HENN为年轻的软件公司baramundi的设计结合了社会和技术性能。作为奥格斯堡创新园的首批试点项目之一,该总部有助于加强德国作为技术创新驱动者的地位。
新的总部是一个连接和协作工作的平台。这座13250平方米的建筑包含一个公共食堂、灵活的合作空间、专门的工作区、健身房和一个可以看到阿尔卑斯山的屋顶露台。这些空间围绕着一个充满活力的内部中庭组织,其旋转和重叠的切口创造了单层、双层和全高的混合空间。中庭为建筑创造了一个充满活力的社会核心,其层叠的楼梯作为一个非正式的交流空间发挥作用。
The new Headquarters is a platform for connection and collaborative work. The 13,250 square-meter building contains a public canteen, flexible collaboration spaces, dedicated work areas, a gym, and a rooftop terrace with views of the Alps. The spaces are organized around a dynamic interior atrium whose rotating and overlapping cut-outs create a mix of single, double, and full-height spaces. The atrium creates an energetic social core for the building, and its cascading staircase functions as an informal communication space.
baramundi总部是一个灵活的工作环境,其灵活性表现在其外墙的不断变化的特点上。最小的玻璃体量用精确的带钢衔接起来,优雅地显露出来,而半自动窗帘系统提供了一个俏皮的、但功能很强的遮阳系统。该系统将低技术含量的窗帘与高科技的自动轨道系统相结合。窗帘跟随太阳的轨迹,为工作区和休息室提供不同程度的遮阳。
baramundi HQ is an agile work environment whose flexibility is expressed in the always-changing character of its facade. The minimal glass volume is articulated with precision strip steel and elegantly reveals, while the semi-automated curtain system offers a playful, yet highly-functional sun-shading system. The system combines low-tech curtains with a high-tech, automated track system. The curtains follow the sun’s path and provide variable degrees of shading for workspaces and lounges
窗帘创造了一个透明的内部空间,而不是封闭建筑,它们轻柔的运动和看似随机的模式创造了与外部世界的自然节奏的直接联系。
The curtains create a diaphanous interiority, rather than sealing the building off, their gentle movements and seemingly-random patterns create a direct connection to the natural rhythms of the outside world.
与光滑、简约的立面形成对比的是,室内是由原始的、裸露的和自然材料制成的。裸露的混凝土,未完成的阳极氧化表面,和可见的金属板。
工作空间使用自然的颜色和材料,如木材和织物。面向中庭的所有表面都覆盖着一层白色的声学涂层,该涂层可以减弱声音,放大自然的漫射光。古铜色的窗帘作为灵活的室内隔断,创造出易于适应的空间。
In contrast to the sleek, minimal facade the interior is made of raw, exposed, and natural materials. Exposed concrete, unfinished anodized surface, and visible metal sheets. Workspaces utilize natural colors and materials such as wood and fabric. All the surfaces facing the atrium are clad in a white acoustic coating that dampens sound and amplifies natural, diffused light. Bronze-colored curtains serve as flexible interior partitions to create easily adaptable spaces.
总部的混凝土板是热激活的,使用辐射采暖,全年保持21度的温度,在夏季和冬季充当热缓冲。裸露的混凝土被镶嵌着分层的隔音板,穿孔的金属层允许热传导,而泡沫层吸收声音。
The headquarters’ concrete slabs are thermally activated and use radiant heating to maintain a 21-degree temperature throughout the year, acting as a thermal buffer during the summer and winter. The exposed concrete is inlaid with layered acoustic panels, the perforated metal layer allows for thermal conduction, whil e the foam layer absorbs sound.
平面图
立面图
剖面图
建筑师:HENN
地点:德国
面积:13250 m2
年份:2022
返回版块140.17 万条内容 · 2232 人订阅
设计策略:8种校园空间范式随着当代中国教育改革的推进,教学方式由教师“填鸭式”地单向传授转变为学生自主学习,教学内容由统一课表向创新课程转变。 因此,多元化的教学趋势对中小学校园建筑设计提出了全新的要求,传统校园空间中教室作为单一学习空间的模式,已无法满足学生作为校园使用主体对学习空间灵活多样的需求。
