土木在线论坛 \ 装修设计 \ 家装设计 \ 青岛八大关太平角壹路18号-21画廊
青岛八大关太平角壹路18号-21画廊
发布于:2022-09-21 09:06:21 来自:装修设计/家装设计 [复制转发]
21画(画廊 艺术品)
 The 21 Gallery (Art Gallery and Art Collection)
青岛市太平角一路18号,4500平米花园的一栋别墅建于1930年由法国设计师白纳德先生设计,欧式建筑砖木结构、本次设计由于建筑物是文物所以外观整体都保持原状态不变,政府统一修缮加固过。
Established in 1930 as a villa with 4500m2 front yard designed by a French architect, The 21 Gallery, located in No. 18 Taiping Cape 1st St., Qingdao, is a European architectural style wood-brick structure house.As a conservation of historic site, the building has been repaired and reinforced by government department to keep the appearance as before.
我们将窗户更换成整块大玻璃,让建筑的室内空间透光性增强与4500平面的花园融入一起,让红瓦、绿树、白墙体现的淋漓尽致。
Whole big pieces of glass were mounted to replace bridge-cutoff aluminum window. Accordingly, the interior environment is in harmony with the 4500m2 villa yard view accompanied with red-tile roofs and white walls shaded in green trees by enhancing indoor natural sunlight.
室内空间的设计
Interior design of The 21 Gallery
21画是一家画廊艺术品商店,所以采用整体白色,根据文物保护建筑的规定要求在保留原有墙、顶、地、的基础上,顶面保持不变直接涂装白色、地面通铺灰色橡木地板、墙面用木丝吸音板包制涂装白色。
Since the conservation rules for historic buildings, the overall color tone is white on the original ceiling and wall (wrapped with wood silk sound-absorbing board) and grey oak floor on the original ground.
楼梯采用吊装悬空,二楼保持原有的法式孟萨屋顶、增加一部分展示隔墙。由于建筑物的窗户较多更换后的玻璃整窗像一幅幅艺术作品展示着花园一年四季的变化。
Stepping up with lifting stairs, the French mansard roof is showed up on the top as its old style while some gallery walls on the 2nd floor. By taking the merits of new large whole piece of glass, the view from the villa windows brings unparalleled experience to witness the change from season to season in the yard, like fantastic art work.
建筑物还有间62平米的附房,我们特别邀请了国内知名品牌哲品“ZENS T”新派茶饮作为21画配套服务,也是在一栋接近百年建筑里茶与艺术又一次新的尝试。为了保持设计的统一性茶厅与画廊色调装饰保持一致。
“Zen T”, a famous new-fashioned tea beverage brand, was invited to set up a store in the 62m2 annex next to the villa as a complementary service of The 21 Gallery. It’s a brand new attempt to combine the tea culture and art. To keep the unity principle of design, its decoration style and color tone are brought into correspondence with the Gallery.
两栋房形成了一个90度夹角,我们将这块区域设计成了公共花园休息区、地面呼应房顶的红瓦采用红砖铺设预留草道衔接。
The area enclosed by the main building and annex is designed as an outdoor lounge area. The ground is paved with red-brick blocks which coordinates with the red-tile roof. The gaps between blocks are filled by lawn.
休息区有两个设计点:一、主建筑的原有的后门没有封闭改为玻璃通明盒子用于雕塑陈列,二、外挂装置艺术楼梯俯瞰4500平米花园。通过应用大面积玻璃的使用让一个接近百年的建筑重新焕发新生,希望能够陪伴它度过百年时光......
Design highlights in outdoor lounge area: 1. The backdoor of main building is reserved and modified into an exhibition spot with clear glass for sculptures. 2. An installation art stair is mounted for a bird’s-eye view of the yard.By applying large area glass to rejuvenate a nearly 100-year historic building, may its life and story will go on.
项目名称 | 21画& ZENS T
项目所在地 | 中国 青岛八大关太平角18号
主创设计师 | 韩冷
设计单位方 | 设理设诚
委托方 | 二十一画艺术品中心
视觉设计 | 井然设计
项目面积 | 252 m2
项目时间 | 2022年9月
摄影师 | JolinTomato
家装设计
22.34 万条内容 · 392 人订阅
自然木色 奶油色系,打造随性有品位的家!
说在前面
