土木在线论坛 \ 建筑结构 \ 混凝土结构 \ 小体量 | 多层公寓(交错编织的立面)
小体量 | 多层公寓(交错编织的立面)
发布于:2022-09-14 09:52:14 来自:建筑结构/混凝土结构 [复制转发]
“这座城市是迷雾地图上的一个点”安布罗斯·比尔斯。旧金山市的网格山丘是水晶几何形状的起伏地形,在地中海的光线下闪闪发光。海湾和山丘一览无余的景色是巩固城市特色的天气图像。沿旧街道排列的重复海湾的确切顺序以更亲密的规模加强了这一形象。
‘This city is a point upon a map of fog’ Ambrose Bierce. The gridded hills of the city of San Francisco are a rolling topography of crystalline geometry which glisten in the Mediterranean light. Sweeping views from the Bay and hills are synoptic images that cement the city’s character. The exact order of repeating bays that line older streets reinforces this image at a more intimate scale.
这试图浓缩当代建筑中踩在山上的盒子的多面图像。折叠的海湾重叠和镜像,创造出重复元素的波纹和交错编织的立面,重新焕发了城市传统建筑中随处可见的简单材料的起伏的锯齿状街道墙壁。
This attempts to condense the faceted images of boxes stepping on the hills in a contemporary building. Folded bays overlap and mirror, creating a rippling and staggered woven fa?ade of repeated elements, reinvigorating the undulating crenelated street walls of simple materials found all over the city in its traditional architecture.
该项目共25个单元,其中16个为叠层的两层联排别墅。虽然紧凑,但它们提供两层的尺寸,一层用于居住,另一层用于两间卧室和两间浴室,提供了另一种城市联排别墅类型。这种格式消除了卧室楼层的走廊,减少了流通并增加了可居住空间。
The project is 25 units, 16 of which are stacked two-story townhouses. Although compact, they offer the dimensions of two levels, one for living, the other for two bedrooms and two bathrooms, providing an alternative urban townhouse type. This format eliminates corridors on bedroom levels, reducing circulation and increasing habitable space.
典型的双负荷廊道建筑可以达到约84%的净效率,这里的效率是91%。地面层是包裹着穿孔金属的落地玻璃。屋顶是居民的室外花园。
Where typical double-loaded corridor buildings can achieve an efficiency of around 84% net to gross, here efficie     ncy is 91%. The ground level is floor-to-ceiling glass wrapped in perforated metal. The rooftop is a common outdoor garden for the residents.
Where typical double-loaded corridor buildings can achieve an efficiency of around 84% net to gross, here efficiency is 91%. The ground level is floor-to-ceiling glass wrapped in perforated metal. The rooftop is a common outdoor garden for the residents.
平面图
立面图
剖面图
轴测分析图
建筑师:Stanley Saitowitz | Natoma Architects
地点:美国
面积:24000平方米
年份:2022
140.17 万条内容 · 2232 人订阅
中小学国际竞赛设计方案:依据地势布置,灵活可变的空间,支持创新教学模式
西部(重庆)科学城巴石片区 中小学国际竞赛第二名 天津天华+中国中建 △ 天津天华建筑设计有限公司+中国中建设计研究院有限公司 设计单位  天津天华建筑设计有限公司、中国中建设计研究院有限公司 项目地点  重庆市九龙坡区巴福镇
