土木在线论坛 \ 建筑结构 \ 混凝土结构 \ 请留言啊
请留言啊
发布于:2008-03-30 20:14:30 来自:建筑结构/混凝土结构 [复制转发]
自盖阳光房,预制了十个柱子,150*150*3000,每个柱子内筋4*10mm,无箍筋, 并挖500*500*700坑浇混凝土固定,所有柱子间距3000,单边5个,室内面积约2700*11000,全部用100厚素混凝土做基础,基础大于柱子,约为3300*12300,然后所有柱子间砌单砖12墙,14#槽钢与柱子顶端预留铁板焊接,所有柱子顶端间横竖向均用14#槽钢互相连焊,原平顶屋板用彩钢板,现拟拆了,14#槽钢不动,然后现浇混凝土平顶屋板,仅为家庭散步阳台,请就基础,整体结构有无问题说说,若可行,有关参数,要点告之,俺这厢有礼了,恭祝万寿无疆,
  • panjianmin
    panjianmin 沙发
    頂頂頂頂頂頂頂頂頂頂頂頂頂頂頂████████████████頂頂頂頂
    頂頂頂頂頂頂頂頂頂頂████頂頂██████████頂頂頂頂頂頂頂頂頂
    頂頂頂頂頂頂████████頂頂██頂頂頂████頂頂頂頂頂頂頂頂頂頂
    頂█████████████頂頂頂頂頂頂頂███頂頂頂頂頂頂頂頂頂頂頂
    頂███████████頂頂頂頂頂頂頂頂█████████頂頂頂頂頂頂
    頂頂█████████頂頂頂頂頂頂頂頂████████████頂頂頂頂
    頂頂頂█頂頂頂████頂頂頂頂頂頂████頂頂頂頂頂█████頂頂頂頂
    頂頂頂頂頂頂頂頂███頂頂頂頂頂頂██頂頂頂█頂頂頂頂███頂頂頂頂頂
    頂頂頂頂頂頂頂頂███頂頂頂頂頂███頂頂頂██頂頂頂███頂頂頂頂頂
    頂頂頂頂頂頂頂頂███頂頂頂頂頂███頂頂███頂頂頂███頂頂頂頂頂
    頂頂頂頂頂頂頂頂███頂頂頂頂頂██頂頂頂██頂頂頂頂███頂頂頂頂頂
    頂頂頂████████頂頂頂頂頂頂█頂頂██頂頂頂頂████頂頂頂頂頂
    頂頂頂頂███████頂頂頂頂頂頂頂頂頂██頂頂█頂頂頂██頂頂頂頂頂
    頂頂頂頂頂頂█████頂頂頂頂頂頂頂頂███頂頂████頂頂頂頂頂頂頂
    頂頂頂頂頂頂頂頂███頂頂頂頂頂頂頂████頂頂頂██████頂頂頂頂
    頂頂頂頂頂頂頂頂頂頂頂頂頂頂頂頂█████頂頂頂頂頂██████頂頂頂
    頂頂頂頂頂頂頂頂頂頂頂頂頂頂頂████頂頂頂頂頂頂頂頂█████頂頂頂
    頂頂頂頂頂頂頂頂頂頂頂頂頂█████頂頂頂頂頂頂頂頂頂頂████頂頂頂
    頂頂頂頂頂頂頂頂頂頂頂頂██頂頂頂頂頂頂頂頂頂頂頂頂頂頂頂██頂頂頂頂
    頂頂頂頂頂頂頂頂頂頂頂頂頂頂頂頂頂頂頂頂頂頂頂頂頂頂頂頂頂頂頂頂頂頂頂
    2008-03-31 20:50:31
  • mrky010
    mrky010 板凳
    仅为家庭散步阳台,那你还不如就铺点钢板算了,还搞混凝土楼盖,那玩意多重啊
    2008-03-31 16:13:31
140.17 万条内容 · 2232 人订阅
有没有谁有灌注桩的图纸
有没有谁有灌注桩的图纸有没有谁有灌注桩的图纸有没有谁有灌注桩的图纸有没有谁有灌注桩的图纸有没有谁有灌注桩的图纸有没有谁有灌注桩的图纸有没有谁有灌注桩的图纸有没有谁有灌注桩的图纸
