Architecture
地点:澳大利亚
面积:46823平方米
年份:2022
装配式施工
9484 条内容 · 133 人订阅
蒸压加气混凝土砌块
          蒸压加气混凝土砌块
