土木在线论坛 \ 建筑结构 \ 混凝土结构 \ 多层住宅:突出立面的设计
多层住宅:突出立面的设计
发布于:2022-09-09 13:01:09 来自:建筑结构/混凝土结构 [复制转发]
为居民提供宽敞的户外空间。这座住宅距离 Meudon 森林(法国)仅几步之遥,是当代建筑的体现,其众多户外空间突出了立面。
Generous outdoor spaces for residents. Just a few steps from the Meudon forest (France), this residence is the expression of contemporary architecture, highlighted by its many outdoor spaces that punctuate the fa?ade.
该项目包括两栋带有低碳生物气候公寓的建筑,以及宽敞的户外空间(阳台、露台和私人花园),为居民提供舒适。每间公寓都暴露了一面木墙,增添了温暖的感觉。顶层享有场地中心 2,200 平方米的园景公园的广阔视野。一楼的商业场所为新区带来生机。
Sustainability: wood is at the heart of the project. Wood is at the heart of this housing project. Exemplary in terms of carbon emissions over its entire life cycle, it has been awarded the BBCA (Low Carbon Building) label.
可持续性:木材是该项目的核心。木材是这个住房项目的核心。在整个生命周期的碳排放方面堪称典范,它已获得 BBCA(低碳建筑)标签。
It is made of CLT (Cross Laminated Timber) for the floor, fa?ade, and walls from the first floor upwards, and combines bioclimatic design, control energy use, and carbon storage with more than 2,000 m3 of solid wood in the structure.
它由 CLT(交叉层压木材)制成,用于从一楼向上的地板、立面和墙壁,并将生物气候设计、控制能源使用和碳储存与超过 2,000 m3的实木结构相结合。
nnovations and technical specifications. Solar panels installed on the roof ensure a virtuous cycle of exploitation of natural resources. The floors of the balconies are made from the recovery of CLT window off-cuts. The facade coating was made with an ATEX (a French label for the creation of technical innovation) developed specifically for the project. The railings are made of Geolam composite wood resin, a durable and weather-resistant material.
创新和技术规范。安装在屋顶上的太阳能电池板确保了自然资源开发的良性循环。阳台的地板是由回收的 CLT 窗户边角料制成的。外立面涂层采用专为该项目开发的 ATEX(一个用于创造技术创新的法国标签)制成。栏杆由 Geolam 复合木树脂制成,这是一种耐用且耐候的材料。
The solid wood CLT structure is prefabricated in the factory, which halves the duration of the structural work, limits the number of truck rotations on site by 6 to 8 compared to concrete construction, and reduces the nuisance of the construction site for local residents.
实木CLT结构在工厂预制,结构工程工期减半,与混凝土施工相比,工地卡车转车次数减少6-8次,减少施工现场对当地居民的滋扰。
For the interior, French wood flooring with the PEFC label (certifying sustainable forest management) was chosen to reduce the building's carbon footprint.
平面图
建筑师:DREAM
地点:法国
面积:5680平方米
年份:2021
  • daghy
    daghy 沙发
    挺好看的设计
    2022-09-12 10:22:12
140.17 万条内容 · 2232 人订阅
砌体墙上部无梁直接入板会有什么影响嘛?
地下室底板到顶板有段砌体墙,总工让在顶板的墙的位置上也放一道梁,请问各位大佬能不放这道梁嘛,不放的话会有什么不好的影响啊。
