土木在线论坛 \ 电气工程 \ 建筑智能化 \ 电气触头发热及处理方法(英文资料)1
电气触头发热及处理方法(英文资料)1
发布于:2008-03-30 21:19:30 来自:电气工程/建筑智能化 [复制转发]
Electricity touch hair hot and treatment
Electric power system in electricity equipments and electricity equipments, mother line and mother line, mother line and equipments conjunction of conductor formation can dismantle unload of electricity touch head, this kind of electricity touch head for number numerous, actual circulate medium usually meet electricity touch head lead hot, because of detection and processing can not compare with but destroy by fire equipments, cause trouble, break off power supply, give electric power system safety produce, economy circulate, credibility power supply, superior quality duty result in graveness loss.
Electricity touch head lead hot of reason a lot of, mostly is electricity touch head tight firmware at design, manufacturing, install conjunction aspect existence lack sink, cause touch head spread hot condition not creation lead hot problem.Currently electricity touch all of head is adoption common stud bolt conjunction, is exactly use common stud bolt conjunction existence many habitual mistake, but cause electricity touch head lead hot.
To electricity touch head of conjunction carry on thorough analysis, put forward electricity touch head however hot four great principle;Then according to this four great principle, analysis common stud bolt tight solid electricity touch head existence of problem;And emphasize introduction understanding definitely these problem of method and basis four great principle but design of patent tight firmware.
建筑智能化
12.42 万条内容 · 420 人订阅
德国BECKHOFF 楼宇控制案例
顶级足球场的灯光控制
